Question about Xerox Phaser 6180N Laser Printer
Xerox 093-950 erroor code
Error code:369014
Sign in to your Facebook through your computer first to ensure it works. While online on your computer, go to the login screen of Facebook on your DSi/XL and check the box that says "keep me logged on" or "keep me signed in". Then sign in through your DSi/XL, exit the browser and return to the menu, then go back to the photo channel and try again.
Nov 04, 2011 | Nintendo Dsi XL
Hp t 1200 plotter erroor 41.01 code 0x10307002
Media_Axis motor malfunctioning/shut down.
Reconnect the drive motor connections. Perform the paper drive diagnostic,check media advance drive, replace PCA,,
Sep 08, 2011 | HP Designjet T1200 Large Format Color...
I forgot my security code to restore all for my nokia5130. i have tried lot but it shos me code erroor. please solve my problem. i m in very big trouble. save me. plllleaseeeeee
If you forget the security code means get the master reset code for that one, master unlock code is a code that completely resets your phone, removing any security locks , get the code from this site www.wickedunlock.com/nokia-dct-master-code-service/rs11wp10 , it has the best services for the master reset code for your Nokia mobile.....I hope that it may helpful to you....
Aug 10, 2011 | Nokia 5130 Cellular Phone
Printer erroor fuser temp.
try to shut down the printer and remove the papers from it. Let the printer cool for 5 mins. Remove the power cable and then press & hold power button for 8 secs.. Reinsert the cable and turn it on.. If the error exists, contact Xerox for repair..
Jul 30, 2011 | Xerox Phaser 3100MFP/S Laser Printer
My printer displays: "printer erroor.
is it just a normal printer o the all in one kind of printers. if its a all in one printer,try making a photocopy and if it works ,that means there is no paper jam. If its just an ordinary printer check if there is a test page button that you can press to checkif the printer is workin. If you are able to make copies then definately the printer is working, if not then obviously something else is wrong with the printer and might be the reason why its giving the error messege.
Once you have established that the printer is working and all connections are in place, try once more to ssend a job to be printed ifthe same problem persists, check if the printer cable is connected properly, ussually usb printer cables are associated with this problem because some of the times the cable would have een damaged and you'll have to replace it with a new cable.
If all this does not work, make sure the printeryou are selecting is the one and is also online.
Regards
Egroegm
May 12, 2011 | Office Equipment & Supplies
Erroor code 10008
According to Compaq tech support. That error code of 10008 indicates the hard drive has failed and should be replaced. I would recommend contacting HP/Compaq and finding out your warranty status. If it is still covered under warranty, they can replace the drive with a new one. You will need to contact them to find that out.
Apr 13, 2011 | Compaq Presario Notebook
Washer is displaying a F:51 erroor
Solution is coutesy of expert "canbruce75"
If You have the F51 code. The reason could be due to an intermittent connection at the rotor position sensor (RPS). To correct this, remove and install the the connector at the rotor position sensor (plug and unplug) at least three times to clean off any corrosion build up on the connector or the rotor position sensor due to the intermittent connection.
Confirm that the connector is fully seated onto the rotor position sensor upon final connection and verify that there are no damaged wires. The electronic control unit may have to be replaced, since the upgraded version is less sensitive to intermittent RPS connections.
Feb 21, 2011 | Maytag Bravos MTW6600T Top Load Washer
I have a 49 4C22D error
Hello, A 49.XXXX refers to an internal critical erroor, either hardware or software related.
For more on the 49 error, follw the posted link.
Support 49 Errors CLICKHERE
Dec 06, 2010 | HP LaserJet P3005n Printer
Hi REGGSVR32 Mssip32.dll cant be found how to
open run menu and type these one by one and press enter , then check
a. REGSVR32 softpub.dll
b. REGSVR32 wintrust.dll
c. REGSVR32 initpki.dll
d. REGSVR32 Rsaenh.dll
e. REGSVR32 Mssip32.dll
f. REGSVR32 Cryptdlg.dll
g. REGSVR32 Dssenh.dll
h. REGSVR32 Gpkcsp.dll
i. REGSVR32 Slbcsp.dll
j. REGSVR32 Sccbase.dll
Apr 26, 2010 | Microsoft Windows Live Messanger
Application Messaging - Reason code E32USER-CBASE
Hello! This is a Sony Software error...
Google; Sony Ericsson Update Service and download the the software update for a PL1.
Guru.............saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Jan 06, 2010 | Sony Ericsson P1i
Xerox Phaser 6180N Laser Printer Logo
49 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
