Question about Sanyo HEC SA5000C Massage Chair, Desert Sand
Display on but no functions
Switches on with display but cannoy operate controllers
How to reset microwave
there is no reset function to look over, check safety interlock door switch, Has lamp & control Display lit?
Aug 19, 2014 | Panasonic NN-H965 Microwave Oven
Why does my pioneer remote DDX3086 display work, but why can't I turn on my receiver or functions?
Check the remote control for its infrared emission.Check it with fresh batteries.If you wish to get more details about how to check a remote control, please visit this site.One among the posts has details about it.Surf the site with patience.
Aug 03, 2014 | Pioneer Televison & Video
Winsheild wiper will not work
The wiper control module is probably at fault ,without test that is just a guess . The wiper/washer switch is a input to the wiper control module. Do you know anything about automotive electronics an electrical systems ?
  • The Wipers are Inoperative
  • Fuse.
  • Wiper motor.
  • Multi-function switch.
  • Circuitry.
  • Wiper control module.
  • GO to Pinpoint Test B .
Voltage drop testing the power an ground circuits for the wiper control module would be a good place to start . Do you know how to test electrical circuits with a volt meter ?
PINPOINT TEST B: THE WIPERS ARE INOPERATIVE CONDITIONS DETAILS/RESULTS/ACTIONS B1 CHECK FUSE JUNCTION PANEL FUSE 16 (30A)
Fuse 16 (30A)
  • Is the fuse OK?
Yes GO to B2 .
No REPLACE the fuse. TEST the system for normal operation. If the fuse fails again, CHECK for a short to ground. REPAIR as necessary. B2 CHECK FOR VOLTAGE TO THE WIPER CONTROL MODULE - CIRCUIT 65 (DG)
Wiper Control Module C294
Measure the voltage between wiper control module C294-2, circuit 65 (DG), and ground; and between wiper control module C294-11, circuit 65 (DG), and ground.
  • Is the voltage greater than 10 volts?
Yes GO to B3 .
No REPAIR circuit 65 (DG). TEST the system for normal operation. B3 CHECK CIRCUIT 57 (BK) FOR OPEN Measure the resistance between wiper control module C294-3, circuit 57 (BK), and ground; and between wiper control module C294-5, circuit 57 (BK), and ground.
  • Are the resistances less than 5 ohms?
Yes GO to B4 .
No REPAIR circuit 57 (BK). TEST the system for normal operation. B4 CHECK THE MULTI-FUNCTION SWITCH
Multi-Function Switch
Check the multi-function switch; refer to Section 211-05 .
  • Is the multi-function switch OK?
Yes GO to B5 .
No REPLACE the multi-function switch; REFER to Section 211-05 . TEST the system for normal operation. B5 CHECK CIRCUIT 993 (BR/W) FOR OPEN Measure the resistance between multi-function switch C269-4, circuit 993 (BR/W), and wiper control module C294-7, circuit 993 (BR/W).
  • Is the resistance less than 5 ohms?
Yes GO to B6 .
No REPAIR circuit 993 (BR/W). TEST the system for normal operation. B6 CHECK CIRCUIT 589 (O) FOR OPEN Measure the resistance between multi-function switch C269-1, circuit 589 (O), and wiper control module C294-1, circuit 589 (O).
Yes GO to B7 .
No REPAIR circuit 589 (O). TEST the system for normal operation. B7 CHECK THE WIPER CONTROL MODULE OUTPUT FOR VOLTAGE
Wiper Motor C152
Turn the multi-function switch to the HI position. Measure the voltage between wiper motor C152-4, circuit 57 (BK), and wiper motor C152-3, circuit 56 (DB/O).
Yes REPLACE the wiper motor; REFER to Motor-Windshield Wiper . TEST the system for normal operation.
No GO to B8 . B8 CHECK CIRCUIT 57 (BK) FOR OPEN Measure the resistance between wiper motor C152-4, circuit 57 (BK), and ground.
Yes REPLACE the wiper control module; REFER to Module-Windshield Wiper . TEST the system for normal operation.
Jun 29, 2017 | 2002 Lincoln Town Car
F 56-2 ERROR CODE
Key Operator Mode
To the Key Operator
The key operator is trained to handle all special key operator functions that are not
accessible to the general user, such as monitoring overall copier activity, machine
performance, and service information; modifying machine settings; and controlling user
activity, for billing purposes.
A unique 4-digit key operator password is normally set by service at installation. If the
unique code is not set by service, the copier will not display Key Operator Password
Entry Screen when the Key Operator mode is being accessed, and a key operator
password will not be required. A service-set 8-digit ECM master key code must be
entered by the key operator to access the Electronic Copy Monitor functions, and a
service-set 4-digit Weekly timer master key code must be entered by the key operator to
access the Weekly timer functions.
To ensure the security of Key Operator mode, it is recommended that you establish a
unique key operator password, along with the key operator ECM master key code and
Weekly timer master key code, and keep them in a confidential file.
r HELP is unavailable in the Key Operator Mode
Key Operator Mode Screen 2
NOTE: The function number [12] Call remote service center and [13] Save ECM data to memory card on the
Key Operator Mode Screen will be dimmed and cannot be selected on the copier without the remote
diagnostics activated.
Key Operator Password Entry Screen Key Operator Mode Screen 1
Key Operator Mode 13-3
Key Operator Mode
To the Key Operator (continued)
How to Access the Key Operator Mode
1 First, be sure the copier power switch is OFF.
2 Then, turn power back ON while pressing the [HELP].
The Key Operator Password Entry Screen displays when the 4-digit key operator
password is set by service.
Otherwise, the Key Operator Mode Screen displays without the password
requirement.
3 If the Key Operator Password Entry Screen is displayed, use the keypad on the
touch screen to enter your 4-digit key operator password; then touch OK, to display
the Key Operator Mode Screen. (See note.)
If the key operator password is not valid, check with your service representative.
4 To display menus [11] to [13] of the Key Operator Mode Screen, touch the lower
arrow key. To return the menu [1] to [10] of the Key Operator Mode Screen, touch
the upper arrow key.
5 Make setting changes from the Key Operator Mode Screen, as described on the
following pages.
NOTE: If an invalid Key operator password is entered, continue by entering the valid 4-digit password.
13-4 Key Operator Mode
Key Operator Mode
Function Menu Map
FUNCTION MENU SUB FUNCTION MENU AND SETTING OPTIONS
[1] Initial setting [1] Copy mode: [RADF; 1-1; 1-2; 2-2; 2-1]
[2] Copy density: [AES; manual]
[3] Lens mode: [AMS; ratio 0.33~4.00]
[4] Paper tray: [APS; trays 1, 2, 3, 4, 5, or Multi-sheet bypass tray]
[5] Output: [sort; group; staple-sort]
[6] Staple: [Normal 1 position left; Normal 1 position right;
Normal 2 positions left; Normal 2 positions right; Upsidedown
1 position left; Upsidedown 1 position right; Upsidedown 2
positions left; Upsidedown 2 positions right]
[7] Image scan: [Normal mode; High mode; Very High mode]
[2] Lens mode ratio [User Set ratio]
[3] ECM [1] ECM Password and User name setting
[2] ECM Count limit setting
[3] ECM Count Reset
[4] ECM On/Off Setting
[5] Copy-Limit-reached effect
[4] Lock/delete [1] Lock Job memory
job memory [2] Delete Job memory
[5] Paper type [Recycled; Colored; Letterhead; Special; Labels; Invoice; Legal;
Ledger; Blank]
[6] Control panel [Dimmer; Brighter]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[1] Weekly timer On/Off setting
[2] Summer time setting
[3] Date & Time setting
[4] Timer setting
[5] Timer action On/Off setting
Feb 22, 2013 | Konica Minolta Copier Toner 7055/7065...
Lcd screen stuck in external screen mode
How to use the function (Fn) keys on the keyboard - ThinkPad T40, T40p, T41, T41p, T42, T42p, T43, T43p
Switching the display output location.
Switch between the computer display and an external monitor. If an external monitor is attached, the computer output is displayed in the following three patterns by turns:
  • External monitor (CRT display)
  • Computer display and external monitor (LCD + CRT display)
  • Computer display (LCD)
Notes:
  • For any operating system other than Windows 2000 or Windows XP, no additional procedure is needed. Just press Fn+F7.
  • This function is not supported if different desktop images are displayed on the computer display and the external monitor (the Extend desktop function).
  • This function does not work while a DVD movie or a video clip is playing.
To enable this function in Windows 2000 and Windows XP, the following procedure is needed:
  1. When you log on to Windows 2000 and Windows XP for the first time, press Fn + F7 and select a display-switching function in the Initial setup window. Since in Windows 2000 and Windows XP multiple users can log on to a single operating system by using different user IDs, each user needs to select the function in the initial setup window when logging on for the first time.
  2. If the Fn + F7 key combination have been assigned to a presentation scheme function, start Presentation Director, and change the settings.
Feb 28, 2010 | IBM ThinkPad T41 Notebook
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
2001 Merc Marq automatic ac blower motor stopped working. I wired blower directly to battery with a fused switch. This has worked for past 9 months----but, now the compressor stays on when the switch is...
check the fuses and blower motor resister first. Some systems don't have resisters. Use blower motor speed control instead.
SECTION 412-04: Control Components 2001 Crown Victoria/Grand Marquis Workshop Manual
REMOVAL AND INSTALLATION Blower Motor Speed Control Removal and Installation
  1. Disconnect the wire harness connector.
  1. Remove the screws and remove the blower motor speed control.
  1. To install, reverse the removal procedure.
  • The blower motor is inoperative—EATC
  • Fuse.
  • Circuitry open or shorted.
  • A/C blower motor switch.
  • A/C blower motor resistor.
  • A/C blower motor.
  • Go To Pinpoint Test
Electronic Automatic Temperature Control Module Self-Test
  • The EATC module self-test will not detect concerns associated with data link messages like engine coolant temperature or vehicle speed signals. A diagnostic tool must be used to retrieve these concerns.
  • The EATC module self-test will detect concerns in the system control functions and will display hard diagnostic trouble codes (DTCs) in addition to intermittent diagnostic trouble codes for concerns that occur during system operation. The vehicle interior temperature should be between 4° and 32°C (40° and 90°F) when carrying out the self-test. If the temperatures are not within the specified ranges, false in-car temperature sensor DTCs will be displayed.
  • The self-test can be initiated at any time. Normal operation of the system stops when the self-test is activated.
  • To enter the self-test, press the OFF and FLOOR buttons simultaneously and then press the AUTOMATIC button within two seconds. The display will show a pulse tracer going around the center of the display window. The test may run as long as 30 seconds. Record all DTCs displayed.
  • If any DTCs appear during the self-test, follow the diagnostics procedure given under ACTION for each DTC given.
  • If a condition exists but no DTCs appear during the self-test, refer to the Symptom Chart Condition: The EATC System Is Inoperative, Intermittent or Improper Operation.
  • To exit self-test and retain all intermittent DTCs, push the blue (cooler) button. The control will exit self-test, retain all intermittent diagnostic trouble codes and then turn OFF (display blank).
  • To exit the self-test and clear all DTCs, press the DEFROST button. The vacuum fluorescent display window will show 888 and all function symbols for one second. Then, the EATC control assembly will turn OFF (display blank) and all DTCs will be cleared.
  • Always exit the self-test before powering the system down (system turned OFF).
  • Intermittent DTCs will be deleted after 80 ignition switch ON cycles after the intermittent condition occurs.
Apr 16, 2009 | 2001 Mercury Grand Marquis
Have Pioneer DEH 1900MP CD receiver. Do not know how to set time. Have no amnual. Also information on the remote control
It's on page 12 of the manual. Here you go:
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/372010482DEH1900MPOperationManual1030.pdf
Adjusting initial settings
Using the initial settings, you can customize
various system settings to achieve optimal performance
from this unit.
1 Press SOURCE and hold until the unit
turns off.
2 Press SOURCE and hold until function
name appears in the display.
3 Press FUNCTION to select one of the initial
settings.
Press FUNCTION repeatedly to switch between
the following settings:
Clock—AUX (auxiliary input)
Use the following instructions to operate each
particular setting.
# To cancel initial settings, press BAND.
# You can also cancel initial settings by holding
down SOURCE until the unit turns off.
Setting the clock
Use these instructions to set the clock.
1 Press FUNCTION to select clock.
2 Press c or d to select the segment of
the clock display you wish to set.
Pressing c or d will select one segment of the
clock display:
Hour—Minute
3 Press a or b to set the clock.
Turning the clock display on or off
You can turn the clock display on or off.
! Even when the sources are off, the clock
display appears on the display.
% Press CLOCK to turn the clock display
on or off.
Each press of CLOCK turns the clock display
on or off.
Operating this unit
12 En
Aug 05, 2008 | Car Audio & Video
Sanyo HEC SA5000C Massage Chair, Desert Sand Logo
Top Sanyo Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Sanyo Furniture Expert? Answer questions, earn points and help others
