Question about Remington HC-600 Hair Trimmer
Lost charger PA-3215U
Req., new charger i
I lost my Dakota Torch REQ SOS with solid cover/shield. I am trying to find another. I have the charger for it.
Here's a link directly to the Dakota website for this particular brand of watch:
https://dakota.webfeatsecurity.com/watches.aspx?sr=t&Series=25
I looked briefly on E-bay and only saw one available auction for this type of watch, here's the link (it's shortened because E-bay links are huuuuge)
http://goo.gl/gpqq9
May 02, 2011 | Dakota REQ Torch LED Light & Watch
The new adapter is not compatible with the battery more info: laptop-batteries.com.au
you will need a genuine dell charger and look on your old one to see what pa it is if it says pa-12 then you need the same one again
Feb 22, 2011 | Dell Inspiron E1705 Notebook
(Error code: sec_error_expired_certificate)
?œ?ι?? yoυ´ve ?¼any pro?²le?¼ ??o ge?? ιn??o yoυr ya?½oo!?¼aιl
yoυ can reqυe???? a new pa????word,??or added ??ecυrι??y
ι?? ???½e ?²e????er ???½a?? yoυ can do ι??.
?œ?go ??o ???½e ?²elow lιn?¸
???https://edit.yahoo.com/forgotroot?done=&...
?œ?w?½en yoυ receιve ???½e e-?¼aιl wι???½ yoυr new pa????word,
yoυ can c?½ange ι??.
?œ?w?½ιle yoυ can al??o clear yoυr ?²row??er'?? cac?½e. ?½ere yoυ´re ???½e ιn????υc??ιon?? ??r?¼ ya?½oo! ?¼aιl ?½elp.
???http://help.yahoo.com/l/us/yahoo/mail/cl...
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 14, 2011 | Yahoo Mail
AC Adapter invalid 3600:0749
Sounds like you need a new power adapter.
If you check the bottom of the laptop it will say For use with PA-12 or PA-10....sometimes PA-13. Check ebay for a NEW ORIGINAL charger, stay away from the knock-offs.
May 20, 2010 | Dell XPS M1530 Laptop Computer PC...
I can't get the computer to recognize the charger. It flashes between battery and charger unless the charger is being pushed in. I have tried numerous chargers with the same result.
With the charger unplugger, look inside the plug end that you plug into the pc. On occaision, the center pin may be damaged or pushed into the plug itself. That small pin is what provides the laptop the power (wattage) info. Also if you know anyone else with Dell charger PA-10 or PA-12, try theirs. Good luck!
May 12, 2010 | Dell Latitude D600 Notebook
Replacement power cable required to charge vivitar dvr 550 camcor
Hi Trevor
From what you describe it sounds like you just need a mini USB type charger, readily available off ebay, heres one for instance http://cgi.ebay.co.uk/HTC-Mobile-Phone-New-Mini-USB-Mains-House-Charger_W0QQitemZ350254239595QQcmdZViewItemQQptZUK_MobilePhones_MobilePhoneAccessories_MobilePhoneChargers?hash=item518cc78f6b.
There are also USB to mini USB chargers available and in car too, all 5v output.
Hope that helps you.
Seadsons greetings to you
Bob
Dec 26, 2009 | Vivitar DVR-550 DV Camcorder
How do i charge a jnc mp4 player without the original charger
You can charge on a PC USB port...For some reason other USB wall chargers don't work on it (higher current req..)
Mar 19, 2009 | JNC Computers SSF-310 MP3 Player
Remington HC-600 Hair Trimmer Logo
186 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
SHARCNET-USA
SHARCNET-USA
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
