Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Lid latch Thank you for the responses. I am not looking to replace the entire latch. I have fixed the broken piece and I am trying to put it back together. I just don't know where the two pieces of metal go inside of the latch housing to get it to work right.
jsrock516
  • 5911 Answers
SOURCE: Door Latch has broken plastic tab
The door latch assembly comes as one piece. It would actually be much simpler to purchase the new latch and replace the whole assembly instead of trying to put pieces and parts back inside a latch that may or may not work after all your hard effort. If you decide to replace the latch, follow these steps: 1. Unplug the machine. 2. Remove the lower kick plate panel if you like (this can help you reach the latch from a couple of different angles). 3. Open door and feel around the rubber door boot for a wire hoop. At the bottom of the door open is a tension spring. Pull the spring apart and remove the wire hoop from the groove. 4. Gently lift the rubber boot from the groove around the door opening and push inside the machine so you can access the inside of the casing. 5. The door latch assembly is located inside the case on the right-hand side. There should be a couple of wire connectors going to it (remember how they come off). Be careful with the wires, they are small and can break. 6. Unplug the wire connectors and remove the three screws holding the latch in place from the outside of the casing. 7. There should also be a plastic retainer holding the latch in place. Remove latch from retainer. 8. Install new door latch by placing it in the plastic retainer, first. 9. Plug wires connectors in. 10. Re-install the three door latch screws. 11. Re-install rubber door boot around the door opening. Make sure it is properly seated in the groove. 12. Reinsert wire hoop. starting at the top of the door opening, carefully push the wire hoop into the groove and work your way all the way around the bottom where the tension spring would be. (A second set of hands to hold the wire hoop in replace would be handy at this point). 13. Pull tension spring apart and snap into groove. Done. Hopefully this will take care of your problems. Of course, you may not like the idea of having to purchase a whole new door latch assembly, or the effort required to remove and replace. But, it sure beats trying to rebuild the old one. I hope this helps.
Posted on Jun 11, 2007
jsrock516
  • 5911 Answers
SOURCE: whirlpool washer problem with door
I believe you are talking about the lid switch. To replace follow these steps: 1. UNPLUG the machine first. 2. Remove the console. You will have one of two types of consoles with two separate methods of removal. a. The first type is a matter of removing the two end caps of the console by lifting up on the end cap from back behind the console and pulling towards you. The cap should just pop off. There will be a groove present on the top rear that you can gently pry with a screwdriver if you can't remove by hand. You will need to remove the philips screw under the end caps and the console will lift up. Be careful not to break the plastic hinges that hold the console in place. You can lift it up and lay it back over the rear panel in a resting position. b. The second type of console (usually found on some of the newer models) has a retaining clip under each end cap at the front corners. You will need to carefully slide a putty knife between the end cap and top of the machine from the front. Push in to release the retaining clip and lift up. This may be a little tricky trying to get both ends to release together. The console lifts up in the same manner as described before. Again, be careful not to break the plastic hinges that hold the console on. 3. You will find two brass colored clips under the console. Place a flat blade screwdriver in the clip groove on the washer top and push away from you. This will release the retaining clip that holds the case to the back of the machine. Remember how they came off, because you will need to put them back in. 4. Disconnect the lid switch plug from the connector. This is a white plug that is mounted physically to the washer top casing. 5. Lift the lid and place one hand under the front rim of the casing and pull up from the rear towards you. The entire casing should lift off the frame. 6. The lid switch is located on the right side of the machine in most washers. Some are located in the back on the left hand side. In either case they are fairly simple to remove. There should be a couple of mounting screws and a ground wire to remove first. Then the switch (with harness) should come off. You will need to carefully remove the connector from the casing by using a small screwdriver to release the tabs holding it in. 7. The new switch will install using the reverse order of the steps I just mentioned. 8. Placing the case back on the frame can be tricky. Lift the lid again and place one hand under the front rim of the casing. Looking down through the lid, place the front of the casing UNDER the frame first and slowly lower the rest to the back. There are two cleats on the frame that must line up with two holes in the casing. Once the casing lines back up on the frame, set it down all the way and pull the back up to meet the casing so you can place the brass retaining clips back in. Place the clips in the groove on the back first, then push down until they snap back into the hole on the washer casing top. You may have to use a little effort to get them back in. 9. Reinstall the console. I know this seems like a lot, but it should help you replace the switch. Getting the machine case to line back up is the hardest part of the procedure, but you can do it if you take your time. Let me know if you have any further questions.
Posted on Jul 17, 2007
jsrock516
  • 5911 Answers
SOURCE: Getting a small plastic piece out of a door
If the piece is jammed (locked) in the door latch assembly, there is a manual release that you can use to open the door latch to see if the piece will come from free. The following link advises:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
This may require two people. One to pull on the manual release, while the other works on retrieving the broken piece from the door latch.
Another method may be to remove the door latch assembly so you can easily manipulate it outside the machine. This link explains how to remove the door latch assembly:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
Now...if the piece is jammed too far inside the door latch assembly, a last resort would be to replace the latch. I hope it does not come to that, but it may be a last resort. The link provided will give you all the necessary steps to complete this repair, if required.
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Nov 08, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool Duet: gray plastic agitator poece inside drum broke off
here's the part number for the replacement 8182233, thinking it may come as a 3 pack , if they're not broken no need to replace. but the new one will simply slide in and with a click forward lock into place. they also come shipped with a screw to secure. in order to install screw you'll need to remove the top of the washer(3 screws across the back of the top assy and slides back and off. then you'll see the top of the tub area, a small black hose will run from the white box to the left to directly top of the tub assy. remove ethe hose from the tub and spin the inner drum to the correct position, they screw hole will line up through the opening, re-secure the hose to the tub and your in!
Posted on Nov 13, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool top loading washer will not spin or
This problem is commonly attributed to a loose or broken lid switch.
If your washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, the problem is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
If you have any questions about this repair, or if you need additional assistance, please let me know. I hope this helps you.
Posted on Jul 18, 2009
Model ftw3011kwo washing machine won't work after breaking locking lid piece
Thank you for your inquiry, David Castro!
I understand that your Frigidaire washer is not working after the lid piece became broken. If the lid piece is not latching properly inside of the door latch then your washer is not registering the door is closed and will not start. You may need to have that piece replaced I would recommend having any electrical component replaced by an authorized technician. I hope this is helpful. -Matt
Dec 14, 2014 | Frigidaire Washing Machines
Need help with the lid latch
Yeah, I would say that your lid switch came apart. Seems to be a common problem with lid switches made out of plastic. I think that it comes from people placing heavy things on top of the washer. Like themselves during the spin cycle. And it puts too much pressure on the switch making it come apart.
I go to repairclinic.com a lot with model numbers to find manufacturer part numbers. Then take that number and plug it into ebay. For this model I found W10059230 to be the part number. Found a lot of listing on ebay for really good prices. Amazon is another good source for parts for low prices.
As for putting the switch back together there is no way to do so and it work correctly. It will need to be replaced.
Youtube videos is another good source on how to do things. People have been nice enough to post hands on videos of a lot of different things. Great learning source.
Mar 20, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Ge front loading washer door won't unlock
Some machines do this when the power is cut, there should be what looks like a screw heat on the front of the handle which will allow you to unlock the door and open it. If there is still water inside you will need to empty the machine first. There is usually a hatch at the bottom of the unit, open this hatch and you will find a cap to unscrew, unscrewing this cap will empty the contents of the machine onto your floor so be prepared!!!!!
May 08, 2011 | GE Washing Machines
This morning I opened my trunk to my 2055 Pontiac Sunfire and when I went to close it the black casing around the latch on the frame of the car came off so I put it back on and when I went to close the...
You may have inadvertently locked the latch when putting the plastic piece back on look at the latch mechanism and where the latch locks on the bar put a screw driver in the latch mechanism and then operate the lat to open it should open up then try shutting the trunk lid do it with the plastic piece off first to be sure thats the problem because if you have the plastic piece on you may make it nearly impossible to open it up. Then if it works put the plastic piece back on then make sure the latch is open and then close it does it work? if yes you did it if not write back to me for more help. Thanks for using fix-ya.
Apr 23, 2010 | 2005 Pontiac Sunfire
The trunk won't latch shut. It has the interior trunk release and electronic release from keychain. Also has trunk lid pulldown.
Try this forum. I had the same problem and they were saying to take off the trunk release actuator. I did and it worked. Don't take the whole piece off of the trunk lid (although if you do, it's easy to put back on), but take the one piece (the actuator) off of the latch. I don't know anything about cars and I was able to do it. Not hard at all. Take a look at the forum:
http://www.automotiveforums.com/t677633.html
Dec 16, 2009 | 1995 Buick Roadmaster
Back of camera will not close looks like small piece of plastic has broken
Yes, the film door was always a problem on these. The entire door was usually replace since it was one piece with the latch.
I do not believe that Nikon supplies the part any more. You can check eBay for a dead camera, or possibly a new /used door.
The other option is a repair kit available from USCamera.com
Dec 14, 2009 | Nikon N6006 35mm SLR Camera
Singing machine ism 1010
My machine has the same problem and I got the same response from the company. I discovered a quick fix. With needle nose plyers I removed the wire from the corner of the lid that holds the lid open. Without the wire, the lid remains closed and the CD will play. The downside is that its tricky to open the lid. I've been using the piece of wire I removed to gently pry the lid open. I think I will glue a knob or ribbon to the top of the lid to make it easier to open. This isn't a perfect fix, but it was quick & free and now I can use my machine!
Apr 21, 2009 | The Singing Machine Singing Machine SME399...
My 1999 Toyota Sienna has a broken rear latch
I answered this for someone else -
If you still have the broken piece, you can try to use that to try to open the back. Otherwise, you have to open it from the inside.
I changed mine in 2007 so if memory serves me, I had to remove the back panel and pull on the cable to open the door.
Now to see and pull on the cable, and replace the latch, you have to take off the inside liner/panel to get to the latch to replace it. This took about 2 careful hours to replace.
The trick is to get the two side pieces off.
These two plastic pieces are next to the window on the left and right sides. Each piece is about 3 inches wide and 18 inches long. Using a strong grip, or a pry bar or large screwdriver, take off both pieces. There are three clip areas that holds each piece in.
If you are using a tool, be careful to protect the area by wrapping a towel on the screwdriver/tool.
After that the bottom liner piece pulls away and you can see the latch.
There are two screws/bolts that holds the latch.
The two pieces snaps back in pretty easily.
You probably broke the plastic piece shaped like a J.
You can try to glue the pieces back, but note that the piece broke due to age. I changed the whole assembly - good for another 7 yrs. I could not find just the plastic piece
Apr 13, 2009 | 1999 Toyota Sienna
Jetta 2003, trunk won't lock
More than likely the spring inside the latch has come undone. To save some money you can remove the latch from the trunk, open the latch and reset the spring. To Remove the latch you will need to remove the carpeted cover on the trunk lid (there are about 10-15 phillips screws holding it on.) Once the cover is off disconnect the rod going to the latch by opening up the clip thats connected to the actuator. Disconnect the wire harness, Remove the 2 10mm Nuts holding the latch to the lid. Remove the black plastic cover on the latch and remove the electrical piece (the plastic cover wraps over the latch and is secured buy 2 plastic pressure snaps). Look down into the latch and you should see a small spring...on my Jetta the spring wasn't connected. take a small pointed object ( I used a light tester) and reattch the spring to the black hook. Mine had some broken plastic in it and After I removed that it worked fine. Once the spring is back into place reassemble the trunk and you should be good to go. No money spent, and it only takes about a half hour or 45 mins to do.
Dec 01, 2008 | 2003 Volkswagen Jetta TDI
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
