Question about Cell Phones
Screen is dark samsung s4 mini
My screen is dark for s4 mini even after charging all night
MY TABLET WILL NOT EVEN ON. THOUGHT IT NEEDED CHARGING BUT WHEN CHARGING IT DOESN'T EVEN INDICATE ON THE SCREEN THE BATTERY ICON
Have you tried a second charger and or charging cable?
It is also possible that the micro USB connector could be damaged? You could try gently wriggling the port when the charging cable is plugged in? do you get any result?
May 06, 2016 | Samsung GALAXY S4
Screen has done dark. Appears phone is on as it buzzes
could be a blown screen/ digitizer, take to your service provider for confirmation.
Oct 12, 2015 | Samsung Galaxy S4 Mini
How do I unlock galaxy s4 mini sch-r890?
Try this link: http://www.android.gs/how-to-sim-unlock-samsung-galaxy-s4-for-free/
Aug 27, 2015 | Samsung Galaxy S4 Mini
How do I answer my s4 mini mobile phone
Every smartphone I've seen has a a button or a on-screen slide button when someone calls you. Does your display not change when someone calls you?
Aug 17, 2014 | Samsung Galaxy S4 Mini / GT-i9192 Black...
Samsung turns off
It's faulty, buy an iPhone. You are not alone
How to fix Samsung Galaxy S4 that keeps turning off on its own ...
https://thedroidguy.com > Mailbag
Aug 24, 2015 - We received several emails from Samsung Galaxy S4 (#Samsung #GalaxyS4) owners whose phones are randomly rebooting. It may be ...
Fixing The Samsung Galaxy S4 Turns Off Does Not Turn Back On Issue
https://thedroidguy.com > Mailbag Jan 24, 2016 - The #Samsung Galaxy #S4 has established itself as one of the most dependable smartphones available in the market today. This device which ...
Samsung Galaxy S4 Randomly Shuts Down Issue & Other Related ...
https://thedroidguy.com > Mailbag Jan 10, 2016 - My Samsung s4 mini was switched off during an update and will not switch on now. ... Reinsert just the battery then check if the phone turns on.
samsung galaxy s4 turns off but still has 30% battery life ...
https://forums.androidcentral.com/samsung-galaxy-s4/303065-samsung-galaxy-s4-tur... Oct 12, 2016 - 25 posts - ‎22 authors
My s4 turns off at 30% battery life! ... note that, yesterday after the phone turned off by itself by showing battery critically low (in reality it had over ... Galaxy S4 shuts down randomly
8 Jan 2017
Galaxy S4: HELP with Hands Free
17 Dec 2016
Galaxy S4 Turns Off by itself sometimes
14 Apr 2016
S4 won't turn on unless replacing battery, then turns off ...
17 Jul 2014
More results from forums.androidcentral.com
Fix Randomly Shut Off Samsung Galaxy S4 Active Issue ' Technobezz
https://www.technobezz.com > Tech -How To's > Android Fix Randomly Shut Off Samsung Galaxy S4 Active Issue ... the battery. Now turn on the device to see if the sudden shut-off or reboot issue is resolved then. Samsung s4 mini turns itself off Google Search
Oct 28, 2017 | Samsung Galaxy S4 Mini Duos GT-I9192...
Why will my samsung galaxy s4 not connect to the charger - the socket seems to have dropped
REASONS OF SAMSUNG GALAXY S4 NOT CHARGING- GREY BATTERY PROBLEM
The main reason of Samsung Galaxy S4 not charging- grey battery problem is a shorted charging port. There may be several reasons for it such as sometimes dust entered into the charging port and causes this problem. Sometimes the bar across the center of the charging port gets bent.
SOLUTIONS TO FIX SAMSUNG GALAXY S4 NOT CHARGING- GREY BATTERY PROBLEM
Method 1
If your Galaxy S4 falls and you start to face Samsung Galaxy S4 not charging- grey battery problem, then take a pointed wooden toothpick, a magnifying glass and a strong light and see carefully if any bar across the center of the charging port is in the center and not bent to touch one of the sides of the shell. If you find that it is bent then straight it using the toothpick point carefully.
Method 2
Look for the dirt into the charging port that it may pick up from anywhere. Take a thin needle and gently insert it in the charging port to take out the large piece of dirt from it. But you have to be very careful so that you do not make any damages of the charging port. You can do this by using a can of compressed air or dust/hair blower that will blow out the small dust particles from your phone's charging port.
Method 3
Some users reported that they have found solution of the Samsung Galaxy S4 not charging- grey battery problem by taking out the battery from the phone , insert it into another Samsung Galaxy S4 ,and then again put it in back.
So follow these steps to get rid of Samsung Galaxy S4 not charging- grey battery issue.
Apr 25, 2014 | Samsung Cell Phones
Pls can I get a users manual s4 mini gt 19192 dual
Download the manual here: http://www.samsung.com/latin_en/support/model/GT-I9192ZWLTPA-downloads
GALAXY S4 Mini Duos
Apr 02, 2014 | Samsung Galaxy S4 Mini Gt-i9192 Black Gsm...
Lycamobile simnetwork unlock pin
How do i found my puk code number lycamobile
Feb 16, 2014 | Samsung Galaxy S4 Mini
Cell Phones Logo
13 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
