Question about Microsoft Outlook 2013 543-05747
DLL error : C2r32.dll problem on MS Outlook 365 in South Africa
Hi I have this error message C2r32.dll showing and preventing me from starting Outlook 365. Please help.
    Problem Solver:
  • 8 Answers
Do an online repair of your office 365
Posted on Apr 30, 2014
  • 7 Answers
SOURCE: window proffectional 2000
This message occurs when a "run key" still exists in the registry for an item that has been removed from your machine.
In this case, you would just "fix" it with HJT to remove the key from the registry.
If you still have Mywebsearch active, the first step would be to uninstall it via Add/Remove Programs.
Failing that, open the C:\PROGRAM FILES\MYWEBSEARCH folder and run the uninstaller manually. If no uninstaller exists, you could just delete the folder and clean registry remnants manually, to the extent desired - (most just remove the runkey and leave it at that).
Posted on Mar 19, 2008
  • 7993 Answers
SOURCE: I have a bug in my microsoft outlook program. How
I may have the solution for you. Effectively, if you repair the installation, or do a reinstall you will lose your E-mail. However since Outlook Express is a fixture in Windows OS, you can use it to create an E-mail account. Create the account exactly as OUTLOOK and import the E-mails in Outlook.
To do that press Menu File, Import submenu. You can import all that concerns Outlook.
Once your Outlook is repaired or reinstalled, do the same thing. It will ask you to import various things. Point it to Outlook Express and import your E-mails.
Hope it helps.
Posted on Oct 11, 2009
  • 11 Answers
SOURCE: Problems with MSOE.DLL will not load no matter how
http://support.microsoft.com/kb/232480
Posted on Nov 20, 2009
SOURCE: Can not run Unicode version of ATL.DLL on Windows 95.
hi,
http://www.fix-all-dll-errors.com/msoeres.dll/
u can go to this site...this will help in case of missing or for downloading dll's or also if there is errors in dll's..!
I also registered few dll's from this site...worked in my case :)
Posted on Feb 09, 2011
  • 29 Answers
SOURCE: ie shows error message(, ModName ntdll.dll.) then
The causes of ntdll.dll error messages can vary greatly. However, most ntdll.dll errors result from a corrupt or damaged version of the ntdll.dll file itself, corrupt hardware drivers, or issues between Windows and other programs.
Ntdll.dll errors can sometimes mean that a piece of hardware in your computer is malfunctioning, but this is rare.
Resolution
1.Restart your computer. The ntdll.dll error you're receiving could be due to a one-time, temporary issue and a simple reboot may resolve the problem completely.
2.Reinstall the program if the ntdll.dll error only displays when you use a specific program.
If the software program has any updates or service packs available, install them too. The software's programmers may have identified an issue with the program that caused the ntdll.dll error and then issued a patch for it.
Note: Third party software programs that have been installed on your computer are almost always the cause of ntdll.dll errors. The remainder of these troubleshooting steps resolve ntdll.dll issues only rarely.
3.Check the Windows service pack level you're running and then check Microsoft's support site to see if there is a more recent service pack available for installation. Some issues that caused ntdll.dll errors have been corrected in these service packs from Microsoft.
4.Selectively disable Internet Explorer add-ons. If your ntdll.dll error is displaying when you start, run, or close Internet Explorer, an add-on may be causing the problem. Disabling each add-on, one by one, will determine which add-on is the culprit (if any).
Note: As a workaround, assuming the ntdll.dll error really is Internet Explorer related, install and use a competing browser like Firefox.
5.Rename the NLSPATH system variable. If your Windows system does not have this environment variable, skip this step.
Note: This is a troubleshooting step for this issue only. Be sure to set this path back to its original name if this does not resolve the ntdll.dll issue.
6.Disable Data Execution Prevention for Explorer.exe. As in the previous step, this is for troubleshooting the ntdll.dll issue only. If this doesn't resolve the problem, return the Data Execution Prevention settings to their previous settings.
7.Update drivers for any hardware in your computer where updated drivers are available. Outdated drivers sometimes cause ntdll.dll errors.
8.Test your memory for damage. If you're receiving ntdll.dll messages, one possible cause could be a bad memory module in your system. Testing your memory will either identify a problem or clear your RAM of any responsibility.
Replace your memory if it fails any of your tests.
9.Ntdll.dll errors could occur if you have an Iomega Zip drive on the same IDE cable as the hard drive inside your computer. If so, move the Zip drive to a dedicated IDE controller.
10.Replace the IDE cable connecting the hard drive to the motherboard. If this cable is damaged or malfunctioning, one symptom could be the ntdll.dll error you're seeing.
11.Repair your installation of Windows. If individual software reinstallations fail to resolve the problem, a repair installation of Windows will replace the ntdll.dll file.
12.Perform a clean installation of Windows. A clean installation will completely remove Windows from your PC and install it again from scratch. I don't recommend this option unless you've exhausted all previous troubleshooting ideas and you're comfortable that the ntdll.dll error is not caused by a single program (Step #2).
Note: If a single program or plugin is causing the ntdll.dll error, reinstalling Windows and then reinstalling all of the same software may lead you right back to the same ntdll.dll error.
13.While extremely rare, if everything else has failed, including the clean installation from the last step, you could be dealing with a hardware issue with your hard drive.
If so, replace the hard drive and then perform a new installation of Windows.
Posted on Jul 20, 2011
Getting an error on outlook mapi cant find the msncon.dll file
what version operating system did you install on . most likely it is not compatible with your OS
Jun 28, 2015 | Microsoft Office Outlook 2003 for PC
Dll missing
This problem occurs when the Previous version isn't uninstalled properly. The thing is that when a software is uninstalled some files often remain in the system. These files are ofter referred to as "Leftovers".
To resolve this issue Uninstall your software (i.e. Previous version of MS Office) using a special Uninstaller software. You can find one if you google these words "uninstaller".
Alternatively you may also find a complete guide on how to fix this problem at this link
Office 365 error The program can start because c2r32 dll is missing...
Hope this helps.
Mar 19, 2014 | Microsoft Outlook 2013 - Download - 1 PC
I cannot start my microsoft office outlook MAPI32.DLL is corrupt
This Common Mapi32.dll Errors occurs because of a corrupt or damaged windows registry. In this case you can resolve them by using a registry scanner which is updated with all the most recent information.
Apr 19, 2011 | Microsoft Computers & Internet
My MS Outlook's MAPI32.DLL file is currupted or the wrong version. Pls give me solution for Access Outlook.
hello
try rename mapi32.dll and msmapi32.dll to the .old extension and start outlook or access
if that doesnt work try
1. Delete the contents of the "C:\Program Files\CommonFiles\System\MSMAPI\1033" folder
2. Reboot into normal mode and start Outlook/access, setup will replace the files
with the correct version and Outlok will load as normal.
Oct 07, 2010 | Microsoft Office Outlook 2003 for PC
Dear Walt Disney I have bought the game " Finding Nemo Learning with Nemo in South Africa for my granddaughter who is a fanatic- devoted fan of Nemo, Saddly the game do not want to play. It start up well...
http://www.error-fix-tool.com/dll.php?t=Msvcr80.dll
Goto this site and download the repair tool, it should fix your problem. Post back and tell me how it goes.cheers.
Mar 25, 2010 | Computers & Internet
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
Upgraded to Windows 7 on my D509 Desktop. When I try to open MS Outlook, I get a error message stating that Windows has deactived the avgxch32.dll. Where can I get a new driver that will run within...
avgxch32.dll is an AVG anti virus dll. You will need to upgrade AVG to the most current version or change it out for another Anti-Virus program.
If you have the most current version, uninstall it and reinstall a new copy.
Dec 18, 2009 | E-Machines eMachines Desktop PC
hi,
Apr 15, 2008 | Microsoft Office Outlook 2003 for PC
Microsoft Outlook 2013 543-05747 Logo
122 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
