Question about Konica Minolta Konica Bizhub C353 Imaging Unit Black IU313K
First we put on the screen apear an error then we put off and on the screen became black
Electric current is available the screen black
  • Konica Minolta Master
  • 6,674 Answers
What error
Posted on Mar 12, 2017
Hisense Codes
Try opening internet explorer and going to www.google.com
If this also produces an error, go to START -> Type "CMD" in the search box and hit ENTER
A black box will apear.
Type "ping www.google.com"
If it comes back with errors, it is your internet connection. You can be connected to your home network whilst your internet is not working.
Are you on windows 7?
If so try this:
There should be a network icon at the bottom right of your screen, a computer icon. Right click it, select "open network and sharing center"
You should have a network that says LOCAL AREA CONNECTION. Select this.
Click on DETAILS...
You should have an IPv4 Address that looks similar to "192.168.1.3"
Write down this address.
Close the current screen. You should be on the LOCAL AREA CONNECTION STATUS screen again.
Click PROPERTIES.
Double click the INTERNET PROCOTOL VERSION 4
Select USE THE FOLLOWING IP ADDRESS:
Now remember that IPv4 address i told you to remember? Well put that down in the IPADDRESS field, except add +15 to the number.
Eg. original: 192.168.1.3
Make it: 192.168.1.45
Subnet should be: 255.255.255.0
Default gateway should be the same as your IP but with a 1 at the end.
EG: 192.168.1.1
As for the DNS - Log in to your router/modem and in the summary or overview section it should list the primary and secondary DNS ip addresses, find them and fill in the remaining 2 boxes.
That's it, you're done. Enjoy your internet.
Oct 24, 2013 | Tablets & eReaders
I have loaded a colour cartridge a and a black cartridge into my 8450 printer and now all I get is the 05f37c2b error code apear on the screen
Please try the following:
Remove the cartridges that you just replaced. Ensure that they are compatible with your HP 8450 printer. Make sure that none of the electrical contacts on the printer or cartridges are damaged and that there is no obstruction in the cartridge port. Turn printer main power off, and then back on with the cover closed. If the error code is now gone, open the cover and install the new cartridges as described in the manual. Also, did you remove the protective nozzle covers from the cartridges?
Good luck,
GaugeMan
Mar 06, 2011 | HP Photosmart 8450 InkJet Printer
Black Screen in start up evern in Safe Mode a black screen apears! Dell Inspiron 1525. OS-Windows Xp
This error means that the OS need to re reinstalled............ Use the following link to reinstall the OS and the drivers very easily
http://findtechhelp12.blogspot.com/2010/11/how-to-reinstall-os-in-dell-computer.html
Nov 25, 2010 | Dell Computers & Internet
My 32 lcd tv a black rectangle apears on aprox,
If it is a large black rectangle that blots out the middle of the screen then you need to check your CC (closed caption) setting. Make sure the closed caption is turned off. I'm not up to date on the newer sets, but a lot of the older ones had more than one CC setting. One setting ran the captioning across the bottom, another put it in a big black box in the center of the screen. Most places didn't support the full text so all that showed was a big black rectangle on the screen. Since I'm not sure exactly what your rectangle looks like, this is my best estimate of your problem. Hope this helps.
Jan 01, 2010 | Polaroid Televison & Video
Mitsubishi CS 40503, black box in center of screen, takes up 90
check on the remote control for the function text maybe by mistake you put it on
Mar 14, 2009 | Mitsubishi CS-40503 TV
0701 usb over current on hc/port error
I had the same problem on a toshiba satellite u400.
Usb over current on port ... blabla..
Please press F1 to resume or F12 to install.
F1 just ended up in a screen asking to press F2 or F12 which did nothing.
F12 did nothing.
Rebooting the pc ended in a black screen with a flickering HD symbol.
To be able to boot again on the BIOS I had to remove the battery and disconnect the plug.
Once It restarted booting on the error USB over current.
Si I took a USB mouse and tried to boot with the mouse plugged in on port , then another ... at the third port the PC booted normally with no error :)
Don't have any idea why it became faulty but it's now solved for me.
Mar 12, 2009 | Toshiba Satellite A135-S4527 Notebook
Samsung dlp hl-r5064w
there is actually a what is called light tunnel recall on the sets that develop that samsung is also willing depending how much youve spent on repairs and have this problem documented where they will offer an upgrade and depreciate the current tv if thats what you want
Jun 04, 2008 | Samsung HLM617W 61" Rear Projection...
Samsung plano tv
The problem that is happening is due to the shutdown circuit activating, which is an indication of excessive current flow. This may indicate a problem in the High Voltage section or in the power supply feed from the HV section. In any case this problem is best dealt with by a trained professional. I would suggest that you take the TV to a qualified TV repair person and have them check it out.
I hope this helps
Thank you,
Shuttle83
Dec 04, 2007 | Samsung WS32Z308P 32" TV
Konica Minolta Konica Bizhub C353 Imaging Unit Black IU313K Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
