Question about Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 333,000 BTU
Buttons won't turn temperature up or down
Turns on but I can't get buttons to work
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sta Rite Master
  • 1,448 Answers
Sounds like you need a new control board did mice nest under it that happens frequently
Posted on May 26, 2014
I have a 55 inch JVC tv,today the screen went black but still have sound, also the buttons on the back wont work, but the channel down button turns it on and off? What is wrong with it?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary..
Jan 15, 2017 | JVC Televison & Video
Hayward H250FDN blue temperature control will not respond (MODE and RED up button are OK)
up and down button at same time with either mode or enter at same time for seven seconds that should unlock
May 16, 2014 | Hayward H250FDN Low NOx Natural Gas Pool...
How do I turn my thermostat down?
I think you may be misinterpreting what it's telling you. The up down buttons select the DESIRED temperature, when it goes back to the same number it's showing you the actual temperature, which given time should eventually reach the desired temperature.
May 09, 2014 | Ouellet Heating & Cooling
Interior light not turning on. Temperature not showing up either. Brand new out of the box. Plugged in and it lit up, then turned off. Now won't turn on (light won't turn on) Unit turns on and
Sounds like a poor connection in the control or a faulty control module, I would return it as faulty for a new one. They seal those units up pretty good so we can't fiddle with them. Everyone gets a lemon sometimes.
Sep 06, 2012 | Whynter (WC16S) Wine Cooler
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
    Hi.
    Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
    If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
    Good luck.
    Jul 16, 2011 | Toshiba Computers & Internet
    Engine stopped running after 2 hours of consistent start and stop driving with air on for the 1st time at full blast. It turns but won't fire. I checked fuel pump and it's working. Replaced...
    have you cheeked the ignition (coil ) ?? probably it is
    because we learnt it (the coil) comes down after engine high temperatures
    yes i know if car cools down and turn on again it is surely bad coil
    but some times the coil is just dead not only bad
    Jun 06, 2011 | 2001 Nissan Sentra
    Power button failure
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Sep 11, 2008 | Nintendo GameCube Console
    Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 333,000 BTU Logo
    76 people viewed this question
    Top Sta Rite Pool & Spa Experts
    Jay Finke
    Jay Finke
    john h
    Jim Goldsmith
    Jim Goldsmith
    Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
