My son sat up a passcode pattern for his tablet and then forgot it. Is there a way of reseting it? I tried the reset button on the back, but it didn't do anything.
One opiton you have is to overwrite the current setup on the tablet. The download for the firmware file can be found at Proscan site here: http://www.curtisint.com/html/custservice/manuals/PRO_PLT7223G_FIRMWARE.ZIP Unzip the files on your computer and extract the contents to your desktop. Now, use the micro usb cable that came with your tablet and connect one end on your tablet first, leave the computer end open for now. Find the small pinhole next to your tablet`s usb port and use a small pin to press it, while plugging the cable to your computer. Your PC should now say finding a new USB device. From the list, select iRockusbDriver from the folder to install the driver. From here, run the RKbatchTookl.exe file that was extracted. On the choose file path screen, select Update.img and click on Upgrade. The process should only take a few minutes and your tablet will be reset when done.
