Question about Hammering
Leaking fluid near the bit - Hammering
  • Diane Fraser
    Diane Fraser Mar 20, 2014
    I have a Kango Ballast Tamper Type 990 which is leaking fluid from the end where the bit is secured, particularly when it is hot, I'm looking at what do I need to do to address this issue.
  • Diane Fraser
    Here is a photo of the Kango
  • 20 Answers
Sounds like the seal is worn and needs to be replaced.
Posted on Mar 20, 2014
Brake fluid is leaking
You need to find the source of the leak and repair ASAP. Shouldn't be hard. If its leaking or has leaked fluid, you should be able to find the wet bits and narrow it down from there.
Feb 28, 2016 | Cars & Trucks
4 cyl., 5 speed. Why is it leaking somewhere under the frame - not transmission fluid
Smell the fluid. If it smells like gasoline you have a gas leak. If it smells like antifreeze you could have a hose or a anti freeze cooler line leaking. Or could be a water pump leaking and running along the frame under the car. Get a flash light and crawl under neath the vehicle and see where the fluid is coming from.
Dec 26, 2015 | 1997 Jeep Wrangler
Power steering ford f150
It is just the broken seal which is causing the fluid to leak, replace the seal to avoid fluid leakage.
Jun 09, 2013 | Cars & Trucks
97 ford windstar leaking transmission fluid
Possible leaks are 1. Transmission belly Pan gasket 2. Front pump/torque converter seal. 3. Transmission fluid cooler lines 4. Axle seals at right and left half shafts.
Feb 13, 2012 | 1997 Ford Windstar
Water leaking near top of engine 3.8 Buick Regal LS ?
Wipe any coolant off your engine make sure there is coolant in the car. Run engine for a bit. shut off engine and look for wet spot. Before this see if there are any cracks in rubber hoses or they are loose. It could be a thermostat gasket or warped housing to. Its hard to say without seeing it.
Nov 26, 2011 | Buick Regal Cars & Trucks
I have a 2008 Qlink Pegasus and just had it service,matter fact had to drive 45 miles because that was the only place near that could honor the warranty, they replaced the head gasket that was...
If it is leaking oil out a tube , they may have overfilled it.
I'd be checking the oil level first.
If it is petrol leaking, the float in the carby might be set wrong, or needle and seat might be stuck, or worn out.
It depends what is leaking, but flooding carburetor (petrol) will usually come out a small tube, check the float height, adjustment.
Sometimes a small bit of dirt can jam the needle open, causing flooding.
Good luck
Sep 25, 2017 | 2008 Qlink Pegasus 150
Yes i have a 1999 Oldsmobile Alero and when i got to work this morning i noticed it was leaking quite a bit of red fluid and it smelled a little funny. The leaking did stop after a few minutes but i'm...
SOUND LIKE A TRANSMISSION FLUID LEAK.I WOULD NOT KEEP DRIVING.LOOKS LIKE TRANSMISSION COOLER LINES LEAKING.MORE YOU DRIVE VECHICLE TRANSMISSION PUMPING OUT ALL FLUID FROM BROKEN OR LOOSE COOLER LINES.IF ALL FLUID LEAK OUT YOUR TRANSMISSION YOU WILL HAVE TRANSMISSION FAILURE.BEST TO GET A FRIEND OR COWORKER TO PICK UP YOUR SON AND TAKE YOU TO WORK.GET LEAK FIX DONT DRIVE CAR LOSING TOO MUCH FLUID.TRANSMISSION LEAK FIX CHEAPER THAN BUYING ANOTHER TRANSMISSION COST $2000.00 OR LITTLE MORE.
Oct 28, 2010 | 1999 Oldsmobile Alero
Transmission slipping after changing cracked pan
check the filter for cracks if nothing there look for damage to steel tubes that also run near the filter.
Jul 31, 2010 | 2002 Pontiac Grand Am
Leaking green fluid from right rear near tire of a 2005 town and country. What is it?
most likely coolant (anitfreeze) if it has rear heat pressure test system to find leak hose,clamp,etc...
May 02, 2010 | 2005 Chrysler Town & Country
Leaking transmission fluid
This problem if left unrepaired can cost you thousands of dollars.
Transmission fluid will typically be red in color,,and will leak from near the center of the underside of the car.
Take it into a repair center as soon as you can
Jan 16, 2009 | 2001 Jaguar XJ8
Hammering Logo
397 people viewed this question
Top Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
