Question about Blenders
Farberware blender parts
Silicone gasket for farberware 104558 blender sold at walmart
Farberware 103742. Where can I get replacement blades?
Check with a local appliance parts supplier.
Feb 13, 2016 | Blenders
What kind of lids can I get
To see what lids may be available, go to the manufacturer's website and look under Customer Service or Parts.
Feb 09, 2016 | Blenders
I need 0914084 Blender Sealing Ring Diameter 2 1/16"or its substitute.
Unfortunately that gasket, part number MS-0914084, has been discontinued.
Here is a link to the part online: Seal MS 0914084 for Krups Appliance eReplacement Parts
Unfortunately the gasket is obsolete, and there are no known replacements. The gasket is very perticular and i do not know of any other gaskets that have a similar shape.
-Colleen@MendingShed
Apr 02, 2015 | Krups 572 Power Xtreme VI Work Top Blender
Blender is leaking
As we all know that blender is an electronic device from which you may face some problems while using it. One of the main problems is leakage, the neckline and gasket are the first problems that will give some inconvenience to you, it is a most critical part of your blender because they keep it sealed or water tight. I would suggest you the Best Blender Under 100 which is on your budget also.
Sep 18, 2013 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Sunbeam 2774 Blender Logo Problem with the Sunbeam 2774 Blender I need a gasket for my sunbeam blender #2774.
The gasket is not available by itself, you need the blade assembly part number 123250-000-000 available from Sunbeam at 1-800-458-8407.
Aug 13, 2011 | Sunbeam 2774 Blender
Where can I get replacement blade unit for Farberware/Salton blender model FBL500SS??
Available replacement parts for your blender are normally available online at the following site:
http://www.directpartsandproducts.com/blenders-fbl500ss-c-61_171_884_885_888.html
Unfortunately I do not see that a blade unit is available. I would recommend you contact this supplier directly to inquire whether a compatible blade is available.
Contact information can be found here:
http://www.directpartsandproducts.com/contact_us.php
Trust this is helpful. Thank you for using FixYa!
Jul 12, 2011 | Salton FBL500SS 3-Speed Blender
I have a new KA blender. After washing I am not able to get the pitcher back into the locking collar to allow the couplers to fully engage. I have done it several times and it is just not working. I...
Please make sure the collar is on a firm flat surface (not on the blender). Check the silicon gasket is evenly placed in its groove in the middle of the collar. Lower the glass jar onto the collar lining up the gaps on the collar with the glass keys on the side of the jar. Holding the collar in one hand, twist the glass jar clockwise to lock into place. If this doesn't work it sounds like something is jamming the mechanism underneath.
Apr 05, 2011 | KitchenAid KSB560 5 Speed Blender
GE single serve blender 898679--need replacement plastic gasket for grinding jar. I am told by Walmart, where I purchased it, that I need to return it. I don't want to return it. The blade chewed up the...
I had the same issue. i took the gasket from the other blade to use with the blade i use everyday. one trick is, don't remove that gasket to clean it but make sure it stays in there. Just soak it and scrub it good, to make sure it stays seated in there.
If the gasket comes loose while you are grinding, the lid will come loose in the base and sometimes causes you to not be able to get the jar from the base. you have to turn the jar the opposite direction to get the lid to tighten up, then you can remove the jar from the base.
I am trying to get replacement jars since those plastic nobbies that run the blender have broken off. It is down to one of 3 nobbies, so it can't be run anymore. I mght just have to buy a brand new blender but it seems so wasteful.
Mar 15, 2011 | GE Blenders
KitchenAid Blender Model KSB560GC0. Coupling is ruined. Looks to be a geared part at the base of the unit. [ top of motor ] Also there is a part that is geared at the bottom of the pitcher, attached to...
the older glass jar blenders were sold as a complete ***'y too.
no separate parts were available. i'm sure the stainless jars are sold in the same way...complete.
Jun 24, 2010 | KitchenAid KSB5 Professional Stainless...
I followed the link to purchase a rubber gasket for my blender. The item is $2, weighs less than an ounce, but the shipping charges are over $10 from Utah to California. Something wrong here.
I called the place.. and the lady sold me 2 Gaskets.. for $2 and only charged me $4 for shipping.. Much better rate.. We love our smoothie machine.. but when you cant find decent replacement parts.. its really dis-heartning.
Jan 09, 2009 | Back to Basics 600 Smoothie Plus Work Top...
Blenders Logo
67 people viewed this question
Top Blenders Experts
eyecam
Ross Keen
Are you a Blender Expert? Answer questions, earn points and help others
