Question about capital Precision GCR484G 48" Pro-Style Gas Range with 4 Power-Flo Sealed Burners w/ Simmer, 24" Thermo-Griddle, 4.6 cu. ft. Convection Oven, 2.1 cu. ft. Small Oven, Manual Clean, Infrared Glass Broiler and Full Extension Drip Trays on EZ-Glides Not Exact Im
Thermador has had sudden no gas to whole unit
We used the range this am, then cleaning people came, and after, there was no gas flowing to any of the burners. Any idea?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
They may have accidentally turned off a little gas cock which is cunningly hidden on the front panel can\'t remember if it\'s top or bottom, it isolates the gas to the main control valve.
Posted on Jun 11, 2014
Burners output seems "weak", is there a valve that regulate gas flow and if so can it be adjusted?
Yes it can be . Contact your utility company. They can make the adjustment. They have a vested interest and a responsibility in this .
Jan 27, 2013 | Thermador Pro Harmony PRG304GH 30"...
SGCS304RS The two left burners work. The two right burners, spark but no gas comes out.
The regulators are clogged and so there is no gas flow due to this. use a good brush to clean the burner tops so as to get the mixture of gas /air correct. Use pressurized air to clean the valve, clean the JETS and reset.
Jun 14, 2011 | Thermador 31 in. SGSX304Z Gas Cooktop
2 burners wont ignite
Hello there:
A burner doesn't work The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite. The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, either repeat the procedure or call a qualified appliance repair technician.
Jun 29, 2010 | Thermador SGS36GS Gas Cooktop
We have a thermador 5 burner gas range top and the pilot light seems to have gone out. The burners don't go on but we smell gas. How do we re-light it?
Most gas range tops no longer have pilot lights but use an electronic ignition (sparker) to light the burner. Normally when you turn the burner on you should here a snapping or sparking sound, at which point the burner should ignite. Here is a link to the user manual for 36" - 5 burner Thermador rangetop...maybe this will help: http://dl.owneriq.net/a/ac64ae7b-1ed3-44a3-9235-e4dbd8fe4628.pdf
By the way, in the short term you could always use a match to light the burner. JUST BE VERY CAREFUL THE YOU HAVE THE MATCH LIT AND OVER THE DESIRED BURNER BEFORE YOU TURN KNOB TO START THE BURNER!!!!
Jan 15, 2010 | Thermador 37 in. SGSX365 Gas Cooktop
Have a thermador pc366 six burner range, the 2
Did you get an answer on this? Have the same problem and the house call starts at about $100
Sep 21, 2009 | Thermador PC366BS Stainless Steel Gas...
Trying to remove stains around the gas unit where temp is the hottest.
have you tried cooktop cleaner? this seams to work pretty good at getting stains out of stainless steal. (You know...cooktop cleaner is really just car wax if you had some try this on a little area and see how it works and if you like the results...there you go.) let me know what you think. But like i said always do a test point before doing the whole surface.
Apr 22, 2009 | Thermador 37 in. SGSX365 Gas Cooktop
Clicking gas cook top
I accidentally bumped the thing where the gas comes out (I don't know what it's called - I'm a wife not a tekkie) and it started clicking when I turned it on. I turned off the gas and repositioned that gizmo and it stopped clicking.
Feb 19, 2009 | Thermador SGS36GS Gas Cooktop
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
Gas cooktop
We have an older Thermador Gas Cooktop type range. It was working fine until the cleaning crew came in, then all the burner igniters were clicking when turning on a single burner. I solved the problem by cleaning off the igniters. I first of course unplugged the power. Then I took a small wire telcom pic tool to scrape the white and brown deposits from the sides of the igniters. You could probably use something else similiar to do the scraping. I noticed a shiny surface underneath. I then went ahead and scraped and brushed clean the mating surface where the spark travels. I then vacuumed up the mess. My burners all worked great after this. Hope this helps!
Aug 27, 2007 | Kenmore 30 in.32099 / 32094 / 32092 Gas...
capital Precision GCR484G 48" Pro-Style Gas Range with 4 Power-Flo Sealed Burners w/ Simmer, 24" Thermo-Griddle, 4.6 cu. ft. Convection Oven, 2.1 cu. ft. Small Oven, Manual Clean, Infrared Glass Broiler and Full Extension Drip Trays on EZ-Glides Not Exact Im Logo
109 people viewed this question
Top capital Cooktops Experts
Paul Carew
Are you a capital Cooktop Expert? Answer questions, earn points and help others
