Question about ASUS Computers & Internet
How can i connect my asus vga to hdmi tv
Vga port
Benimur
  • 6966 Answers
SOURCE: ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Posted on Jul 31, 2007
SOURCE: ilo 27inch hdmi hd tv monitor
You would need to connect a VGA + Audio to HDMI Converter. The downsize it the converter goes for about $150 us
Posted on Apr 12, 2008
  • 124 Answers
SOURCE: VGA port connection to old style TV
Right click an empty spot on your desktop, select properties. Click the Settings tab. Right click the gray-ed out monitor, select enable.
To push the image to that screen, press the Function (FN) key and F4 normally.
Posted on Feb 16, 2009
cheap to fix
  • 404 Answers
SOURCE: play laptop video on tv
yes vga plays hd video. but an hdmi cable is better. get a VGA to HDMI cable
Posted on Jul 20, 2009
  • 64 Answers
SOURCE: cant connect asus computer to tv via hdmi
Try turning both pc and tv off and connect, then turn both on. Also, make sure your Display setting are correctly configured. Goto Control Panel, Display and click on Settings Tab. If your still having trouble. Try changing your resolution and make sure that you have your TV to the right input. My TV has 4 HDMI 3 RCA 2Component 1 Digital Optical many USBs...can get kinda confusing. The connection should be numbered. Switch inputs with your remote til you get the right port. Then work on getting your pc to display correctly. Set your aspect ration to 16:9 first. Most tv and laptops are set this way. GOOD LUCK let me know how it goes.
Posted on Sep 12, 2009
Guys, Recently i got LG 22" LCD TV. It has VGA port and HDMI port. When i connected my CPU cable toLCD via VGA port it didn't show anything, :"( i checked input MENU on remote then it shows only 4...
HDMI [High Definition Multimedia Interface]. VGA [Video Graphics Array]. AV [Audio Video]. By these definitions itself talk to you about the inputs your TV have; and it do not support VGA. Output from PC is VGA. Without a VGA input with the TV, you can't connect the PC to TV. I think I'm clear. http://electronicshelponline.blogspot.com/
Jul 09, 2014 | Televison & Video
Technika tv
connect by using VGA-port or HDMI-port. Press the Fn-key + F8 to switch between the lcd's.
Sep 06, 2013 | ASUS Computers & Internet
Can I connect my Asus Eee PC 1015PE to my HDMI tv (tv does NOT have VGA port)?
Maybe. You could try a USB to HDMI adapter, like this: http://sewelldirect.com/articles/USB-to-HDMI.aspx . These are fine for some uses but not generally for gaming. I'm not sure this works with Win7 Starter (due to driver issues).
Another option is a VGA to HDMI (analog to digital) converter. An example is http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10114&cs_id=1011404&p_id=6191&seq=1&format=2#description . Note: the VGA output is a 480 (SD) signal; some issues may occur. Also you need to make sure that the refresh rate for the computer is set to 60Hz. (On some ultrabooks, the VGA port is disabled for power-savings. In that case, you may need to enable it in the BIOS as well as setting the video output.) Then the TV will be the only monitor while it is connected to the Ultrabook.
The only issue you may have is with the TV. Not all TVs with HDMI ports read the signal from a computer. The converter gives the signal for TVs. I'm not sure about the output signal from the USB device. (If the port is labeled HDMI/DVI, it is more likely to support a computer's signal.) There are also VGA to component video or composite video converters that will do similar signal modifications. These don't have the HDMI issue. (Make sure you don't get a VGA to component cable; these are for projectors that can talk to computers.)
I hope this helps.
May 08, 2013 | Computers & Internet
Element tv wont see laptop
Connecting laptop VGA port to HDMI port on a TV
VGA to HDMI converter is required to connect a laptop to a TV with HDMI input. The VGA signal does not have an audio component. You need to connect an audio cable from the audio/headphone port on your laptop to the audio connector on your TV. There are HDMI converters with Audio input so you do not need to connect an audio cable to the TV. The audio is connected to the HDMI converter and then passes the audio with the video data to the HDMI cable to HDMI port on the TV. Check out these WEB site for these HDMI converters. http://www.aten.com/products/productItem.php?model_no=vc180 http://www.sybausa.com/productInfo.php?iid=1174 http://www.topbuy.com.au/tbcart/pc/Audio-VGA-to-HDMI-Video-Converter-Box-HD-HDTV1080P-p164633.htm
Mar 14, 2013 | HP Pavilion Computers & Internet
Can i plug a tv to asus a3000 laptop
That machine has a VGA port. If your TV has an HDMI port then you can get an adapter. If your TV has a VGA port then just a cable will work.
Jan 26, 2013 | Computers & Internet
What kind of wire do I need to connect my samsung laptop to panasonic viera hd 3d plasma tv?
Most TVs will have HDMI and RCA component and composite jacks. Some TVs will also have a VGA port. Your laptop will have a VGA port. (If the laptop is fairly new, it may also have an HDMI port.)
Not all TVs will support an HDMI signal from a computer, so the VGA signal is often better. However, that limits you to SD (anything with HDCP will fail.)
Very few TVs ship with the HDMI or component cables. However, there are some vendors who do package the HDMI cable with their TV. Without knowing which exact model of TV and laptop, I can only make a few suggestions. I know that the TCP42ST30 (Plasma 42") doesn't have a VGA port.
Look at your laptop for any external monitor port. VGA ports are generally blue female ports with 15 holes (D-Sub). If your TV has a matching VGA port, get a standard VGA monitor cable.
If you have the VGA port on the laptop but not on the TV, you can try a converting from VGA to HDMI. (You may need a DVI to VGA adapter and either a DVI to HDMI cable or a DVI to HDMI adapter.) Note: this gives an analog signal (RGB format) to the TV. You'll also need to make sure that your VGA port is active (in the BIOS for some computers) and then set your computer to send the signal to the external monitor. It is best to turn off both the computer and the TV before connecting the two. Then turn on the TV and set it to the correct input before turning on the computer. (In Windows 7, I set the video signal for the external monitor by right clicking on the desktop and selecting Graphics Properties. Set the signal to the external monitor and click Apply. Then click OK (in the external monitor's screen).)
If this doesn't work, you need a VGA to component video converter. (Not a VGA to component video cable - those are for projectors that read the RGB signal.) See http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215-p1.html .
Some laptops come with an HDMI, mini-HDMI or a DisplayPort option. For the latter two, you will need the appropriate cable with that end and the HDMI connector on the other. Then connect the TV and the computer as described above. (Note: my TVs accept a computer signal at the HDMI port labeled HDMI/DVI. However, you need to make sure that your TV understands this signal. It isn't the same format as that from a set-top box. My laptop has VGA and HDMI out; the desktops have VGA, DVI and HDMI (on one).)
If you add a comment with the model of your TV and laptop, I'll be glad to give you more specific options to connect the TV and the computer.
I hope this helps.
(A DVI port is a digital video out option with ~21 pins and is usually white.)
Feb 03, 2012 | Panasonic VIERA Televison & Video
Link ASUS laptop to Sharp Aquos LCD TV
No, a DVI to VGA adapter will not work. (The TV is looking for the digital signal from a set top box. This is different from the analog signal on the VGA cable.) You need a converter. Your best bet would be a VGA to component video converter. (I am assuming that the Sharp TV has a component video input.) This page has some examples: http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215.html?sorter=productname-en-asc . Note a VGA to component video cable will not work. The VGA to component cables are for projectors that read the RGB signal. The component video signal is YPbPr.
Connect the VGA cable to the converter and the component video cable to the TV and the converter with the computer and TV off. Turn on the TV first and set it to the component video input and then turn on the computer. Then (assuming the VGA port is enabled - adjust in the BIOS if needed) set the computer's video output to the VGA port. (On my Windows 7 laptop, this can be done by right-clicking on the desktop. Choose Graphics Properties and set the display to the external monitor or both. Click Apply and then confirm the change (on the external monitor if using the single monitor). (VGA to Composite video converters also exist if you do not have an available component video input on your TV.)
If your computer is fairly new, you may have an HDMI port. Your TV may be able to read the signal with a DVI to HDMI cable. (It depends on the TV. Not all of them will read the computer's signal on the DVI port. Check the documentation for your model. TVs without a VGA port are less likely to support this feature.)
I hope this helps.
Nov 28, 2011 | Televison & Video
When connected to my Philips 47PFL7422 tv via HDMI cable I get video but no audio. When connected via the VGA port I get both audio and video,
The VGA cable is strictly just for video so the sound is received thru an analogue (RCA) cable. HDMI is an combined digital link but the video card delivers only the video - you must tell the tv from where to get the sound (use the analogue connection already in place) This is done in the menu.
Mar 20, 2011 | ASUS ATI RADEON HD 5450PCI EXPRESS21DDR3...
What do I need and how do I connect my Toshiba L305 model PSLB8 050302f to my hdtv to view online tv?
I dont believe that laptop has an HDMI port on it. If you have an LCD TV then your TV may have a VGA or DVI input on it. You can connect your laptop to the TV by using a VGA to VGA or VGA to DVI cable. If you your TV doesn't have one of these input ports, then you're not going to get your laptop connected to your TV.
Mar 03, 2011 | Toshiba Satellite Pro L300 Notebook
How do i connect my adventt9101 to my sony lcd tv, i want to use hdmi leads but i dont think my pc has hdmi port? any help
If you don't have an HDMI connection on your computer, then you will need to get a VGA cable. There should be a VGA connection on your tv. Just disconnect the monitor on your computer and connect the VGA cable from the computer monitor port to the VGA port on the tv. You may have to set the tv for PC or Aux input. You won't have high definition or sound to the tv with a VGA cable though. The sound will still come through your PC speakers.
Jun 25, 2010 | Computers & Internet
Computers & Internet Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
