Question about Thomson TE1152 Top Load Washer
D02 error code
Top loading Gorenje WT 52113, it stops a few minutes into the washing cycle, an error message comes up on the small digital display, looks like d02?
This washer only has f fail code, they recommend you contact svc person for repair. Fail code for F02: F2 Door lock fault detected The door lock on the washing machine has been detected as faulty or failed to engage correctly.
  • Check that the washing machine door has been closed correctly and is engaging the door lock correctly
  • Check wiring to door lock
  • Check door lock
  • Check wiring at control module or timer
Aug 12, 2016 | Washing Machines
What is the meaning of D02 in Samsung watching machine
D02 Error may have following Causes:
1-drain hose kinked or plugged
2- drain pump failure
3- accumulation of debris in filters and causing the floater positioner got stuck
if there is the flow of water through the drain hose it may that the floater inside the bath got stuck, if this is the case, remove the filters, unfasten the bolts and remove the inside cap until you can see the floater.
clean debris from inside surface of the washing machine and also clean the floater.
Posted on Aug 21, 2015
Dec 19, 2015 | Samsung Washing Machines
The SAPE.Heur.d02 is a Trojan Virus.
The D02 file extension is for the MicroSim PCBoard NC Drill Data.
Some manufactures have a version of their motherboards that feature a D02 as the version. Please be more specific for more assistance.
Dec 19, 2015 | Computers & Internet
Wastetonerasihavereplacedrumunit ir 1600
What is Wrong type print cylinder install for RP 3100?. Error number is D02-532
Jul 20, 2013 | Office Equipment & Supplies
Error code d02-d532 on riso RZ200EP
Jan 02, 2013 | Office Equipment & Supplies
Error code d02 on samsung dishwasher dmb28afw
d02 Error may have following Causes:
Dec 21, 2012 | Samsung DMB28AFW Dishwasher
Thomson TE1152 Top Load Washer Logo
Top Thomson Washing Machines Experts
Harjeet Singh
highlander28
Level 1 Expert
Sue Hale
Level 1 Expert
Are you a Thomson Washing Machine Expert? Answer questions, earn points and help others
