Question about Brother DCP 130C All-In-One InkJet Printer
Dcp-130c unable to clean 5A
Good day! please help me. I already reset the purge counter. It is now purge00000. I already reset several times but the same error still displayed.
    New Friend:
  • 56 Answers
Looks like something is blocking paper feeder, roller or the caret. check for some unwanted parts of paper or paper clips.
Posted on May 27, 2014
SOURCE: Unable to clean
unable to clean troubleshooting maintenance user guide
Posted on Jun 23, 2008
SOURCE: Need to reset purge counter due to error 46
not easy and worth to fix it since ink jet printer sare cheap. New one include all the ink cartridges which are expensive too.
gar266
Posted on Jul 31, 2008
SOURCE: unable to clean 46
posted fix in another prob same section
Posted on Aug 31, 2008
  • 1297 Answers
SOURCE: I reset the purge unit counter but the
Reset the maintenance counter ,and perform a general reset.
Posted on Aug 29, 2009
SpideRaY
  • 687 Answers
SOURCE: DCP-340CW purge counter reset
n the mean time you can RESET this purge count back to zero using the MAINTENANCE 80 menu, to continue using the printer for a while until you get the new pads. But it on a tray as if they are full they may start to leak onto your desk....
1 . Press (MENU) (MONO START) then (^) OR <the up arrow> four times, the Photo Capture and Red Exclamation Lights will then flash.
2. Press (^) eight times until you see <8> then press (SET)
3. Press (^) twice until you see <0> then press (SET)
You will now be in MAINTENANCE 80.
4. Press the (MONO START) its a toggle until you see PURGE:6451 ( I guess this means you have cleaned the heads over 6,450 times their threshold level.) you will need to enter the code <2783> to RESET it.
5. Press (^) twice until you see < 2 > then press (SET)
5. Press (^) eight times until you see < 7 > then press (SET)
5. Press (^) nine times until you see < 8 > then press (SET)
5. Press (^) four times until you see < 3 > then press (SET)
The Printer will beep then reset counter will be at ZERO <0000000>
Its the PURGE that will increment by a variable amount each time you clean the print heads the amount will be between 100 and 130. When this count gets to about 64,000 the error 46 will occur. That's about 510 times you can clean the heads before the pads need cleaning.
Almost forget to EXIT the Maintenance mode enter 9 twice by using the up arrow & set key's to exit from maintenance mode in the same way as entering the 2783 code, or power down the printer.
LOL
Check me out at www.windowstipsclub.co.uk
Posted on Sep 23, 2009
PROBLEM IS MY PRINTER SHOW ERROR CLEAN UNABLE 46
Hi
This is the counter inside the printer which stops the printer unless it is reset. Follow the below steps to do the reset on your printer.
How to Reset Brother DCP 110C, 115C, 120C, 130C, 135C, 145C, 150C, 165C, 185C, DCP 195C Printer
May 25th, 2011 • Printer
How to Reset Brother DCP 110C, 115C, 120C, 130C, 135C, 145C, 150C, 165C, 185C, DCP 195C Printer:
1. Press the Menu, then Mono Start key then press the UP arrow key 4 times to make the machine enter the maintenance mode and "ERROR 46′ pops-up in the display.
2. Enter maintenance mode 80: Select 8 by pressing the UP/DOWN arrow key and push OK key and select 0 and push OK key
3. Now Press MONO arrow key several times until you see PURGE:XXXXX
4. Select 2 and push OK, Select 7 and push OK, 8 and push OK, select 3 and push OK and the purge counter is now reset to 00000.
5. Press STOP/EXIT key to go to root of maintenance mode
6. Enter code 99 to exit maintenance mode: Select 9 and push OK, Select 9 and push OK.
Jul 24, 2011 | Brother DCP-110C All-In-One InkJet Printer
Clean unable 46 dispaly
Try to reset DCP printers without numeric keypad.
Follow this:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Jan 14, 2011 | Brother DCP 130C All-In-One InkJet Printer
How can i solved problems regarding my brother dcp-130c printer. it says clean unable 46. pls...
Dec 07, 2010 | Brother DCP 130C All-In-One InkJet Printer
Clean uneable 46 brother dcp 130c printer
Hi you can try
This works with most Brother printers
Procedure how to reset the error 46 error (unable to clean). This can be done on every Brother inkjet machine with a numeric keypad.
- Machine off
- Switch on the machine while holding down the “menu” button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press “99” to exit the maintenance mode
Now you are able to print again, but actually your ink absorber box is now full with ink. Ink flooding can happen if you don’t replace this ink box
Also can try.
Reset code.
Press menu then*2864 within 2 seconds (maint should be on the display and all the lights should be flashing, if not try again) press 80
then keep pressing black/mono start button until screen displays ‘purge count’
press 2783 to reset purge count
press stop/exit key
press 99
machine should return to normal
All the best Pineworks
Apr 28, 2010 | Brother DCP 130C All-In-One InkJet Printer
Clean unable 51 it says check trouble shooting and routine mainta
Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 20, 2010 | Brother DCP 130C All-In-One InkJet Printer
How to fix clean unable 46, pls tell me how
This is for the mfc5440 but should work I would really need the cleaning absorber pad replaced but takes a bit of getting to. - Machine off - Switch on the machine while holding down the ?menu?button until all the leds are flashing on/off. Now you are in ?maintenance? mode. - press 80 - press the ?mono start? button several times until you see ?purge: xxxx? - press ?2783? in order to reset the purge counter. You will see: ?purge:0000? - press the "stop" button. - press ?99? to exit the maintenance mode.
Jun 12, 2009 | Brother DCP 130C All-In-One InkJet Printer
Clean unable 46
All you need to do is to reset the purge counter. These steps worked in MFC620CN/420CN/410CN/210C/240C and FAX2440C model. To reset purge counter
1) Enter machine maintenance mode (on MFC240C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine’s log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Apr 23, 2009 | Brother DCP 130C All-In-One InkJet Printer
Unable to clean 46
Aug 23, 2008 | Brother DCP 130C All-In-One InkJet Printer
DCP-130C Clean Unable
- pull out the AC plug
- put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
- now you are entering the MAINTENANCE mode and "error 46" pops up in the display
- select 8 by using the arrow buttons ,push OK and select 0 and push OK
- 00:00 00:01 OK (the display is showing this message)
- now push the MONO button 25 times until you see PURGE: xxxxx
- Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
- the purge counter indicates now: purge: 00000
- switch off the printer ,switch it on
- ready to print
Jan 27, 2008 | Brother DCP 130C All-In-One InkJet Printer
Clean unable 46 : what does it mean ?
IT means you  need to reset the purge counter in order to that .
For MFC - 240c
1.Enter mainatanace mode by pressing menu button at time of switch on. and leve the menu button when fax/scan/copy/photocapture button start blinking
2.press *, 8 & 0 and drag the this submenu by pressing mono button to get "purge" eg (purge:9624)
3.Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
4.Press the Stop/Exit . OFF the printer .and turn it on.
Jan 13, 2008 | Brother DCP 130C All-In-One InkJet Printer
Brother DCP 130C All-In-One InkJet Printer Logo
134 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
