Question about eMachines EL1352G-01w (884483537679) PC Desktop
Adding RAM I need to add 2 GB RAM to my desktop. Actually, 4GB since the two shuld be matched. However, I haven't opened the case and wonder how much trouble this will be. Is there a 5 step approach or something?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
First off make sure to check how much ram your motherboard can use make sure the rams also have the same or it will use the lowest speed and besides that make sure you have enough slots and your good to go put them in and your motherboard should pick them up and your done and pls explain more . It's kind of confusing do u have 2GB and want to add 2 more or do u have 4GB excuse me if I don't understand your writing above?
Posted on Mar 20, 2014
  • 1 more comment
  • Bryan Perry Mar 20, 2014
    Meant to say make sure the ram u buy us the same speed as the current ram and also u need to know what type of ram your motherboard takes like ddr3 or ddr2 etc...... If u want I can find this all out for you just post the specifications of your computer if u can
    Actually this is the ram u can usehttp://www.crucial.com/upgrade/eMachines... and for installing it just put the ram in the motherboard and it should pick it up no problem
    But make sure your computer is unplugged :)
Need install more ram
Hi.
you have to use DDR 2 RAM with 800 mhz .
you`re Manuel say`s maximum is 4GB.
maybe a BIOS-Update can help to use more than this 4 GB.
otherwise you need a new Motherboard to fix this.
lg Gue.
Dec 29, 2013 | Shuttle XPC PC Desktop
Tip
How to make Windows Server 2003 Enterprise Edition see more than 4GB RAM
Issue – After upgrading a server to Windows 2003 Enterprise Edition and adding additional memory, the OS still shows only 4 GB of RAM.
Additional Information – Physical Address Extension (PAE)
In Windows Server 2003, PAE is automatically enabled only if the server is using hot-add memory devices. In this case, you do not have to use the /PAE switch on a system that is configured to use hot-add memory devices. In all other cases, you must use the /PAE switch in the Boot.ini file to take advantage of memory over 4GB.
The newer Dell servers are capable of using hot-add memory devices, but the older servers do not.
If you upgrade an older Dell server and are experiencing the issue above, make the following change to the boot.ini file.
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(2)WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(2)WINDOWS="Windows Server 2003, Enterprise" /fastdetect /PAE
Add the /PAE flag to the end of the boot device. Then reboot the server.
After rebooting the correct amount of memory should be displayed
To summarize, PAE is a function of the Windows 2000 and Windows Server 2003 memory managers that provides more physical memory to a program that requests memory. The program is not aware that any of the memory that it uses resides in the range greater than 4 GB, just as a program is not aware that the memory it has requested is actually in the page file.
on Apr 19, 2010 | Computers & Internet
My Gateway DX300X desktop is super slow and only has 0.99 GB of RAM. How do I install more?
According to specs, your computer can use up to 4Gb of memory. You will need to open the case and see what is currently installed. You should have 4 memory slots and probably it came configured with 2 512Mb memory sticks. You could add 2 more sticks of 1Gb each bringing your total up to 3Gb, but my suggestion would be to remove the existing memory modules and install 4 matching 1Gb modules. You must use DDR2 PC2-5300, DDR2 (non-ECC) type memory and the best results will be achieved by using all matching modules.
Oct 21, 2013 | Gateway DX300X PC Desktop
Can I add 4gb more RAM
see:http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay/?sp4ts.oid=5295969&spf_p.tpst=kbDocDisplay&spf_p.prp_kbDocDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c03536888-9%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken
probably no, 32 bit systems have an under 4Gb limit. looks like 2 memory slots 1,2,4 and 8Gb supported.
Memory upgrade information
  • Dual channel memory architecture
  • Two 240-pin DDR3 DIMM sockets
  • Supports DDR3 DIMMs
    • PC3-10600 (1333 MHz)
    • PC3-12800 (1600 MHz)
  • Non-ECC memory only, unbuffered
  • Supports 1 GB, 2 GB, 4 GB and 8 GB DIMMs
  • Supports up to 4 GB on 32-bit* systems
  • Supports up to 16 GB on 64-bit systems
Aug 29, 2013 | HP Pavilion P6 Intel Pentium Processor,...
Installed 4GB upgrade in optiplex 330 still only 2GB memmory
Your BIOS should automatically detect your new RAM when your computer starts, try starting your computer after removing your old RAM module, if it starts, you need to update your BIOS to use 4GB. If it doesn't start, you either have a faulty RAM module or a faulty connector on your motherboard. Insert the new RAM module into the slot the old RAM module was in, if your computer still refuses to start, you have a faulty RAM module which should be returned, if it does start, it's the connector on the motherboard, and only replacing the entire board will fix the problem. However, it's worth noting that your motherboard will only support RAM modules of 2GB or less, the above was written with the assumption you're adding an additional 2GB module to your Dell computer.
Dec 24, 2011 | Dell OptiPlex 330 Desktop Desktop Computer...
Dell precision 670. Adding 8 gb total memory. Using Kingston KX1563-NAB; DDR2 2gb 2Rx4 PC3200 EEC, registered. Accepts 4 gb in dimms 1 and 2 (2 gb modules) and boots fine. Adding 4 more gb in dimms 3...
glenn_mullin
From what I can tell the Dell Precision Workstation 670 does support over 4GB of RAM. However when you have over 4GB of RAM installed in the system you have to have the Memory Cooling Shroud connected to keep the memory cool. Also this is only shipped out when the system is ordered with over 4GB of RAM originally. If you do not have this part you can order it from Dell buy calling 877-671-3355.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Jan 27, 2011 | Dell Precision Workstation 670 PC Desktop
How much maximum ram does acer aspire 4520 support? and is it fine if we have one ram of 2 gb and the other of 1 gb?
Your machine currently has this ram (1GB DDR2 667 SDRAM)
You can upgrade to 4GB DDR2 800MHz ram, sell old one off.
If you use old ram you must exactly match to old in speed, ie 2GB ddr2 667 SDRAM.
I recommend renew with matched larger faster ram 2 + 2 GB DDR800
Dec 18, 2009 | Acer Aspire 4520-5141 Notebook
How to add memory to my pc gm5472
You need to open the case and see how many sticks of memory are in the slots. Your machine should come with 2GB. (probably 2 1-GB sticks)
If you are running a 32-bit system, it's useless to increase the memory above 3 GB, as the system will not see it. For a 64 bit system, you can add a lot more.
Sep 25, 2009 | Gateway GM5472 PC Desktop
Want to add memory to Gateway 700x
Max memory is 2GB, i.e. 1GB per slot(DIMM), so you will need 2 X (SimpleTech 1 GB PC3200 400MHz DDR RAM). {Always use matched pairs only}
Visit this link : http://www.simpletech.com/upgrades/gateway/700x/700xddrintelp428ghz/
.................sodeep
Mar 31, 2009 | Gateway 700 X PC Desktop
How to change add RAM to Acer Aspire
first check with www.acer.com to see that expansion is possible.
all computers like their memory upgrades in sets, instead of singles(like changing both front tires on your car or truck)..so compatibility among the two is more vital than matching to existing ram cards.
Feb 17, 2008 | Acer Aspire 5500 5570-2609 Laptop
eMachines EL1352G-01w (884483537679) PC Desktop Logo
74 people viewed this question
Top eMachines Computers & Internet Experts
brian soufane
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
