Question about Medion MD2950NA diamond lamp
How to reset medion md2950na to factory settings
Have one medion projector which I need to reset to factory settings
How do I reset my Medion E4506 back to factory settings
Try Ctrl + F11 as soon as you turn on the laptop. This would take you to the complete factory restore of the system.
Dec 03, 2015 | Medion Computers & Internet
How to reset to factory default settings on projector sony VPL-DX126
here's the user manual of the prjector:
https://docs.sony.com/release/VPL-DX126_DX146_DW126.pdf
i've readed it and i guess you should push the reset bottom in the remote.
Nov 21, 2014 | Sony Office Equipment & Supplies
How to factory reset
To restore all the projector settings to their factory-default values, select the Reset menu (very bottom of the Menu tree), highlight Reset All, press Enter, and select Yes to confirm.
May 19, 2014 | Epson BRIGHTLINK 450WI Projector
Need to reset projector to factory default settings
hold the power button until it beeps or turns on ect but keep holding it and it should reset
Dec 07, 2013 | Acer X1261P - DLP projector - 3D - 2700...
Telex p1200 projector
Can you still see the projector's menu? If so, do a 'Factory Reset.' That will re-set it to the parameters it had when it first came out of the box. Factory Reset is usually buried a couple of levels deep, in an 'Advanced' menu.
Apr 26, 2013 | Panasonic Telex Magnabyte Video Projector...
The screen is upside down and when I click "set up" or "System" it reads "Source Unavailable" and I have no options to choose from.
Apply the Factory Reset within the projector options. You should be able to select that option without a source attached to the projector. What the option does is set every settings of the projector back to factory default.
Aug 07, 2011 | InFocus LP280 Projector, Factory...
I have recently replaced the lamp in my screenplay 7200 projector. But the replace lamp box still apears in the lower corner how can I reset this. I've tried going into settings in the menu and hit the...
Rather than hitting the factory reset, you need to reset the lamp hours. With the power on, press and hold the brightness up and brightness down keys on the projector keypad at the same time for 10 full seconds. Verify the hours were reset by going to "About" in the main menu.
Feb 12, 2010 | InFocus ScreenPlay 7200 Multimedia...
Medion MD2950NA diamond lamp Logo
83 people viewed this question
Top Medion Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Medion Office Equipment and Supply Expert? Answer questions, earn points and help others
