Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
Yamaha outboard f15b
Plasticparts fall out of the water take in shaft and causes overheating how to solve
    Sergeant:
  • 456 Answers
Take ro a mechanic
Posted on May 13, 2014
3 Suggested Answers
Fame_Guru
  • 483 Answers
SOURCE: Yamaha outboard motor manual
You got it :
http://www.yamaha-motor.com/outboard/service/viewmanuals/outboard_manuals.aspx
here !
Posted on Mar 20, 2009
goldbill
  • 184 Answers
SOURCE: yamaha prop shaft
Think you will need to set them side by side and look at the details. I have used similar shafts but make sure the clutch dog engages the gears properly.
Posted on Sep 12, 2012
1997 yamaha 75 hp outboard. what does it mean when alarm sounds
It sounds as though you have an overheating or low oil issue. Check for water flow through the engine. Check all exit ports. Dirtdaubers/Wasps can clog these. Is your oil pump working correctly?
Aug 27, 2017 | Yamaha Boating
I have a 2003 yamaha 40 hp four stroke outboard, this year started up seemed to run great after about 25 minutes i shut it down an hour later checked oil crankcase full of water
water in the engine crank case oil --major seal or corrosion problem in the motor
water in the leg gear box --
pump seal on the drive shaft
Jun 01, 2017 | Yamaha Boating
Coleman outboard overheating
You should change your impeller.
It is located at the top of the gearbox, around the vertical engine shaft.
First, disconnect the gear control. Underneath the steering bracket, you'll see a long nut with a counternut. ( Maybe you'll have to shift FWD or BWD to get better access ). Loosen the counternut 1/4 turn and then turn the long nut up ( 2 open box wrenches 10mm ).
Then remove the 4 bolts holding from lower to upper the gearcase ( just above the anti-cavitation plate )
The gearbox should drop down easily.
Then remove the 4 screws of the waterpump ( top of gearcase, around the long vertical shaft ). Lift the waterpupp housing, you'll get the impeller.
To reassemble the waterpump, grease the cup in the housing with PTFE or silicone grease, and while pushing the housing down over the impeller, rotate the shaft clockwise.
Reassemble all the rest in reverse order.
Check and adjust the gear shifting...
Apr 01, 2014 | Coleman 9.9 HP Manual Start Outboard Motor...
Oil coming out of were water goes in on leg of yamaha 15 horsepower outboard why is this so ???
If your water pump has failed it could be that your lower shaft gear oil is getting past and running out.
The water pump on those should be replaced yearly. They are a rubber wheel with fins on it. They dry out and weather rott wich leads to their failure.
Aug 23, 2013 | Boating
1988 evinrude outboard
You need to replace the oil seal on the main shaft located below the water pump. Your lower unit gear oil is seeping into the water pump housing. I had the same problem on a Yamaha that I just repaired. Not a hard job. 7_12_2013_1_59_18_pm.png
Jun 17, 2013 | Boating
1991 yamaha outboard motor leaking water from bottom
Under The Water Pump Is A Seal Plate Which Has Two Shaft Seals And An Outer O Ring Seal This Is Probably Where Your Problem Lies.
Mar 16, 2013 | Boating
8hp yamaha runs hot
In most outboards, it will flow through the prop itself (through the inner prop). There should be a stream of water coming from somewhere around the back end of the motor itself, called a telltale, which visually shows that the water pump inside the outboard is pumping water up around the motor. If you cannot see this, then there is obviously a problem with the water pump or pump impeller that needs to be corrected to prevent the outboard overheating.
Jul 04, 2009 | Light Outboard Motor Boat Bass Fishing...
Hello, I have a Yamaha 9.9 outboard engine, it stars without any problem. When I ref it up just above idle it dies after a few seconds. There is fuel, fuel filter in the line is no blocked.
Yamaha outboard that runs fine until heat light come on and it idles down. When light goes offf it runs fine. What is causing heat problem
Jun 06, 2009 | Yamaha Water Sport
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
70 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
Ian Summerfield
Ian Summerfield
Are you a Light Boating Expert? Answer questions, earn points and help others
