Question about Minolta EP4000/5000 CS/PRO Copier
Minolta 4050 giving error code c0160. and noiw not going ahead of welcome screen
First it gave code c0160 and after while it totaly stopped and now only welome is displayed and nothing else
    New Friend:
My problame is screen welcome aption is not going .
minolta 4050 giving error code c0160. and noiw not - 7_27_2017_5_15_18_am.jpg
Posted on Jul 27, 2017
  • Minolta Master
  • 1,297 Answers
The C 0160 code not exist in Minolta EP 3050-5000 series.If the real code is C0610 refer to lens motion failure.Check the mirror reference position sensor and lens reference position sensor.Unplugged and plugged the connectors. minolta 4050 giving error code c0160. and noiw not - 3331bbd5-f151-4464-a6c0-bf018f48f2bd.jpg
Posted on Mar 26, 2014
Cogz
  • 1326 Answers
SOURCE: I've got a Minolta model #4050
Yes, it means that something is wrong with the scanner. It may be fixed, it depends what is wrong with it. Is the scanner skewed under the copyboard glass? If so that means that the scanner cables have poped off and they will need to be restrung. It could also be the scanner drive motor or the driver PCB. It may also be that the scanner HP sensor is dirty or is not working correctly. I have worked on these models for years and most of the time it has been a sensor or the cables poped off. There is a jig that makes it easier to restring the cables, but either way it will take time and time is money.... Question is are you willing to put the money in to it?? This model came out around 1995 or so... Good Luck
Posted on Apr 16, 2009
  • 11 Answers
SOURCE: minolta cspro 4050
corona leak to ground - chk. c corona spool
Posted on Jul 30, 2009
team leader
  • 40 Answers
SOURCE: I have a minolta 4050
thers fan for transport motor this fan not working fine check it
Posted on Sep 01, 2010
wheatlandsvc
  • 1110 Answers
SOURCE: I have a Minolta CSPro
C0d50 means you have a duplex error. This would be coming from the duplex drawer just under the main front door. You must open then close the duplex drawer to reset this code. It can not be reset by opening/closing the front door as with most other codes. Most of the time the c0d50 code will reset by opening/closing the duplex drawer. If not you will need service on the drawer as there is a drive or sensor problem in the drawer. The guides in this drawer have to jog in and out for different paper sizes and orientations. This code is usually causes by a failure of the guides to move properly.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Nov 29, 2010
  • 1297 Answers
SOURCE: I have a minolta 4050 that is showing a 601 error
SC 601 = SCP board PWB J malfunction or scanner motor malfunction.Scanner motor located in rear parts right side and the PWB J panel in the right side of copier.Try open and closed the front door,push the trouble reset switch,if the error code persisit change the scanner motor or PWBJ.Move the scanner manually,turn ON the power switch,if the scanner exposure lamp move,working the scanner motor is OK.Check the scanner home position sensor.
Posted on Jan 05, 2012
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
How to reset error code d370 on konika minolta c450 machine
1. Touch the following code on the trouble code display screen.
(buton) Stop 0 7 1 3 9
2. [*] will be displayed on the trouble code screen.
3. Touch [*].
4. The screen will be shifted to the data restoration screen to perform data restoration.
NOTE
• When the restoration is performed in a short time, data restoration screen may not
be displayed.5. Check the message which indicates that the data restoration was successfully conducted.
Turn Main power OFF, and wait for ten seconds or more to turn it back ON
GOOD LUCK
Jan 12, 2015 | Minolta Office Equipment & Supplies
Kyocera service codes
It's a firmware mismatch error did you just replace the touch screen or the whole control panel
Aug 25, 2014 | Kyocera Km-4050 With Feed, Finisher, Bank,...
I have a minolta 4050 that is showing a 601 error code
Oct 30, 2011 | Minolta EP4000/5000 CS/PRO Copier
I have a problem with my Minolta CSPRO EP 4050. The message is: A malfunction was detected. Call for service and provide the code C0500. Any help appreciated.
try to reset the error to reset that error is open the fron door & you will see a small cover square shape with a lock of 1 screw just remove the screw then you will see the reset botton
Nov 24, 2010 | Office Equipment & Supplies
Minolta bizhub 162 error code 32
In Konica Minolta bizhub 210,162,211,163,182, error code "cof32" means "Automatic toner density control abnormality.
To remove this code or you want to get rid of this problem, simply call your technical service representative to solve this problem.
If you want to remove this code by yourself then please perform these actions attentively.
1-Turn the machine ON.
2-Press "Utility" button on front panel.
3-Now press these buttons "stop+0+0+stop+0+1" it means press stop button, then press 0,again 0, then again press stop button, then press 0, and 1.
4-service mode will appear on LCD screen.
5-Now with the help of arrow keys go to the 2nd option which is "ADJUST"
6-Now press "YES" button.
7-Again by pressing the down side arrow key go the option which is "ATDC ADJUST".
8-Press YES button.
9-Now increase the value, for example if the value is 145, you have to enter 155 or 160.enter the value with numerical key pad buttons.
10-After entering the new value press "YES" button.
11-Restart the machine.
Oct 04, 2010 | Konica Minolta bizhub C351 All-In-One...
I have a minolta 4050 that is showing a c0040 error code
Aug 23, 2010 | Minolta EP4000/5000 CS/PRO Copier
I have Minolta 4050 CsPRO and i am getting the code of CF301 how should i resolve it.
Hummm... There was a COF31 code which popped up when the machine was run with no toner. This caused the toner to carrier ratio to drop so low that even when you decided to put a new bottle of toner in the machine still could not recover. If that's what happened, your looking at doing a developer change.
Jun 30, 2009 | Konica Minolta Office Equipment & Supplies
Ep2080 minolta cspro
Ep2080 minolta cspro error code comes up with c0500
Dec 06, 2007 | Minolta EP4000/5000 CS/PRO Copier
75 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
