Question about Lexmark X658DE All-In-One Laser Printer
230.13 jam stopwatch on panel
Removing the beep sound from an avia stopwatch?
If your Avia stopwatch has no option for muting the beeps, there is a very simple way to achieve a semi-permanent mute capability.
1. Using a small screw driver, remove the case back of the stop watch.
2. You will see on the inside of the back panel, a small circle stuck to it. This is the piezo speaker that beeps.
3. Take a small piece of tape and apply it to the speaker. Best choice would be a smooth painter's tape (blue) or electrical tape (black). But thick clear packing tape might work as well. It doesn't need to be a big piece -- just large enough to be in position between the speaker and the metal contact from the stopwatch module.
4. Re-assemble the watch.
5. Test for sound.
Jan 03, 2018 | The Watches
What are the types of stopwatches?
There are two types of stopwatches: mechanical and digital. Mechanical watches are sometimes preferred because of their modern designs and because they don't require batteries. Digital stopwatches are considered more accurate and don't have to be rounded up (because they have batteries). They are also more stylish than mechanical stopwatches and sometimes have a sporty look.
Aug 29, 2012 | Coleman Exercise & Fitness
Where can I get a mechanical stopwatch?
They sell mechanical stopwatches in many websites, and not just online sport shops. Here is a link to the Amazon site, where they sell mechanical stopwatches for good prices. http://www.amazon.com/Ultrak-1000-Mechanical-Stopwatch/dp/B002YRZTAS
Aug 20, 2012 | Exercise & Fitness
What's the best brand for stopwatches?
The best stopwatches are made by Seiko. Seiko is also the official Olympic Games timer so you can get the idea that they are a solid brand. The only drawback is the expensive prices the charge even on simple stopwatches, just to get the idea, the cheapest I found cost 89$.
Aug 02, 2012 | Exercise & Fitness
Can I turn the beep off on the stopwatch?
Generally most of the new stopwatches have a mute function that allows you to turn off its beeps but not in all of them. You can visit http://www.johnisfit.com/2008/10/23/sportline-240-stopwatch-how-to-stop-the-alarm/ to see exactly how to do it on your stopwatch.
How do I use the stopwatch on iPod nano?
"iPod Software 1.0 for iPod nano introduces a Stopwatch feature. You can use the Stopwatch as you exercise to track your overall time and, if you're running on a track, your lap times too. The Stopwatch menu is located in the Extras menu. To access the Stopwatch from the main menu, select Extras, then Stopwatch, and then Timer (Extras > Stopwatch > Timer) to see its display. Total time of session Current lap time Left button (Start function shown)1 Battery indicator Right button (Clear function shown)1 The left and right buttons' names and functions will change, depending on the current state of the Stopwatch. Using the Stopwatch When you first enter the Stopwatch screen, the left button is labeled Start and the right button is labeled Clear. To use the Stopwatch, select the Start button (use the Click Wheel to highlight the Start button, then press the Center button). The Stopwatch creates a new session, and both the total time of the session and the current lap time begin counting: When these counters begin, the left button changes to Pause and the right button changes to Lap: If you select the Lap button, the current lap time will be recorded in the session's log, then the Stopwatch resets the lap time to zero and begins counting the new lap's time. The total time of the session will freeze for 5 seconds after you select the Lap button so you can quickly view your total time at the end of that lap. After 5 seconds, the total time of the session displays the correct total time and resumes counting. If you select the Pause button, both timers will stop counting and the left and right buttons will change to Resume and Done, respectively. If you select Resume, both timers will begin counting again. If you select Done, the Stopwatch records all the final times and creates statistics for your session in a log. Please note that selecting the Done button does not reset the display. You will see the final times for your total time and lap time displayed: To reset the display, select the Clear button (appears after you click Done and then select Timer again). Stopwatch Behaviors You can play music and use the Stopwatch at the same time. When iPod nano displays the Stopwatch screen, the Play/Pause, Next/Fast-forward, and Previous/Rewind buttons control music playback as usual. If you're playing music, you'll see an icon in the upper-left corner of the Stopwatch screen that indicates the current playback state: A play icon indicates that music is currently playing. A pause icon indicates that a song is currently paused. You can use the Menu button and the Click Wheel to navigate to other menus without interrupting the Stopwatch. Note: The Stopwatch will prevent your iPod from sleeping if it's counting. The Stopwatch will automatically stop if any of these three conditions are met: The total time counter reaches 24 hours iPod goes into hibernation (you can start it again when you wake iPod) You conne
Sep 28, 2005 | Apple iPod nano
Lexmark X658DE All-In-One Laser Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
