Question about Akai LCT2721AD 27 in. LCD Television
Tv will not turn on with or without remote
Model LCT2721AD . TV will not turn on with or without remote. It won't turn on with start button on the side of the unit. If I pull the power plug from the house current then plug back in everything works ok. I can shut it off a few seconds and turn it back on. If I wait say an hour and try it again no dice got to pull plug again.Not sure when I bought this set I am guessing 2 years.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 64 Answers
The power supply is broken. You need to replace the capacitors that are bulging inside. I did and now it works fine. I don't have any experience but I did it. Follow what this guy did. http://www.fixya.com/support/t1661054-akai_lcd_tv_power_light_stays_red_turn
Posted on Sep 09, 2009
Vivo tv won't turn on lost the remote and the
These are the universal remote control codes to Vivo TV. 0004 0005 0009. Check this link to know more codes and proceedings to other brands of remote controls, and buy one remote control that has setup codes with your TV. The above said codes are for GE remote with Vivo TV.
Jan 23, 2013 | Televison & Video
Someone sold me a Coby HDTV HDMI without a remote. The channel or the volume button on the side of the tv won't work so I got a universal remote. For some reason the only thing the universal remote...
the code that's entered on the remote is the wrong one for the tv. use the instructions for the remote and get the correct code.. for your model or search ebay for the exact remote. also child lock maybe activated on the tv meaning you cant use the buttons on your tv until you use menu on the remote to take it of.
Jun 08, 2011 | Televison & Video
When I turn the tv on, it comes on in DVD mode and won't change over to the tv mode.
You have two ways to change it to TV Mode.
1 - remote control (source button) -cycle through the options.
2 - side of the unit (source button) -cycle through the options.
If the remote doesn't work, try using the button on the TV to change the source mode.
If this doesn't work, you have a problem with the TV.
Another option is to check your inputs. If you have the input for the DVD in the wrong place, that may also be causing you the inability to change from DVD mode.
Apr 28, 2010 | Akai LCT2721AD 27 in. LCD Television
TV will not start easily. Akai LCT2721AD
You only have to unplug it for 30 seconds. Also, make sure it does not have a DVD in it when you turn it off as the TV will try to default to the DVD all the time. Resetting the power (I use a surge protector) allows it to turn back on normally. Based on the comments I've seen this TV has terrible sound with DVD, doesn't want to turn on, and is hard to mount on a wall.
Nov 18, 2009 | Televison & Video
Model LCT2721AD problem showed 5/11/09 about 24 hours ago. TV will not turn on with or without remote. It won't turn on with start button on the side of the unit. If I pull the power plug from the hou
No did not get it fixed I am in the process of moving from NJ to SC and don't have time this couldn't have happened at a better time.I will just move it broke.
Cheers William Ash
May 13, 2009 | Akai LCT2721AD 27 in. LCD Television
TV will not come on by using the remote control
I think I have an answer. This comes from someone from the Geek Squad. She said that somehow the TV was turned off at the TV and not the remote and that has reset the system . Try pushing the "STAND BY' button and everything should work as normal. I will find out for myself in the morning. Good luck to us both !
Nov 17, 2008 | Akai LCT2721AD 27 in. LCD Television
Model crcr4383 won't provide a code for Awia tv dvd combo unit
If you have a Universal RCA remote, go to remotefinder.com/default.aspx?site=rca and you shoulkd find the proper code.
Oct 27, 2008 | RCA Universal Remote Control
AKAI LCT2721AD On/Off Problem
My Philips LCD TV had the same problem. If your Voltage system is 110 AC till 127 AC and no transformator, then it is probably caused by one of the 4 main transistors, which are likely not originalfrom AKAI, but made in Malaysia or closeby there.
My TV works perfectly after 1. Replacing the burned or semi-burend transistors (in the back panel) 2. After repair (=US 60 plug the TV in a outlet from transformator set to 100 V.Good Luck!
Apr 15, 2008 | Akai LCT2721AD 27 in. LCD Television
Tivo DirecTV Remote-Program AKAI LCT2721AD
Try this: On the Tivo remote press and hold the TV Power button and the Directv/TIVO button at the same time. Hold both buttons down for about 4 seconds or until remote light stays red. Then press the channel up button until the tv turns off. You may press the button over 100 times. You need to go slow. When the TV turns off press the enter button (or select button).
Dec 09, 2007 | Tivo DirectTV Remote Remote Control
Akai LCT2721AD 27 in. LCD Television Logo
150 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
