Question about Chevy Astro Carpet Floor Mats - Berber Auto Mat Floor Mats BC-CV-200-5129
Left front tire locking up when break pedal is pressed
When I press on the break pedal the the front driver tire locks and chadders
    Genius:
  • 1,114 Answers
The problem is most likely the caliper on that wheel is not working properly and not releasing. Have the brake system inspected by a certified mechanic.
Posted on Mar 30, 2014
Stick is lock on park cant put on drive by pressing break wy
have friend bump car just a little to move it apply break put on parking break
start vehicle press brake take out of gear let off emergency brake
you park on hill so this is called shift lock always use the emergency parking break when on hill so you dont get shift lock
Nov 09, 2013 | 2004 Ford Freestar
Brakes won't release
does your model have an abs unit as this can be the fault, some areas when sold did not have this abs unit but with the abs unit it has valves to assist braking. if a piston in the abs has failed it stop it from working and only manual braking is used but this is limited.
Jun 13, 2017 | 1992 Honda Accord
2002 Kia Sportage break tighening up where break pedal is hard to press down
Hello...get the vehicle back to the shop that worked on it....Sounds to me like one or more of the calipers won't release it's grip when you release the brake pedal or the master cylinder is locked...Think about it...it's like driving with your foot on the brake pedal....or maybe your power brake booster...anyway...Get it back to the shop that worked on it and bring your receipts for all the work done...Let me know what happens...I hope this was helpful...PEACE........
Feb 17, 2012 | 2000 Kia Sportage
Reset tire monitor on 2009 escalade
Hopefully you still have you manual. I will tell you how to reset the HHR, I found it in my manual. Turn the key to on, press lock and unlock at the same time on your key fob. The horn will beep twice telling you that you are in program mode. The left front turn signal light will come on, press the valve core letting air out of the left front tire. The horn will beep when left front is programmed. Then the right front turn signal will come on, let air out till horn beeps. Then right rear, same procedure then left rear same procedure. When that is done horn will beep twice again saying tire program is complete. Turn key off, make sure you air all tires back up.
Jan 03, 2012 | Cars & Trucks
I have a Schwinn Ditch mountain bike with front disc brakes and a quick release front tire. I pooped the tire off using the quick release on the hub and the tire simply slipped off and out of the disc...
You have to bleed the break fluid on your break and press the pads on both sides then insert the disc. When you bleed the break fluid do not press the lever.
Apr 10, 2011 | Schwinn Cycling
Break pedal sometimes vibrates when the breaks are applied. Also some sort of knocking sound coming from the hood when slowing down at low speeds
They have ABS and when you press the pedal hard the pedal vibrates. its the computer doing a pumping action for your. It grabs and releases the breaks so they dont lock up and it allowys you to stear your vehicles while the brakes are firmly pressed.
Jun 25, 2010 | 1995 Cadillac Seville
I have a 2007 Suzuki Forenza Sedan. I have no break pedal pressure, the pads are new and the fluid level is correct. I can pump the pedal several times, push the pedal all the way to the floor and the left...
Sounds like you're having an issue with your master cylinder, or you just need to add break fluid and bleed the lines. If you don't know how to do that, take it to a mechanic.
May 29, 2010 | 2007 Suzuki Forenza Sedan
Strange vibration at the pedal when breaks lock
sounds like warped rotors, if the steering wheel also shakes then that would tell me its in the front, replace the front pads and rotors that will solve your problem.dont try resurfacing youll just have pulsating brakes again in a month or two.
Jan 08, 2010 | 2006 Audi A4
Chevy Astro Carpet Floor Mats - Berber Auto Mat Floor Mats BC-CV-200-5129 Logo
70 people viewed this question
Top Intro-Tech Automotive Vehicle Parts & Accessories Experts
David Harrelson
David Harrelson
Lawrence Oravetz
Timllfixit
Are you an Intro-Tech Automotive Vehicle Part and Accessory Expert? Answer questions, earn points and help others
