Question about Stihl FS 85 Weed Eater
Fuel in exhaust
How to find inlet needle
  • 390 Answers
You will find the needle-valve inside the the Carburetor reservoir bowl. Just be sure that the bowl is free of any dirt before putting it back together.
Good Luck
Rich Lilja
Posted on Sep 04, 2016
I got a husqvarna 128ld i got a new crab and it still wont start if fulding my pug out what can it be
If the carb is flooding then it will be an issue with the inlet needle in the carb itself, if the machine has been laid up with stale fuel in it it might just be a case of taking apart and cleaning, if this does not cure it then a replacement inlet needle will be required,however with these small American built machines there is only a complete carb listed. One other thought is check the spark arrestor or exhaust port is not blocked with carbon as this will cause the plug to get wet.
Nov 26, 2017 | Husqvarna Garden
Fuel leaks from carb after mowing till tank empty
Most often this is caused be an inlet needle in the carburetor not seating.
1) The inlet needle itself can be at fault
2) The needle seat can be damaged
3) Dirt/debris/foreign object caught in the needle seat can hold the needle open causing a syphon effect
4) Debris/foreign material in the fuel can be transferred to the tank
5) Best to use plastic fuel can
Feb 15, 2017 | Garden
Throwing black smoke and back fire on 1986 nissan hardbody
black smoke is a sign of over fuelling ( leaking injector washers, excessive fuel pressure , choke on float not working needle and seat not shutting off,. This will also cause back firing as the fuel is accumulating in the inlet manifold and being ignited by an exhaust valve opening
Aug 14, 2014 | Cars & Trucks
Motor coughs and splutters upon acceleration
Hi Anonymous, if you have a carbuerator the usual suspects are:
1. Damaged or restricted fuel tank venting system (gas cap).
2. Inlet system air leak.
3. Vacuum piston malfunction.
4. Accelerator pump leaking or no output.
5. Plugged bowl vent.
6. Fuel level (float chamber) too low.
7. Restriccted fuel supply passages.
8. Plugged jets or passages.
9. Worn or damaged needle or needle jet.
10. Enrichner valve not seated or leaking.
Please visit the website below for a prime suspect:
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley... Good luck
Feb 09, 2014 | Harley Davidson Motorcycles
What causes the engine to sputter when accelerating?
Hi Kallmeyer, and the usual suspects are:
1. Throttle cables misaligned or misrouted (may also affect idle speed).
2. Damaged or restricted fuel tank venting system.
3. Inlet system air leak.
4. Vacuum piston malfunction.
5. Accelerator pump leaking or no output.
6. Plugged bowl vent.
7. Fuel level in bowl too low.
8. Restricted fuel supply passages.
9. Plugged jets or passages.
10. Worn or damaged needle or needle jet.
12. Enrichner valve not seated or leaking.
For more information about your issue please visit the websites below. Good luck and have a nice day.
Victory Motorcycle Service Repair Manuals Page 2
Dec 09, 2012 | 2006 Victory Touring Cruiser
2004 crf450r dumps gas out of carb when gas is turned on
your float settings inside your carb are set wrong read my advice to resetting them and you should be ok
You'll need to first start off by removing your carb. Be sure to clean the surrounding area to the best of your ability to avoid dirt and debris falling into your carb; or worse, your engine. After you've removed your carb I would suggest a thorough cleaning using carb cleaner (or equivalent) and compressed air to ensure that all jets and passageways are spotless. Avoid using wire or other tools to clean orifices of jets; it's all too easy to alter their original designed dimensions.
After your carb is clean you can now set your float level. The picture below will allow you to become familiar with the parts that are responsible for maintaining the correct float level in your carb. There are four basic parts, the floats themselves (part of the float assembly), the float assembly tang, the fuel inlet needle valve, and the fuel inlet valve seat.
(Float assembly pivot pin not shown.)
It is always a good idea to remove the float assembly pivot pin (already shown removed) and extract the float assembly and the fuel inlet needle. The fuel inlet needle is a wearable part and over time can deteriorate. A worn fuel inlet needle can contribute to an irregular float level. Most fuel inlet needles consist of an internal spring loaded bumper (which contacts the float assembly tang) and a plastic or Viton (rubber) tip. Inspect the fuel inlet needle tip for wear and/or damage. To give you an idea, Eric Gorr recommends replacing the fuel inlet needle/seat assembly every two years. I've found that the average cost is around $15 for both parts.
(Fuel inlet needle shown with Viton (rubber) tip. The Viton is used to isolate the fuel inlet needle from vibration and to create a better seal against the fuel inlet valve seat.)
Now that you've made sure you aren't going to have any issues from worn parts you can reinstall your needle, float assembly and float assembly pivot pin and continue on to set your float level. The float level measurement is taken from the top of the floats (when the carb is positioned upside down) to the gasket surface of the float bowl as illustrated in the next picture. You can use an open-end wrench (sized per your spec), a small metric ruler, or a float level gauge. The tolerance for your float level is usually around +/- 0.50mm.
When setting the float level be aware that the spring loaded bumper on the fuel inlet needle valve may have a tendency to compress under the weight of the float assembly which will skew your measurement. Before you obtain your measurement you'll need to make sure that the float assembly tang just barely makes contact with the spring-loaded bumper. Sometimes it is easier to hold the carb body at a 45-degree angle to avoid compressing the spring in the fuel inlet needle.
If you find that your measurement does not match your float level spec then you can carefully bend the float assembly tang to achieve your desired measurement. Be sure to recheck your work, and if you feel confident that your float level is spot on then you can reinstall your carb and get back to riding.
Jun 20, 2011 | 2004 Honda CRF 450 R
Chokes down after running about 30 minutes. Will sometimes restart after several attempts and minutes but usually chokes down again within few minutes. I have changed the air and fuel filter, spark blug,...
There are few things that will make the engine run rich, one is the fuel inlet needle in the carb leaking, and the other is a blockage in the exhaust or spark arrestor.
May 14, 2011 | Garden
On my 99 honda 400 4x4 foreman gas pours out of the line at the bottom of the carburator when i turn the gas on what is wrong
The needle and seat are leaking. Check that there in no dirt or grit making the needle stick. Hold the carb cover upside down and **** lightly in the fuel inlet, if you detect any leakage, replace the needle and seat. Also check that the float has not become saturated or filled with fuel so that it does not lift the needle to shut off the fuel inlet.
Feb 25, 2011 | Honda CB 400 Four Motorcycles
Flooding walbro carb from blower.
The problem centers around the carburetor. The question lies in the condition and operation of the carb initially.
It appears you may need to double check your assembly of diaphragms and gaskets. check for loose welch plugs, adjustment needles in the wrong holes, inlet needle set too high.
*note: metering side diaphragm goes on top of the gasket, fuel pump diahragm has the gasket on top of it.
Nov 10, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Riding lawn mower keeps flooding
It sounds like the inlet needle seat is not closing all the way,allowing fuel to overfill the carburetor.The inlet needle seat may have dirt in it.You will have to remove the carburetor bowl and check for dirt or debris in bowl,if so remove the float assembly and check for a peice of dirt between the inlet needle and seat.If there is none you may have to replace the carburetor or rebuild it with a carburetor kit.You should also chang the engine oil because the overfilled carburetor drains to the crankcase,filling it with fuel,check the oil level and see if it is high,that would indicate fuel is in the oil.Hope this helps
Jul 28, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Stihl FS 85 Weed Eater Logo
82 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
