Question about Panasonic Lands Phones
How to use intercom - Panasonic Lands Phones
Uniden dect 6 0 manual
Try pressing the intercom button (base) above the number 1, on the handset the intercom button is below the # button.
Intercom?
Whenever the phone is in standby, you can make an intercom call
between stations without using the phone line.
You can make an intercom call from any station, but only two stations
can be in an intercom call at any time.
If an outside call comes in during an intercom page, the phone cancels
the page so you can answer the incoming call.
?f an outside call comes in during an intercom page, the phone cancels the page so you can answer the incoming call.
If an outside call comes in during an intercom call, press
speaker on the base or talk/flash on the handset to hang up the intercom call and
answer the outside call
see page 15/16 of the manual at the link below.
http://www.uniden.com/pdf/D1688-2om.pdf
Sep 03, 2014 | Uniden D1688-2 Dect 6.0 1 Corded 2...
M&s intercom model 200 manual
Here is a link for the manual.
NuTone NM200 4 Room Intercom Kit NM200 4 Room Intercom Kit
Please visit our website if you need a replacement part or if you have more questions.
Central Vacuum Intercom and Whole House Audio Systems
Don't forget to like and visit our Facebook page
https://www.facebook.com/QualityHomeSystems/?ref=hl
Aug 16, 2014 | Radio Communications
How does one use the intercom
To Page another phone to initiate intercom:-
From the base station - press Find hs/Intercom.
From a handset - Press Intercom/clear.
Then select the station you want to talk with or All to
page all stations at the same time.
To answer a page:-
From the base station - press Find hs /Intercom or Speaker.
From a handset - press Intercom/clear or Talk/Flash.
Hope this helps
Ive also included a link to the D1785 Series User's Guide
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1785om.pdf
Feb 01, 2014 | Uniden D1785-3t Dect 6.0 Cordless Phone...
Intercom does not work
There needs to be an additional instruction. I am having the same problem. From standby mode, I press Intercom, the screen says "Please wait" for 2-3 seconds, then I choose a handset. Nothing happens. The user guide doesn't have any additional instructions after this point. I don't hear any paging or anything other than silence on any handset.
Jun 15, 2011 | Uniden D16602 Twin Cordless Phone
What is the "left intercom" button on the Partner Mail VS phone? I want to change time system time and don't see the "left intercom" button on my phone.
The left intercom button is the intercom button above the up volume control and to the left of the second intercom button.
Nov 02, 2009 | Lucent PARTNER18 Corded Phone
Is there a way to intercom directly onto the speaker ???
you should have 2 intercom buttons on your set, an SA ring and an SA voice. The SA voice (or voice intercom) should be the second from the bottom.
Sep 16, 2009 | Avaya MLX 5D Corded Phone
Interference in our wireless intercom
Wireless routers operate on 2.4GHz frequency. It's very possible that your intercom is in the same frequency range causing inerference. Try and find the frequency your intercoms operate on. If you can't find it on the unit, search the internet for the name brand and maybe you will find the info. If this is that case, (as I suspect it is), the only alternative I can suggest is to change your intercoms. Be sure to check the frequency of the new intercoms before purchasing. Anything but 2.4GHZ should work fine.
Feb 24, 2009 | Radio Communications
Pickup lines
From intercom 10 or 11.
Feature 00
Left intercom
Left intercom
Right intercom
Enter the extension number in question
press * *
then touch the lines in the order you want to pick up. (line 1 line 2 etc..)
press * *
Press feature 00
Sep 12, 2008 | Avaya 700340193 Corded Phone
Blocked Intercom
If you do not have a button to press to call him, you must press the intercom btn and dial his intercom # . to find his intercom # , go to his phone and dial feature 00. His intercom # will be displayed. press feature 00 to exit.
Mar 06, 2008 | Lands Phones
Lands Phones Logo
12 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
