Question about RCA 25255RE2 - - Phone
Hold button doesn't work
I press hold but caller gets cut off.
How to get caller id for missed calls for Panasonic kx-t7730
Panasonic KX-TA624/824 automatic Caller ID logging How to set up automatic Caller ID logging
in the KX-TA624 phone system with KX-T7735 phones. (for dash four and five, and KX-TA824)
System Programming:
  1. In System Program number 900, enable Caller ID for the lines you have Caller ID on. (To get into system programming, press Program * # 1234.)
  2. In System Program number 901, select your own area code and any other area codes that don't have to be dialed when making a call. The area code digits are removed from Caller ID log information so you can return a call without dialing unnecessary digits which would mess up the call.
  3. In System Program number 902, if necessary, indicate the number of digits to be removed, and a particular digit (usually 1) that might have to be added, when returning a local phone call. The default programming is to remove the first three digits, and add nothing; which is correct for most locations.
  4. In System Program 903, if necessary, indicate the number of digits to be removed, and up to 4 digits that might have to be added, when returning a long distance phone call. The default programming is to not remove any digits, and add a 1; which is correct for most locations.
  5. In System Program number 909, enable Call Log Assignment for each phone where you want to log Caller ID information. You can use * to indicate you want logging at all phones.
  6. Get out of system programming. (Press Hold or End, then Program.)
Phone Programming:
  1. Program a button for Caller ID Indication on each phone where you want to log Caller ID information. Press Program, then the button you want to use for Caller ID Indication (we recommend the top button in the left column), then 96, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 6 instead of 96.)
  2. At each phone where you want to log all calls, press intercom, then 7382#.
User Tips:
  • The Caller ID Indication button will light up only when the system has logged UN-answered calls.
  • Use the Navigator Key at the lower right corner of the phone to scroll through Caller ID information.
  • You can erase the entire Caller ID log by pressing Intercom, then 70**#
  • You can erase an individual Caller ID record by pressing Transfer while the information is displayed.
  • If your phone does not have a Navigator Key, you can program an available button for Caller ID Selection. Press Program, then the button you want to use for Caller ID Selection, then 97, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 7 instead of 97.)
  • To call a number displayed on the Caller ID log, pick up the handset or press the speakerphone button, and press the Caller ID Indication button.
Jul 01, 2015 | Panasonic KX-T7730 Corded Phone
Tip
Here are the instructions for making a conference call on a Norstar system....
Conference [Feature] [3]
  • Establish a conference call between yourself and two other parties.
1. Make or answer the first call.
2. Put the first call on hold.
3. Make or answer the second call.
4. After the second call is connected, press [Feature] [3].
5. Press the line or intercom button of the first held call.
6. Press [Rls] to end the conference call
  • To remove yourself from a conference permanently (unsupervised conference):
    • Press [Feature] [7] [0]. The other two callers remain connected. (Some external lines may not support this feature.)
  • To put a conference on hold:
    • Press [Hold]. The other two callers can still talk to each other.
  • To split a conference:
    • Press the line or intercom button of one caller to consult privately while the other caller is on hold. To re-establish the conference, press [Feature] [3].
  • To disconnect one party:
    • Press the line or intercom button of the caller you want to disconnect, then press [Rls].
    • Press the line or intercom button of the remaining caller to resume your conversation.
  • To independently hold two calls:
    • Press the line or intercom button of the first caller, then press [Hold]. The second caller is automatically put on hold. To re-establish the conference, retrieve one call from hold, press [Feature] [3], then retrieve the second call from hold.
on Mar 21, 2009 | NorStar CallPilot 100
Sorry to bother you but how do i transfer a call from one phone to another phone please, i have tried all different ways but seem to cut callers off, i have bt synergy 5500. thank you Yvonne
Hi Yvonne
If you look on the phone there should be a transfer button,press this then phone the number required to put the call through when the person answers tell them you have a caller on the line who it is and then you are putting them through now.....just put the phone down then they should be connected together now.
If this doesn't work try and get hold of a user guide book on this model because you are still cutting them off with this method...........GOOD LUCK
Steve B
Feb 01, 2011 | Cell Phones
I can hear the caller but the caller can't hear me
Look to see if the Mute button (or Hold button) has been pressed. If so, press the Mute (or Hold) button again to turn it off. With Mute ON, you can hear what your caller is saying, but they can't hear you.
Jan 24, 2011 | Uniden DECT 6.0 Cordless Telephone...
Hi i have lost my user guide for my telstra 8200 phone & want to know how to answer a second call while you talking on line 1
To answer an incoming call whilst you are on the phone:
Press and hold the "2" button. Your first caller is put on hold and you can talk to your second caller.
To revert back to the original caller, press and hold the "2" button again.
Oct 06, 2009 | Lands Phones
HOW TO DO A CONFERENCE CALL
May 14, 2009 | NorStar M7324 Telephone
Call conferencing
May 11, 2009 | NorStar Meridian M7310 Phone
Unable to use conference button
Mar 11, 2009 | Nortel Meridian M7208 Corded Phone
I have a NorStar M7310 phone -I am on a conf call - how do I mute the line where the other parties cant here
Dec 04, 2008 | NorStar M7310 Corded Phone
Conference Calls
To establish a conference call between yourself and two other parties.
4. After the second call is connected, press feature button then 3.
5. Press the line or intercom button of the first held call (not required on the
T7100/M7100 telephone).
6. Press Release to end the conference call.
Press feature buton then 70. The other two callers remain connected. (Some
external lines may not support this feature. See your system
administrator.)
Press hold. The other two callers can still talk to each other.
then press Release button. Press the line or intercom button of the remaining
Aug 22, 2008 | Nortel T7316E 2-Line Corded Phone
RCA 25255RE2 - - Phone Logo
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
