Protect light not comeing off
When switch on the protect light staying on
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 56 Answers
Not passing self test. since my crystal ball got broken I have no idea which unit you have and/or what it even is. you are prolly better bringing this one to the shop
Posted on Mar 24, 2014
I have a Rockford fosgate 501bd why the protect come on?
i say somehow you have damaged the amp, it needs repair or tip. useually output transistor or fets are faulty, if you cut the faulty ones out of circuit the other remaining channels may work
Oct 16, 2014 | Car Audio & Video
Engine management light reset
The car is trying to tell you something - limp mode is there to protect the engine if a serious problem is detected. Stop driving it and get someone out to scan the codes and diagnose this.
Nov 15, 2013 | BMW Cars & Trucks
After turning ON the power/standby switch, the unit(receiver) display comes ON (green light) then after approx.4-5 seconds the display goes OFF and the unit defaults back to the standby mode (red light). I...
Is the red light flashing at first?
The unit may be going into protect mode. Lets hope it has done the job and the receiver has protected itself from failure.
Protect mode can result from speaker wires touching each other or the Amps2_bing.gif metal case. Check that first.
It can also be caused by unstable ohm loads if too many speakers2_bing.gif are connected to any of the outputs especially zone 2.
If you can remove all speaker wires and turn the unit back on. If it stays on, turn the volume down on the main zone and zone 2 if connected. Then reconnect speaker wires.
Nov 16, 2009 | Denon AVR-485 Receiver
What does it mean when the red protection light illuminates
Hi the protection light comes on when there is a problem within the amps. circuitry. Generally speaking the protection light normally comes on when powered up while the amp checks all of its voltage rails so that they all lie within a specific tolerance, when all have been verified to be in spec. then the protect light goes out & the power light comes on. If the protect light stays on then a fault exists within it's circuitry. Cheers, acbva.
Nov 14, 2009 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
A yellow circular arrow warning light has come on. What is it?
A yellow light containing an exclamation mark surrounded by a triangle, all surrounded by a curved arrow is the Automatic Stability Control warning light (ASC + Traction Control). If the light just flashes momentarily whilst driving it means that you have driven in a way that has triggered the ASC system to activate and protect you. If the light is on all the time it can mean that you have switched the system off. The switch for the ASC is one of the row of chrome switches just under the airconditioning controls. If you operate the switch and the light stays on, you have a faulty ASC system. OK to drive the car but be aware that the stability control will not save you from a skid. Have it looked at if you can't get the light to stay off.
Normal operation: Light on when you turn on the ignition, should go out after engine starts. Light flashes if you are driving hard on a slippery surface and the system is acting to stabilise the car.
Faulty: Light on all the time measn either you have turned the system off or there is a fault.
Oct 28, 2009 | 2002 Mini Cooper
Mxa422 protection
Outputs are fried. Try disconnecting your speakers and see if it still goes into protection mode. If it does then you A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
May 24, 2009 | Lanzar MXA422 Car Audio Amplifier
2002 Grand Prix Temp Light On Engine In Protection Mode
Replace the temp sensor/switch located on the radiator.  Don't forget to drain your radiator and use teflon tape on the sensor when installing it.  DO NOT over-tighten.
Mar 23, 2009 | 1995 Pontiac Grand Prix
Hi i am matt
If the protection LED lights only after the remote voltage is applied (head unit is switched on), the amplifier likely has shorted output transistors. If the protection LED remains lit without remote voltage applied, the amp may have other problems.
Does the protection LED light with no speaker wires connected to the amp and no RCAs plugged into the amp?
Jun 22, 2008 | Car Audio & Video
SCREEN WILL NOT COME ON
Could be a few things. Bad bulb? Just like anything, some are just not made correctly. Could be the ballast that powers the light, or you may have a component on any board that is failing causing it to go into a protection mode.
Apr 02, 2008 | Akai PT46DL10 46" HDTV-Ready Television
Amp staying in protection mode
No, this amp is not a heavy power consumer- matter of fact it takes very little power to run.Maybe you should check the fuses on the amp to see if they are what is recommended.Also check your fuse kit to your amp- your fuse might not be big enough.If neither works take it back where u got it.
Jan 01, 2007 | Soundstream XTA880.2 Car Audio Amplifier
112 people viewed this question
 Grubhead
Grubhead
