Question about Gateway Recertified - ZX4250G-UW308-FB-R 20" All-in-One PC Windows 8
Zx4250g hard drive replacement - Gateway Recertified - ZX4250G-UW308-FB-R 20" All-in-One PC Windows 8
Where can I get a screen for my all in one Gateway ZX4250G-UW308 20
Ebay will direct you to some. Search for your model and screen.
eBayeBay
Aug 16, 2015 | Gateway Computers & Internet
How do i disassemble gateway
here ya go , i would strongly suggest you send to a repair shop but....
Aug 09, 2014 | Gateway ZX4250G-UW308 20" Fusion Dual-Core...
No sound on my gateway zx4250g
try to reinstall audio driver
https://support.gateway.com/product/default.aspx?modelId=4567
Dec 17, 2013 | Gateway ZX4250-UR10P
Replace hard drive motherboard
Before you start replacing drive you need to ask yourself if you are trying to replace a bad hard drive and just want to start with a clean install of the O.S. OR are you replacing your hard drive with a bigger one and wish to keep your installed programs, data and documents. If you want to keep your data and documents you need to know how to save the Files and folders on your computer to a CD, DVD or a USB hard drive. Just replacing the hardware involves unplugging all cables from computer after shutting it down. Then opening the case and unplugging the cables from the hard drive and then remove the screw(s) retaining the hard drive. Remove the old hard drive from the case and replace it with the new one, replace screws and plug cables back up watching that that the connectors are correctly aligned with the key(s) on the hard drive's sockets. Replacing the Hard drive also involves installing the O.S. and all your programs and applications on the new hard drive. You can find a lot of information in the internet about this.
Oct 21, 2013 | Gateway SX2855 Case
How would you hook up a printer to this computer since there is no cd drive for the software disc? Are there any printers compatible with this unit?
I often download and install software from my hard drive. Go to the manufacturers site to get the software. I only use HP printers and can get software for almost anything from them.
Oct 17, 2013 | Gateway Recertified - ZX4250G-UW308-FB-R...
MY COMPUTER IS INFECTED WITH A WORM AND TROJAN AND IT WONT LET ME DO ANYTHING IT SAYS EVERYTHING IS INFECTED LIKE MY SYSTEM RECOVERY I CANT GET ON THE INTERNET I DONT KNOW WHAT ELSE TO DO I HAVE DONE SPENT...
If you have access to another computer download this and burn it on a CD Disk. On the same page go to the Frequent Questions tab to see some things. If this helped you let me know.
Jun 29, 2013 | Gateway Recertified - ZX4250G-UW308-FB-R...
Can i replace the default hard drive with any brand hard drive?
Well the replacement drive should be the same interface. i.e. if its an IDE drive then you'll need an IDE drive if its a SATA drive you'll need a SATA drive! regards, babb
May 07, 2007 | LaCie (300773) 1638.4 GB Hard Drive
Gateway Recertified - ZX4250G-UW308-FB-R 20" All-in-One PC Windows 8 Logo
207 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
