Question about Conair Infiniti Pro Titanium Tourmaline Ceramic Heat 1 Inch Flat Iron CS72
Says error and turns off
When i turn it on it heats up and then within a minute of use it will read error and turns off
    New Friend:
My infiniti pro conair turns on & then turns off by giving me an error
Posted on Oct 28, 2017
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display Abnormality / Protection control Abnormality
Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica
tion > 1 min after starting
operation Indoor fan operation
only • Internal / external cable connections
• Indoor / Outdoor PCB H14 Indoor intake air temperature sensor
abnormality Continue for 5 sec. - • Intake air temperature sensor (detec
tive or disconnected) H15 Outdoor compressor temperature sensor
abnormality Continue for 5 sec. - • Compressor temperature sensor
(detective or disconnected) H16 Outdoor Current Transformer open cir
cuit - - • Outdoor PCB
• IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance
continuously - • Indoor PCB
• Fan motor H23 Indoor heat exchanger temperature sen
sor abnormality Continue for 5 sec. O
(Cooling only) • Heat exchanger temperature sensor
(detective or disconnected) H24 Indoor heat exchanger temperature sen
sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor
(detective or disconnected) H27 Outdoor intake air temperature sensor
abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec
tive or disconnected) H28 Outdoor heat exchanger temperature
sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature
sensor (detective or disconnected) H30 Outdoor discharge air temperature sen
sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec
tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance
• Ventilation motor H51 Nozzle lock abnormality 2 times occurance
continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance
within 30 minutes - • Indoor PCB
• Fan motor H98 Indoor high pressure protection - - • Air filter dirty
• Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro
tection - - • Insufficient refrigerant
• Air filter dirty F11 Cooling / Heating cycle changeover
abnormality 4 times occurance
within 30 minutes - • 4-way valve
• V-coil F90 PFC control 4 times occurance
within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance
within 20 minutes - • No refrigerant
(3-way valve is closed) F93 Compressor rotation failure 4 times occurance
within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance
within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro
within 30 minutes - • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor) F97 Outdoor compressor overheating protec
within 10 minutes - • Insufficient refrigerant
• Compressor F98 Total running current protection 3 times occurance
within 20 minutes - • Excess refrigerant
• Improper heat radiation F99 Outdoor Direct Current (DC) peak detec
tion 7 times occurance
continuously - • Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
Oct 13, 2017 | Panasonic Heating & Cooling
Why does my dryer starts but turns off within 1 minute with error code 1-5 or E 5
First, I'd check to see if the vent is clogged. The dryer has a safety feature built in so that if heat builds up too high, the unit shuts down (to prevent fire). IF it is not the vent, then it is probably a faultly thermistor - this is the switch that reads the temp. These frequently go bad and are pretty easy to fix. Check out one of the appliance repair web sites for parts and repair video.
Aug 30, 2014 | Dryers
Our Rinnai Avenger 25 automatically switches off within 1 minute. When we press the on button, the unit starts with a green light on the "ON" button but within seconds, the light turns to red and soon...
Did you get any error codes? Press on/off button twice to reset heater or
press both the Up and Down buttons simultaneously for 3 seconds
It can also be a faulty temperature sensor, this would need a service call...cheers
Jan 21, 2018 | Rinnai Vent Free Gas Heater/
Frigidaire Gallery model GLEQ2170KSO dryer turns off within a minute.
Hello allisonarena - Try reprogramming the dryer by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and then turn on the unit. If issue persists, then the dryer may possibly be experiencing more serious issues such as; wiring failure, faulty control board, thermal limiter, or defective door switch. I would recommend connecting with an experienced appliance repair tech to assist further and to reduce the risk of unnecessary parts.
Jun 12, 2013 | Frigidaire Dryers
I got an "IE" error message. Anyone seen that before?
Water inlet error. Cause : Correct water level (246) is not reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes
Check/Repair
Ensure your taps supplying the washing machine are turned on.
Oct 20, 2010 | LG WM-2277HW Front Load Washer
Low heat error
the fuser lamp is likely blown, if you turn it on and leave it for a few minutes and then feel the back access door and it is cold you will need a new fuser lamp
Nov 12, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Reads open heat error
This sounds like a problem with the fuser or possibly the fuser lamp. You can try turning the printer off for about ten minutes to cool the machine off and then turn back on. If that doesn't work you would need a new fuser unit. The fuser is located behind the door on right side of the machine. There are four screws used to hold the fuser in place. Good Luck, I hope this helps.
Aug 21, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Conair Infiniti Pro Titanium Tourmaline Ceramic Heat 1 Inch Flat Iron CS72 Logo
267 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
