Question about Xerox WorkCentre M20i All-In-One Laser Printer
Have a replacement power supply board for my Xerox m20i multifunction copier and need the step by step process to remove the bad board & install the new one.
  • 3,230 Answers
1) check any fuser damage on the board use a meter and check any component short or damage as possible, if you can not repair it
2) buy a new parts to replace it.
this part comes with the replacement help.
Good Luck
Thanks
Posted on Jun 14, 2009
Re: M20i Power Supply Replacement
You need to contact the manufacturer for the correct part, Fixya doesn't have parts or any way to look them up. Sorry.
Feb 06, 2012 | Xerox WorkCentre M20i All-In-One Laser...
Xerox M20i workcenter will not turn on
Try plugging the printer in to a different outlet and it if it is still not turning on at all you need to replace the power supply. Part# 140N62859 for 110V version or part# 140N62860 in the UK or other places that use 220V. iteminc.com has these in stock and can ship same day. Good luck, hope this helps
Jul 01, 2011 | Xerox WorkCentre M20i All-In-One Laser...
-Xerox workcentre m20i. -Yesterday turned machine
hi enviro,
so its the supply inside the Xerox is the next to be checked or fuse too..a technician nearest you can help open it.
mastergani
Jan 21, 2011 | Xerox WorkCentre M20 Black and White...
The fax shows a messages saying "open heat error"
On this machine, you may have a fuser assembly that is bad. Replace the fuser modual.
If this doesnt work, then the main board needs to be replaced.
Also what most people forget is the fuser fan. Sometimes it turns slow and you will not even notice it. It might not even turn at all.
Replacing the fan will solve most problems, but if it still does not turn on, Look on there to see if it has a small circuit board on the fuser fan, replace it too.
if all else fails the main board needs to be replaced.
Good luck
Jul 29, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Permanent warming up message
When you replace a power supply for this machine, it needs to be the correct power supply for this model. If you have the old one, check to make sure the right power supply was ordered for this specific model.
Because I cannot see the display, and we only know what it is saying, the next best thing would be to see if the fuser warmed up at all. Open the side door and gently feel the fuser frame to see if it is warm at all. Do not touch the Fuser roll; it is hot even to the slightest touch.
If it is not hot, make sure all the plugs were correctly plugged into the power supply.
On this problem there can be other factors that can cause warming up.
First, the fuser assembly may be defective and needs replacement.
Second the main board may be gone out.
And last if the machine has memory chips in the back, unplug the machine, remove the small cover from the back and unplug the simms chips and reseat them. Plug in the machine, then power it on.
See if the machine will go to a ready.
If not, possibly the fuser, or main board, or both. If the main board or(and) the fuser assembly is replaced,
MAKE SURE THE CORRECT PART IS INSTALLED IN THE MACHINE.
If all else fails, Place a Xerox Service Call on the machine before it gets too expensive in troubleshooting the problem with purchased parts.
Oct 22, 2009 | Xerox WorkCentre M20i All-In-One Laser...
WorkCentre M20i will not power on
Most likely on this machine the Low voltage power supply is out.
Before ordering parts, check the back of the power supply to make sure the connectors, 110 volt on the back of the plug have not slipped off. Sometimes they are not slipped on the connector very good and come off. Also, make sure the switch is good, sometimes these switches are just mechanically bad inside.
Disconnect the power and disconnect the main motor plugs, power back on the machine and see if the machine at least comes on, even with an error messege on the console. Sometimes a bad main motor will cause the main board to drain power.
Also, make sure before ordering this power supply, the correct part is ordered for this model machine.
Let us know what you find, just becareful with the power plug in the machine when working in the electrical circuits. Unplug the copier when needed.
Oct 02, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Electrical storm last night. Now no power on
you need a power supply. That is where the fuses are and you should not replace them.
The Power Supply should be replaced.
Jun 12, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Copy Problem
Since you cleand the scanner and scans are fine, the other item I seen cause that problem is the power supply.
Jan 07, 2009 | Xerox WorkCentre M20i All-In-One Laser...
M20i Power
The power supply will need to be replaced. Look up on Google a business called The Parts Drop.
Call and talk to Britt. He will have the part and at the best price.
Not hard to replace, you go to the left side of the machine, where the on off switch it and remove the cover that catches the paper. 2 Screws. Then remove 3 screws that hold on the metal cover, disconnect the connectors from the power supply, then slide the entire metal bracket out, unscrew the old power supply, install the new one, and do everything in reverse to reinstall it.
You may have to swap the on off switch from the old to the new.
Oh yes. please unplug it from the wall when replacing.
Nov 09, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Xerox workcentre m20i power off
First off try unplugging it and leaving it unpluged for 30 minutes. Not just turned off, but unplugged, then plug it back in and see if it works. There are filter capicitors in the low voltage power supply that sometimes have to sit with power removed for 30 minutes before they discharge and allow the power supply to turn on.
Sounds weird but I have seen it fix a dead machine probably 50 times or more. If that doesn't restart then you will have to replace the power supply. If that is the case let me know and I can tell you where to get it from and ho\w to replace it.
Try leaving it unpluged for 30 minutes. not less than 30 minutes.
Oct 16, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Xerox WorkCentre M20i All-In-One Laser Printer Logo
55 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
