Question about Refrigerators
Ice maker not making ice kenmore 106.5812*700
Ice maker is not making ice. makes very little
    New Friend:
  • 60 Answers
Check the filter on your water supply its probably blocked
Posted on Mar 20, 2014
the dr
  • 447 Answers
SOURCE: Ice maker not making ice.
These Icemakers have plastic gears on the modules that are breaking, also some have thermostats that are malfunctioning. I recommend haveing an experianced tech look at the unit to see if you need the new upgraded indoor ice maker.
Posted on Jan 15, 2008
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
SOURCE: ice maker makes very little ice
my under the counter ice machine makes very little ice. we just paid $600 to have a repairman put a new motor in it (although I don't think that was ever the problem) because it would always run, it was just not making any volume of ice. now it's been fixed and the repairman brought it back under th counter yesterday and it's STILL not making more than maybe 1 cup of ice in over 24 hours. I can hear the water running when Iopen it, but just don't get the bin full of ice like it used to get. HELP!!
Posted on Apr 09, 2009
  • 351 Answers
SOURCE: Kenmore Ice Maker Not Working
Probably need a new ice maker, whirlpoolpartssurplus.com
Posted on Jun 23, 2009
  • 6 Answers
SOURCE: kenmore coldspot 106.556325 not making ice
could be your ice maker or your water valve
Posted on Aug 30, 2009
Ice machine makes little bit of ice one day then it might be two days before it makes anymore
clean the condencer under frige.is the fan working good in the freezer. the ice maker heater could be bad ice maker gear could be bad
Dec 21, 2009 | Kenmore Refrigerators
I don't recommend repair on this unit. Simple replacement. Try to find Ice maker kit @ local home depot or lowes that is same. You can buy whole kit for $50-$75.00.
Aug 28, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Jun 23, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker not making ice. red light on control panel blinking twice.
Remove the ice bucket and inspect the ice maker for an ice cube stuck in the ejector. Hit it with a little heat of a hair dryer till it gets loose and the ice maker starts rotating. Replace the ice bucket. See if it starts making ice again amigo.
Jan 31, 2009 | Kenmore 53642 / 53644 Side by Side...
Ice maker won't stop making ice
it's time to replace the ice maker, it will not stop, the you can feel the small bar when it looks in to the of position.
Dec 10, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite refrigerator 795.775.62600
make sure the ice maker is turned on, push and hold the little round button on the front for 15 seconda and see if it starts up an cycles. Also check to make sure the fill tube isn't clogged to the ice maker and another thing to check is the water valve.
Sep 04, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Coldspot Ice maker is not working on our side by side refrigerator
I have a kenmore coldspot side by side model # 106.53662300.
The ice maker red light is blinking and it has made very little ice in the last 24 hours. What do you think the problem is?
Jan 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
