Question about Miele Dryers
Kenworth t800 door diagram
Interior Handel will not open door
  • 40 Answers
SOURCE: door handel won't open door.
Typically in order to remove the actual handle from the door, you must first remove the door panel. When removing the panel, at first do not disconnect your window switches, as you will need to roll up the window in order to accsess the door latch. Once the window is up and all of the door panel compnents are removed, you will likely see a plastic cover of some sort that seperates the door panel from the metal part of the door. You will also need to remove this. Afterwards there should be room enough to look inside the door and see the door latch from the inside. There should be a couple of screws/ bolts holding the assembly together. There will be a series of rods that connect to the latch. The mechanism the opens the door from the outside connects to these rods with a plastic clip. You will likely need to replace that clip to solve the problem. This is a fairly easy task, however, due to the confined space, it will be time consuming.
Posted on Oct 17, 2008
tparsenault
  • 170 Answers
SOURCE: limited cb radio range on Kenworh t800 truck
I recall problems grounding the antenna on those kw's. May want to try a no ground antenna. Also the stock coax that comes with the truck sometimes gets broken or pinched. Go to a good shop, replace the cheap coax and grount the antennas.
Posted on Dec 28, 2008
  • 31 Answers
SOURCE: where is the heater motor in a 2003 kenworth t800
On the Passenger side outer fire wall, remove the HVAC cover and the Heater motor is attached to the back side of that.
Make sure you order a motor and Cages as the never come off a tuck that old.
Posted on Jan 07, 2010
emissionwiz
  • 76109 Answers
SOURCE: need the wiring diagram for
we have no wiring diagrams for trucks at this site, sorry
Posted on Aug 25, 2010
  • 3 Answers
SOURCE: I have a 2001 kenworth t800. the brake lights are
there is either a 50 amp mega fuse at the alt. or a 10 amp fuse at the engine side of firewall driver side of truck. more than likely that is your problem.
Posted on Feb 14, 2011
Where do I lubricate a creaky clutch pedal on a 2014 Kenworth T800?
Spray Lithium grease at the clutch pedal pivot under the dash. But chances are the clutch pedal plastic bushing is deteriorated and the noise will quickly return.
Jul 14, 2016 | Cars & Trucks
How do I reset my check engine light on my 1997 T600 Kenworth
2010 KW T800 How to reset engine check light ' TruckersReport.com ...
www.thetruckersreport.com > ... > Kenworth Forum
Nov 8, 2011 - Is there a way to reset Engine Check Light without going to dealer? ... Inmy case it was 3725. If I run with ... 2013 Kenworth Dash panel removal.Missing: 1997 ‎t600
DIY: Reset Check Engine Light without OBDII reader ...
? 3:31
https://www.youtube.com/watch?v=TvBcdjLkBhU
Jul 1, 2014 - Uploaded by Christian Macias
Learn how to reset your Check Engine Light (CEL) without using an OBD II 2 scanner / reader tool. ... Year ...
Nov 19, 2015 | Cars & Trucks
Take out evaporater fan for 1999 kenworth t800
Should be 4 screws holding in the plastic cover over the evaperator then another 4 screws holding the fan bracket in. Depending on the fan you may need to cut the wires then use a **** connector or marrettes to re connect with the new motor
Sep 06, 2012 | Refrigerators
Where is the heater motor in a 2003 kenworth t800
Dec 18, 2009 | Model Power HO Kenworth w/Flat Trailer,...
1992 dodge Gr. caravan side door won't open
Probably needs a handle or latch,both have cheap plastic retainers & the latches are a common issue.
Jul 22, 2009 | 1992 Dodge Grand Caravan
Dryers Logo
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
