Question about Samsung DVD-V4600 DVD Player/VCR
I was trying to unload a disc from the player. The try opened and almost immediately closed and started to load the disc. I tried to eject the disc but the tray didn't open and the screen displayed that the disc was loading. I tried to look for a manual eject like there is on PC's but couldn't find one. Any suggestions?
  • 10,594 Answers
Unplug unit from AC outlet, look at bottom of dvd player there would be manual eject slot and plastic cover on it, remove cover and slide lever with any flat screw driver so disc mechanism will unload and tray will eject slightly, pull the tray and take out disc.
Thanks.
Posted on Jun 14, 2009
Dvd stuck in Samsung bluray
Have you tried pulling the plug for a minute? Also try the eject button directly from standby.
Nov 26, 2013 | Samsung BD-F5100 - Blu-ray disc player
Magazine won't eject?
A CD may be stuck between the player unit and the magazine. You can try loading and unloading several times but in extreme cases it is necessary to do some disassembly to get at the disk
Oct 20, 2012 | Clarion Caa-355 6-Disc CD Magazine...
I put a disk in and there was already one in now it wont eject
The disc tray does not eject when the OPEN/CLOSE button is pressed. Solution
sp.gif sp.gif Follow the steps below to troubleshoot this issue.
    IMPORTANT: The disc tray will not open while a disc is loading; this is normal operation. If this is the case, wait until the disc is finished loading before pressing the OPEN/CLOSE button to open the disc tray.
  1. Make sure the disc tray is not locked; if necessary,
  2. Perform a power reset.
    1. Press and hold the POWER button for 10 seconds until the BD player turns off.
    2. After the BD player turns off, press the POWER button again to turn it back on.
  3. Attempt to open the disc tray by pressing the OPEN/CLOSE button on the front of the BD player.
  4. If the disc tray still does not open and a disc is stuck inside, follow the steps below to force the disc tray to eject:
    1. Turn off the BD player.
    2. Turn the BD player back on.
    3. Immediately after POWER ON is displayed, press the STOP button on the front of the player. IMPORTANT: Only use the STOP button on the front of the BD player. The remote control cannot be used for this operation.
      NOTES:
      • The disc tray should eject and the BD player will turn off. If it does not eject, repeat steps A-C.
      • It may be necessary to press the STOP button in step C two or three times.
If the issue is still unresolved, service may be required
Sep 15, 2011 | Sony BDP-S300 Blu-Ray Disc Player
Unable to eject disc using open/close buttons
if your not able to eject the disc using the open close button then try to user a paper clip push the clip in the small paper clip hole provided in your player it'll eject the tray..
if this often happens check with new disc if it still happens try to contact a the samsung for a authorized repair..
hope this was helpful
Oct 02, 2010 | Samsung DVD-V6800 DVD Recorder/VCR
Sony dvd player will not eject disc: "Disk Error" displays on screen then it will try to load over and over. It will not respond to open?
Try unplugging and re-plugging. If the does not work try to start the Player without letting it load. i.e. give it a separate command before trying to eject disc.
Aug 17, 2010 | Sony Televison & Video
I just finished running the cleaning disk and the player runs and says loading but dvd will not play. No picture on the tv?
Some dvd players simply will not play copies of dvd's, or ones made on a computer.
Another thing to try, is to unload/eject any discs, turn off the player, unplug from AC socket for a minute or two.....and then re-plug, and turn it on, load a disc, and see what happens. Hope this helps.
Apr 09, 2010 | Televison & Video
Cd player on 2001 lincoln ls - cd error when i press load button
My father inlaw just purchased a 2001 lincoln, with a six disc changer, Question is he loaded the unit ,and now he wants to eject the cd's and the changer won't open? any suggestions thanks
Jan 06, 2010 | 2001 Lincoln LS
Open/close tray disc stuck bose Lifestyle 48
Problem:
I also have a bose Lifestyle 48, and the same problem has happen to me where the DVD player would not open,
Solution:
Unplug the unit, Wait a few seconds, after plugging the power back in, immediately hit eject so that the player does not have time to spin up and try to read the disc again
Feb 17, 2009 | Bose Lifestyle 48 System
Dvd recorder doesn't eject disc
Yes, I'm having the exact same problem -- I can't eject the dvd that's in the player right now either manually or remotely. It plays fine.
Sep 23, 2007 | Televison & Video
Jvc-avx1 wont eject
Try to power down the unit and the power it back up then press the eject button. If this does not work there might be a hole in the front of the unit which you could insert a paper clip which will actuate a mechanical release switch.The last thing you can try is to open up the unit and manually rotate the load and unload motor and this will eject the DVD. Restore the cover and then start up the unit to see if things are ok.
Sep 16, 2007 | JVC KD-AVX1 Car DVD Player
Samsung DVD-V4600 DVD Player/VCR Logo
97 people viewed this question
Jerry Greenberg
Jerry Greenberg
