Seiki bd 660 it thinks it has a disc in it but it does not it wont play anything because of it
Seiki bd 660 i turn it on it shows the logo then starts to play but there is NO DISK IN THE PLAYER. i cant hit stop it just sits on a black screen and cant do anything but shut it off or open the tray
SOURCE: sanyo 6100 dvd player-disc tray automatically opens whenever power is on.
Have you checked to see if it is off track? Sometimes when these machines get bumpbed, dropped, or fall they can jump track. You have to take the cover off and inspect to see if it is off track when it closes and opens. It should go all the way back on the track when it closes. Be careful not to shock yourself. If it is on when you do it and your hand touches the metal parts inside you can get seriously burned or shocked.
Posted on Jan 18, 2007
  • 1153 Answers
SOURCE: DVD player isn't showing anything
do you hear movement inside like disc rotating, if so then the switch that closest lid is damaged. This is when you fold dvd down it hits this switch to turn monitor off. It could be damaged. If there is no noise or movement then power supply has damaged or batt dead and no power goes to it from power cord.
Posted on Aug 22, 2007
SOURCE: Disk wont open or close
well i had the same problem with my xbox is i opened the faceplate and pressed the button and if that doesnt work u will have to wiggle it around a little bit if it comes out what u need to do is take some WD-40 and spray some on a cloth or something to wipe the sides of the tray and the silver part of the tray and open and close it a couple of times if it opens and closes put the faceplate back on and it should open and close now
Posted on Nov 23, 2007
ctf1800
  • 4402 Answers
SOURCE: DVD tray WONT OPEN
unplug it and try it again, if that doesn't work see if theres a pin hole where you can push a paper clip in by the tray area.
Posted on Feb 26, 2008
SOURCE: pioneer muti-disk dv-c503 dvd/cd player carousel wont saty open
When i put a cd into the tray the door will close. It will say its loading but then the cd tray will reopen again not allowing the cd to play.
Posted on Mar 08, 2008
My samsung bd-p1600 will not play blu ray movies
If it plays other Blue Ray discs OK then either the disc is faulty or it is the wrong region. If it previously played, then my bet is that the disc has a scratch or dirt on it. If you have another blue-ray player or you have a friend with one try it on that or theirs.
Jul 31, 2016 | Samsung Televison & Video
Blu ray shows the "Blu ray Disc" Logo on TV screen and then just show a black creen
Hi! and welcome to Fixya!
It looks like your tv is unable to handle the output video resolution from your bluray. The reason why you do not have picture on the tv screen after the bluray disc logo appears.
You can follow the instruction below to set the video resolution on your player to its lowest resolution:
1. Using your bluray remote control, press the following buttons in order... STOP button (press and release) ....HOME button (press and release)....POP UP/MENU button ( press and release )
Note: press the buttons in order with 1 second interval. Make sure tv and bluray are ON when you try this. If first attempt nothing happens, try this again.
2. When the home menu screen appears after doing the above instruction, you can set the video resolution again manually. Follow the instruction:
Using the BD remote control press HOME button > then go to SETUP > select screen settings > then change OUTPUT VIDEO RESOLUTION to Auto > change also 24P OUT to 1080P // set the BD-ROM 24P OUTPUT to Auto
The next time you turn on the bluray player you will have picture again.
Let me know if this works!
Oct 24, 2015 | Sony Televison & Video
Seiki bd600 thinks there is a disk in it
Press and hold eject button and see if that helps.
Mar 20, 2014 | Seiki Blu ray Player SR212S - CAM CONSUMER...
How to play movie
first thing you may want to check is to see if your disks play automatically. go to settings>system settings>disc auto start (its about mid way down). make sure that is marked "ON" If its not just press "X" on disc auto start and you should have option to turn it "OFF" and "ON". with that set every time you put in a disc it should auto start.
if that doesn't start automatically the title of your BD should be under VIDEO and it should be the one on the bottom. if it doesn't show up there you should check to make sure the disk is able to be read. try it with another DVD/BD if those show up and your first disk don't than you know you have a faulty disk. hope this helps
Oct 22, 2011 | Sony Playstation 3 (PS3) Console
I have a friend who has a PIONEER Bluray Player BDP LX52.Despite having updated it to the latest firmware(3.71)it is not playing the RED(Morgan Freeman,Bruce Willis)Bluray.Sometimes he gets the menu and...
The firmware update needs to be done again.
Follow the steps below to troubleshoot if the BD player cannot read or play a disc:
IMPORTANT: Prior to following the steps below, go to the Drivers & Software section of the Pioneer eSupport Web site to check for available firmware updates. If a firmware update is available, it will be posted there with a list of improvements over the original or any previous firmware version. Some disc playback issues may be resolved by ensuring the BD player has the most current firmware installed.
  1. Ensure the Easy Setup procedure has been completed on the BD player. NOTE: Can't play DISC may display on the LCD screen if the Easy Setup procedure was not completed first.
  2. Ensure the inserted disc is compatible with the BD player. NOTE: Consult the instruction manual of the BD player for a list of compatible discs.Manuals are available online through the Manuals/Specs/Warranty link on this page.
  3. Select BD players may require that a USB memory device has been properly inserted into the EXT slot of the player prior to playing the movie. If the BD player being used does not have an EXT input, skip this step. NOTE: The USB memory device may need to be re-formatted to FAT32 format prior to inserting it into the player.
  4. Use a soft cloth to clean the disc.
  5. Examine the disc for any cracks or scratches that might be interfering with playback.
  6. Wipe the top of the disc tray using a soft dry cloth before placing the disc on the tray. Attempt to play the disc again.
  7. Attempt to play another disc. Remove the disc from the BD player.
  8. Turn off the BD player.
  9. Unplug the power cord of the BD player from the electrical outlet.
  10. Let the player remain without power for 1 minute.
  11. Plug the power cord back into the electrical outlet.
  12. Turn on the BD player.
  13. Insert the disc into the BD player.
  14. Attempt to play the disc.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required
Apr 08, 2011 | Pioneer BDPLX52 BluRay Player
My samsung bdp1000 wont play blu ray discs
I DOn't know the answer BUT the Samsung site has firware updates which might help you. Take a look:
http://www.samsung.com/us/function/search/resultList.do?searchWord=BD-P1000
Make sure you copy the entire link. I hope this helps. Let me know
Mar 31, 2008 | Samsung BD-P1000
Won't play PS3 games
u might want to go online and type clean discs the clean ur discs and they start working again orgo into game and they give u a new ps3
Jan 12, 2008 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
Top Televison & Video Experts
