Question about LIS 52650 Harmonic Balancer Installer
On the harmonic balance, is the bolt holding it on, left or right handed threads
How to keep engine from turning when trying to remove
  • 20 Answers
A simple block wedge in the fan belt at the harmonic balance can prevent it spinning.
Posted on Mar 20, 2014
Is it right hand or left hand thread on a toyota 2.7 engine harmonic balance crank bolt?
right hand thread but very tight,usually need to use air gun or lock engine and use big bar amd socket
Oct 29, 2017 | Toyota Cars & Trucks
Which direction do i turn the harmonic balancer bolt to remove it on a 1997 honda civic 1.6 liter
Hi:
The harmonic balancer bolt is a normal bolt with right hand threads, so you need to turn it counter-clockwise.
The hardest part of the process is to keep the crankshaft from turning. An impact wrench is the easiest way to go, but if you don't have one, you can use a large strap wrench or chain wrench to hold the harmonic pulley. I use a section of an old belt to protect the pulley.
Aug 03, 2014 | 1997 Honda Civic
Harmonic balancer bolt on 2001 impala
Looking at the front of the engine, the harmonic balancer turns clockwise when running. You will need to turn the bolt anti clockwise as it is a normal right hand thread.
Mar 17, 2014 | 2001 Chevrolet Impala
Harmonic balancer bolt turn left or right to remove
Right hand thread righty tighty lefty loosey. some require a impact wrench 1/2 or 3/4 drive to loosen if either not available the install socket with breaker bar leaving 6 inches of slack between bar and frame crank engine sometime this will loose bolt. you hear a BIG bang as it loosen.
Nov 07, 2013 | 1995 Lexus ES 300
How do i remove harmonic balancer & replace
YOU NEED A HARMONIC BALANCER PULLER TOOL AND A 15M SIX POINT SOCKET TO REMOVE HARMONIC BALANCER BOLT.TURN OFF RADIO AND REMOVE THE DRIVE BELT AND REMOVE THE NEGATIVE BATTERY CABLE. REMOVE THE STARTER SO YOU CAN PUT A LARGE SCREW DRIVER OR LARGE PUNCH TO STICK IN ONE OF THE FLY WHEEL HOLES TO KEEP ENGINE FROM TURNING WHEN YOU LOOSEN THE HARMONIC BALANCE BOLT. ALSO SCREW DRIVER AND PUNCH CAN KEEP ENGINE FROM TURNING WHEN REMOVER THE HARMONIC BALANCER. YOU WILL NEED A HELPER TO HOLD PUNCH OR SCREW DRIVER WHILE YOU LOOSEN THE BOLT. YOU CAN GO TO SEARS OR ANY AUTO PARTS STORE AND BUY HARMONIC BALANCER PULLER.TORQUE HARMONIC BALANCER BOLT TO 76 FT LBS.
Apr 23, 2011 | 2003 Pontiac Montana
Is it right or left hand thread on harmonic balancer (1996 rodeo)
The harmonic balancer should loosen in the CCW direction. Turn the bolt to counter clock wise direction.To tighten the bolt turn in clock wise direction. -------------- This should help.Thanks.Helpmech.
Apr 06, 2011 | 1996 Isuzu Rodeo
Can't get the crank pulley loose. is it left our right threads. i am replacing the water pump.
TURN CRANKSHAFT BOLT COUNTERCLOCKWISE TO LOOSEN. YOU HAVE RIGHT HAND THREADS.ENGINE TURNING CLOCKWISE.YOU NEED A STRAP WRENCH HOLD CRANKSHAFT PULLEY WHILE LOOSEN IT.BUT YOU NEED A CRANKSHAFT DAMPER REMOVAL TOOL.OR HARMONIC BALANCER REMOVAL TOOL.YOU NEED STRAP WRENCH TO HOLD CRANKSHAFT PULLEY WHEN TIGHTEN IT.TORQUE CRANKSHAFT PULLEY BOLT 90 - 98 FT LBS. MAKE JOB EASIER.HAVE A HELPER HOLD STRAP WRENCH WHEN YOU LOOSEN OR TIGHTEN CRANKSHAFT PULLEY.
Sep 19, 2010 | 1995 Mercury Villager
How do i remove the harmonic balancer bolt to replace the timing cocer gasket on a 1999 ford tarus se
If there is no air-compressor and an impact gun to remove the harmonic balancer bolt, then there are two other ways to remove it. Either remove the inspection cover at the bell-housing and use a large flat head screwdriver to wedge between the flex-plate drive gear teeth and the engine block so that the engine is locked-up, and then remove the harmonic balancer bolt with a long breaker bar and a lot of muscle power, or for the more advanced mechanics and only they should attempt this, place a long breaker bar on the harmonic balancer bolt and then brace the breaker bar up against the frame of the vehicle so that when the engine turns over the breaker bar will stop on the vehicle frame, and keep in mind that the crankshaft will turn clockwise or to the right, and when you are looking for some place to brace the breaker bar be sure that nothing else will get in the way or it will be damaged. Be sure that the breaker bar is on the harmonic balancer bolt properly, and place the breaker bar about 1 to 2 inches from the vehicle frame so that when the engine turns the breaker bar will lock up against the vehicle frame, and while holding the breaker bar in place have someone turn the ignition key and give the starter a bump, and be very sure to keep your hand away from where the breaker bar is going to contact the vehicle frame, or your fingers will get smashed by the breaker bar when it turns into the frame so do not attempt this if you are unfamiliar with using hand tools, and the starter should break the harmonic balancer bolt loose easily, so be very sure that your hands are out of the way of getting hurt when the starter motor is used to break the harmonic balancer bolt loose.
Sep 13, 2010 | Ford Taurus Cars & Trucks
LIS 52650 Harmonic Balancer Installer Logo
59 people viewed this question
Top Lisle Vehicle Parts & Accessories Experts
Kar Volk
Rigger
charles
Are you a Lisle Vehicle Part and Accessory Expert? Answer questions, earn points and help others
