Question about Microsoft Computers & Internet
Hp pavilion dv32332tx
Why my laptop could not start?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 10 Answers
First of all in this situation check the AC adapter. You can test the output voltage with a voltmeter. If you cannot do that, find a known good AC adapter and use it for testing the laptop. It is possible the laptop appears to be dead because the AC adapter is bad (and the battery is discharged). If you know that the AC adapter is working properly and it outputs correct voltage but the laptop is still dead, most likely you have a power issue on the motherboard (or power board on some laptops) and it has to be replaced.
If you have to replace the AC adapter, make sure you use a correct one. The output voltage must be exactly the same as on the original adapter. The output amperage has to be the same as on the original adapter or higher, but not lower.
Situation 2.
When you plug the AC adapter the power LED and the battery charge LED light up. When you press on the power button the laptop powers up but will not start. There is no video on LCD or external monitor.
If the power LED lights up it indicates that the laptop is getting power from the AC adapter. Most likely there is nothing wrong with the adapter but just in case test it with a voltmeter to make sure the output voltage is correct.
Also try this. Unplug the AC adapter, remove the battery and wait for 1-2 minutes. After that plug the AC adapter ans try starting the laptop again. Sometimes this trick helps.
It also could be a memory related problem. Try reseating the memory module, just remove it from the slot on the motherboard and install it back. Try installing the memory module into the other slot (if it's available). If you have two memory modules installed, try removing them one by one and start the laptop just with one memory module installed.
If the laptop starts fine with one memory module in both slots, but will not start with the second memory module in both slots, the second memory module is faulty. Replace the module.
If the laptop starts fine with both memory modules when they are installed in the slot A, but will not start with both memory modules installed in the slot B, the slot B is faulty and you'll have to replace the motherboard or use only one memory slot.
Situation 3.
When you press on the power button, the laptop makes a series or short and long beeps and will not start up. There is no video on the screen.
In this situation test the memory module as I described in the situation2. Try installing a known good memory module. Most likely you are getting a beep error because of a faulty memory.
Situation 4.
You start the laptop. It sounds like the laptop is booting normally (hard drive LED is flashing) but there is no video on the screen
In this situation test the laptop with an external monitor. If the external screen works fine but there is no video on the laptop LCD, most likely there is a problem inside the laptop display assembly. Go to my previous post witch covers laptop video problems in more details.
Situation 5.
You start the laptop and it starts making repetitive clicking noise or grinding noise.
Most likely you hear this noise because of a faulty hard drive. You can remove the hard drive and start the laptop without it. If the noise is gone, the hard drive is your problem. Replace it.
If the laptop makes clicking or grinding noises and you still have video on the screen, you can run a hard drive test utility. I usually use Hitachi's drive fitness test. This test is reliable and easy to use.
Situation 6.
The laptop boots into Windows ans works for a while, but after that it shuts down by itself without any reason or warning. You restart the laptop but the same problem appears again
Most likely it's a heat related issue. Listen for the cooling fan, make sure it works.
Also this problem might appear because of a faulty memory module, try some tips from the situation 2.
The laptop still boots ans you still can see the screen, so you can run the memory test. I usually use Memtest86+. Run the memory test and if it fails, replace the faulty module.
Posted on Nov 20, 2014
First thing to try:
Remove your battery and charger, hold the power button for 10-15 seconds. Plug the laptopicon1.png into mains ONLY leaving the battery out. Try powering it up.
If the laptop powers up ok, shut-down and re-insert your battery. You should find your laptop will continue to work fine for the foreseeable future, this kind of issue is a common occurrence on laptopsicon1.png.
If not I would then try re-seating your RAM/Memory, if that doesn't work and you have more than one stick remove one at a time to see if either one is causing the problem. If you have only one stick find a replacement to test your laptop with.
If you are still finding the same issues with the laptop I would then proceed to reseat all components of laptop, including the CPU.
If the issues continue I would then remove all non-essential components one by one, each time attempting to power the laptop. At worst you will eventually end up with just the mainboard, CPU, RAM and an external monitor plugged into the mainboard, that still doesn't function correctly. I would then conclude your mainboard needs replacing.
Mar 19, 2014 | Computers & Internet
Laptop turns off when optical drive start to work
i will start with a battery test looks like the motor is drawing too much current for ac support only .
Jul 13, 2013 | Pavilion HP Pavilion DV4-1225dx AC Adapter...
If the battery level is near 100% or 99% and it says "Plugged in, not charging" then disconnect power for a few minutes until it reaches 90% and reconnect it then; even try a restart.
If the battery level is near 50% then check your energy management software and see if there is a setting for "battery optimisation" and switch it to "optimise for battery runtime".
Also, there might be a problem with the battery. Is there a red cross over the battery indicator? If yes, then you have to replace your battery.
Jun 13, 2013 | Computers & Internet
Need a replacment or new motherbord for tx1410us
1) http://www.sparepartswarehouse.com/HP,Pavilion,tx1400,KC469UA,Laptop,System-Boards.aspx
2) http://www.pelltechnology.com/HP-Parts/HP-Pavilion-Laptop-Parts/HP-Pavilion-TX1000-Series/HP-Pavilion-tx1400-series/HP-Pavilion-tx1410us/Motherboards-%26-LCD-Screens/
The Pavilion tx1410us Notebook PC is one of the Pavilion tx1000 series of Notebook PC's.
Here is the download page for a free Service Manual,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
Go to the 18th line down. The line that starts with HP Pavilion dm1.
Go to the second line and across to tx1000.
Left-click on tx1000.
This is a PDF file. You may not see anything happening for up to 30 seconds after you click.
The file is downloading in the background.
After you see the first page it may take additional time for the file to fully download.
Suggest you let the file download all the way before looking through it.
Nov 25, 2010 | HP Pavilion tx1410us Tablet PC
When I start the laptop or when the screen is
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN ... Power LED and battery charge LED start flickering when you wiggle the power .... HP Pavilion dv7-4080us 17.3-inch Desktop Replacement Laptop PC ... High-Capacity Battery For Hp Pavilion Zd8000 Series Laptops ...
www.articlesbase.com › ComputersLaptops
Jul 19, 2010 | HP Pavilion zd8000 Notebook
How about this Pavilion dv8000 Battery for HP Laptop Battery?
You just write down the details about HP pavilion dv8000 battery, I know two websites have cheap HP pavilion dv8000 battery
http://www.cheap-laptop-battery.co.uk/laptop-batteries/hp-pavilion-dv8000-series.htm
http://sales-battery.com/laptop-batteries/hp-pavilion-dv8000-series.htm
Jun 02, 2009 | HP Computers & Internet
Computers & Internet Logo
44 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
