Hi have lg32lc56zc TV was having problems with powering took a while but had green remote light Then turn it off on side of TV no power what so ever Checked fuse in plug and the actual socket works with other thingsPlease help
    Master:
  • 397 Answers
The most common thing to fail on modern TVs is the power board. I would take the TV apart and check the internal power board and the capacitors on it, if any appear to bulge in anyway try replacing them.
Posted on Mar 20, 2014
SOURCE: Power light on but no picture
I've got the same problem. No sound, no picture, just a green light. The light comes on when its plugged back in. No buttons work. Occasionally the light flashes off.
Posted on May 30, 2008
  • 8 Answers
SOURCE: power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Posted on Aug 21, 2008
SOURCE: magnavox 32mf23id/37 wont tun on
Had the same issue, I replaced two 1200uf caps on the power supply board and now it works fine again. Remember to replace the caps with caps rated for at least 35wvdc.
Posted on Mar 27, 2009
  • 188 Answers
SOURCE: power light keeps blinking and power will not turn
Check back light inverter,if ok then check the 12V and 5V line,if not OK probably the IC in the power supply is defect ( F9222 )
Posted on Jul 20, 2009
SOURCE: TLA-04011c 40in. LCD TV: Red light is on. TV
I have the same TV and I just replaced the Capacitors. It came with 2 10000UF 10V caps and I put in 2 1000UF 35Volt caps from radio shack. Its like brand new. There is even a video on how to change them on You Tube.
Posted on Nov 16, 2009
Mitsubishi wd-73738 turns itself back on
It sound like the remote is powering off the cable box but not the TV. The remote control may need to be reprogrammed to the TV. When you press power it may only power off the Cable box. At that point, try pressing the TV button on your remote and then Power. If it does not power off the tV after pressing the tV button, the remote may need to be reprogrammed to the tv. Cable companies usually have the codes needed to program their remotes to the TVs.
Jul 09, 2016 | Mitsubishi WD-73738 73" 3D Ready DLP HDTV...
My Sharp tv remote will not turn on / off tv. It will turn on by the main power switch on tv but not by remote.
From page 8 of the manual:
The POWER indicator on the AQUOS television should light GREEN indicating you have power to the AQUOS television.
If the POWER indicator on the AQUOS television still does not light up, press TV POWER on the remote control to turn the power on.
IMPORTANT:
IF THE UNIT DOES NOT POWER ON - UNPLUG THE AQUOS TELEVISION FROM THE OUTLET AND REPEAT THE INSTALLATION STEPS.
IF YOU STILL ENCOUNTER NO POWER, PLEASE CONTACT US AT 1-800-BE-SHARP
http://www.nemsworld.com/theater/LC46_52D62U_Manual.pdf
Dec 04, 2015 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Toshiba regaza 37rv635db wont turn on
seems like capacitor problem, chack them and if thay have exploded replace them.
Aug 25, 2013 | Toshiba 37RV635DB Regza 37-inch Widescreen...
Hi Hi have a toshiba regza 32av555db that was working fine however it will now not turn on, the red standby light is flashing and the green on light flashes also. I have tried a different remote for the...
Problems it is not the tv remote control.This tv have a dying power supply board,that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Jul 11, 2011 | Toshiba 32AV555DB 32" HDTV-Ready LCD TV
Tv will not turn on when tried on either tv or with remote green light flashes 3or 4 times then turns into red flashing light no picture or sound at all.Have tried changing batteries in the remote and fuse...
Hi.The signal lights red means the primary power of your tv is good and the signal lights green indicate the second power.If the green lights is flashing it means that they have shorted parts in the crt board.Maybe the problem is in the power section of the crt.Need for troubleshoot or repair the crt board.
Jul 03, 2011 | Panasonic Televison & Video
Screen remains locked on Blue background welcome screen when it finally comes up. Status light remains blinking green. Over the past 7-10 days it took several tries powering on then off before picture...
Tv manual PCB control buttons all work?Like power on/off,volume - + and chanels + - all work than it not the manual PCB board control IR is parts of this board.Not the IR problems,when tv is finally on the remote work fully everything buttons?No,could be remote control have problems.Tv might have DM power supply board problems.
Feb 08, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
Need rca crk17sa users guide for codes for Magnavox TV
Ok it took me a while. Go to this link to find the codes for you remote: 10054 is the most used code for Magnavox. I hope this helps you out. Good Luck!!!!!!!
http://www.directv.com/DTVAPP/content/remote_codes
Here's how to program your DIRECTV remote control:
  1. Press MENU on remote.
  2. Select "Parental, Favs and Setup"
  3. Select "System Setup"
  4. Select "Remote"
  5. Select "Program Remote"
While aiming remote at device, follow onscreen instructions to program remote to TV, DVD, or other device.
How to program the white DIRECTV remote to your TV
  1. Look up the control codes for your DIRECTV remote control.
  2. Make sure your TV is turned on.
  3. Slide the mode switch at top of remote to "TV".
  4. Press and hold the MUTE button. This is located above the number 1 button.
  5. While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
  6. Enter the first TV code you have. The green light on remote should flash twice.
  7. Aim remote at TV and press PWR button once. The TV should power off.
  8. Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
If the TV does not power off, repeat steps 4, 5, 6 and 7, using the next code for your TV brand.
If remote control fails to program using all available codes, try scanning for the code.
How to scan for TV codes on your DIRECTV remote
  1. Make sure your TV is turned on.
  2. Slide the mode switch at top of remote to "TV".
  3. Press and hold the MUTE button. This is located above the number 1 button.
  4. While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  5. Then enter 991, the green light on remote should flash twice.
  6. Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  7. When the TV powers off, press and release the SELECT button.
Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
Mar 08, 2010 | Televison & Video
Yellow light is so I have power but remote or
Its a vizio l37. I bought it in 2004 from Sams and haven't had any problems until now. We took it to a repair shop and they charged me $55 to tell me it was dead. They said they could fix it by replacing the main board which costs $250 with an additional $250 in labor. We said no thanks to the $500 repair and bought a new tv for $600. Now its in the garage and I'm wondering if there is something I can do to fix it for less. Seems like a waste.
Jul 29, 2009 | Vizio L37 Television
Won't power, light goes green 5-10 seconds later red flashing light is basically what's its doing. at 1st i'd power down the tv for a min and then it comes back up with no red flashing going on.
keep pressing the channel up/down button and the screen will come on it may take a few minutes dont use the switch on the side of tv just use the remote buttons u could try the power button on the remote aswell
Dec 18, 2007 | Philips 42FD9954 42 in. Plasma HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
