Question about Belling 24 in. IDW603 Built-in Dishwasher
Salt inlet is full of water
Where I am meant to put the salt is full up with water which overflows when I add the salt.
Do you need to put salt in the dishwasher. If using tablets detergent ...where to put it ?
A lot of dishwashers do not have salt dispensers. If it does, the salt is added to a container which has a lid on the base (floor) on the inside under the bottom basket. Unscrew the lid and add the salt. Use normal pool salt. It is the same as "special dishwasher salt" that you pay a lot for. When full, the salt will last for 12 to 18 months. Most machines that have a salt container, also have a warning light on the panel to let you know it needs refilling. Dishwasher tablets do not add salt to the machine. Make sure you wipe up any salt that you may have spilt on the base of the machine, it will stain or rust the cabinet.
Sep 25, 2014 | Dishwashers
Where do i put the salt
Hello Maria,
The salt goes in the salt compartment in the base of the washing compartment. Unscrew the lid of the salt compartment (counter-clockwise), pour in salt until the compatment is full or nearly full then screw the lid back on firmly, but do not overtighten it.
If the dishwasher is new and you are using it for the first time, pour about 1 litre of cold clean water into the salt compartment before adding the salt. If you spill any salt or the water spills over the top of the salt compartment, it will wash/drain away the next time you use the washer.
The most important thing is to only use dishwasher salt. The salt is used for water-softening and only salt sold specifically for dishwashers can be used for this purpose.
The picture above is from a Bosch dishwasher. You may have another brand or model of dishwasher, but the salt compartment will still be in the base of the washing compartment and will have a cap which you unscrew as above.
Hope this helps. If you need further assistance, please let me know the brand and model number of your dishwasher.
Regards,
BElectric
Mar 14, 2011 | Dishwashers
Lost directions for using my Sisan Steamer. I have the water measure but don't know how much salt to add. Can you help?
The measuring cup holds 1/4 cup. Fill with tap water and pour one full measure into the hole exposed by removal of handle. Then measure table salt into small hollow on handle. Next, pour two (2) full measures of salt into a second measuring cup full of water, and pour into Sisan. Never use more salt than will fill the measuring hollow in handle. Remember that should the steam cease, unplug and refill with two measures of tap water, but no more salt.
Maintenance:
Add one (1) teaspoon white vinegar to two measures of tap water, put it in the Sisan Steamer and let it run a few minutes. Then pour this out of the Steamer and rinse well to scale the inside.
Nov 17, 2010 | Kitchen Appliances - Others
My new dishwasher leaves a white residue on my pots. pans and stainless flatware. I have not changed soap. Could the water not be hot enough?
Check the incoming water quality. If water is hard and having calcium content this could happen. Use water softeners in the inlet water to the machine.
If dish washer salt compartment available fill with the special salt meant for dish washers.
Check rinse aid compartment and fill rinse aid. Or use two in one soap tablet.
Sep 19, 2010 | Whirlpool Dishwashers
Dishwasher is showing low dishwasher salt soon after putting dishwasher salt. why?
Do not bother. Continue using the m/c. If the inlet water quality is good do not worry. This is a sensor sensing fault, even if the salt is fully loaded.
If the wash quality is good without salt continue.
Otherwise add salt at regular intervals. Trying to fix this fault will lead to another and so on. Now machine works for you continue enjoying!
Sep 16, 2010 | Indesit 24 in. D63 Free-standing...
Is there any chemicals I need to add to my pool when I leave it up and full of water for the winter. I am worried about the alge growth. when I stop treating the water . on my salt water system.
If you have the intex soft side pool do not leave it up.
Once the water freezes and thaws you take a big risk of gouging the pool and thus tearing it.
These pools are meant to be taken down every year if you live in a freeze area
Aug 23, 2010 | Intex Automatic Salt Water System for ...
My Dishwasher leaves a white film on dishes.
check inlet water quality. If more calcium deposits in the water this could happen. Try using water water softeners.
If provision for dish washer salt check and add salt. ( not kitchen salt )
Finally check whether rinse aid compartment is filled with the liquid. If you are tablet, extra rinse aid not needed. Try all the above.
Aug 17, 2010 | Whirlpool Dishwashers
Dishes seem to have a powery residue on them after they're clean
Check inlet water quality for hardness. If salt chamber is provided, fill the chamber with salt meant for washing machine.
Use the recommended wash soap.
Check rinse aid and fill if required.
Jul 20, 2010 | GE 24 in. GLD5560LSS Stainless Steel...
Dishwasher powder
Check inlet water quality. It's hardness level. Use salt meant for dish washers. There will be a salt fill compartment. Refer user guide.
Finally check whether the rinse aid dispenser has liquid for dispensing.
May 26, 2010 | Dishwashers
Siemens Lady 45 Dishwasher - Starup and Water problem
try unblocking the inlet hose under the machine.. My machine was overflowing inlet water into the tray under the machine setting off the above mentioned aquastopper switch. I removed side pannel, then one end of the inlet hose under the machine and dragged a wire with cloth tied to end through, removing a serious amount of built up scum. no more overflowing!!
Mar 13, 2009 | Dishwashers
Belling 24 in. IDW603 Built-in Dishwasher Logo
Top Belling Dishwashers Experts
Kamil Owsianiecki
Level 1 Expert
Oloyede Monsuru
Are you a Belling Dishwasher Expert? Answer questions, earn points and help others
