Question about Magic Bullet NutriBullet Nutrition Extraction System
Why my nutribullet is not working when it is plug in an cup is place in
It is not working
Cup wont press down onto motor grips
Have you got something caught in it? Is it still under warranty? I am guessing but the mechanism inside the base should drop when you push to twist. Check is this is happening. If not then that may be the problem
Apr 21, 2015 | Magic Bullet Nutribullet Blender
I went to plug in my bullet and it won't turn on.
There's 3 tabs on the inside of the base that get pushed down when you push the cup in. Two of them have switches on them, sometimes they can break. Make sure they are being pushed down. If not, it could be one of the switches inside.
Apr 09, 2015 | Magic Bullet Nutribullet Blender
I bought a nutribullet less than a yr and it just stop working it does not smokeor smells like it burned.
ck where the cup goes onto the top make sure it turns on to lock on that is were the switch is to turn it on
Jan 20, 2015 | Magic Bullet Nutribullet Blender
How do I release my stuck NutriBullet
Use warm running water on the threads, keeping the cup end down towards the sink. Keep water away from electric motor unit end. Gently twist after 30 seconds to release cup from motor unit.
Dec 22, 2014 | NutriBullet Pro 900 Series
Ridges inside base catch cup so it won't seat properly
The cup rim had gotten into it while stored. It looked like part of the base. As another user noted, the inside of the base is flat, with no ridges.
Sep 17, 2014 | Magic Bullet Nutribullet Blender
Get the cup off the base, was making hummus, and now it still works, but wont let me remove the cup
put the cup area under some hot water near boiling and then undo the top with a cloth should come undone then, make sure its hot water.
Sep 11, 2014 | Magic Bullet Nutribullet Blender
Nutribullet just stopped working,removed cup then replaced still no action...what now?
One probable reason for failure: The bottoms of the jars have outward-facing prongs which engage slots--incorporating integrated small power switches in the base. If those prongs break off or wear down--or, otherwise they can't make good contact by pushing inward those small switches (all of them)--your blender can't start.
It's an interlock safety feature intended to make certain users use the company's jars when starting their blenders. If the jar seems satisfactory, you may need to push down on the jar. (This reliance upon problematic plastic tabs holding up over time, in order to provide the safety feature, proves the "Achilles Heel" of this small kitchen appliance.
I've noted that Shark/Euro Pro appears to invoke a similar safety solution on their jars for at least some of their Ninja Blenders. The importer company behind Nutribullet still does offer replacement jars, I believe.
The company behind Nutribullet also warns users not to leave the base running for more than one minute at a time. (The system is designed to provide short, intense bursts of grinding and cutting power--not lengthy blending times.)
Aug 13, 2014 | Magic Bullet NutriBullet Nutrition...
Nutribullet manual
www.nutriliving.com/forums/were-listening/nutribullet-support
Jun 15, 2014 | Blenders
Cup wont lock into place
I am having the same problem and have only been using mine for a week!!
Jan 08, 2014 | Magic Bullet Nutribullet Blender
Magic Bullet NutriBullet Nutrition Extraction System Logo
85 people viewed this question
Top Magic Bullet Health & Beauty Experts
Robin Hill
Robin Hill
Jeff Tilburn
Jeff Tilburn
Are you a Magic Bullet Health and Beauty Expert? Answer questions, earn points and help others
