Question about Cybex International CYBEX LCX425T Treadmill
When walking near the front of the treadmill I hear thumping near the back of the treadmill. When I step further back, the noise goes away.
Is this something We can fix on our own?
    Problem Solver:
  • 50 Answers
Your rubber bushings under the board can be warn but first check the bolts near the back of the board that mount to swivel brackets they have a tendancy to loosen
Posted on Jun 26, 2014
My new nordictrack 1750 is squeaking.
Talk to the manufacturer or take it back. It should not do this if it is brand new.
Jun 10, 2017 | Cars & Trucks
Thumping from motor reebok treadmill
Seem like your front roller bearings are knocking. Remove the drive belt. Turn machine on. Replace roller if noise goes away with drive belt off.
Jan 02, 2014 | Reebok Competitor RT 5.1 SpaceSaver...
How to replace the walking belt on Weslo cadence dl15 Treadmill
Installing An Icon Fitness Treadmill Belt- No Exposed Roller Bolts
You can save yourself a great deal of time by following these instructions as opposed to those of the manufacturer. Please contact us if you need any further help. UNPLUG THE TREADMILL BEFORE DOING ANY REPAIR!
Step #1- Before unfolding the treadmill, disconnect the lift shock from the ball joint. Most have a small retainer clip that can be pulled with a small flathead screwdriver and then the shock can be removed from the ball stud.
Step #2- Unfold the treadmill and then remove the three wiring connectors for the incline motor and then one of the incline motor mounting bolts.
Step #3- There are two shoulder bolts that hold the entire motor tray in place. These are at the back of the motor area and must be removed to gain access to the front roller bolts. Remove the two shoulder bolts and then you can pull the motor tray slightly forward or backward to gain access to the roller bolts.
Step #4- Follow the replacement instructions included with the walking belt.
Step #5- Reverse the process of step one, two, and three to reassemble the treadmill.
http://www.treadmilldoctor.com/installation?utm_source=fixya&utm_medium=cpc&utm_campaign=mendi
Jun 26, 2012 | Weslo Cadence Dl15 Treadmill Walking Belt...
My proform 590 treadmill has these problems ; belt slips when running or walking ,speed goes up and down does not stay constant and you can hear motor noise increasing and decreasing in motor what should...
simple(maybe). go to the rear of treadmill,get the allen wrench that came with it,run at med-slow speed and adjust the rear roller with allen wrench. 1 turn per side 2 or 3 time then walk on belt until wont slip. all the problem is belt tension. also. make sure if it need lubrication under board and belt(some are lubless others dont).
good luck to you.
Feb 08, 2011 | Treadmill Doctor Proform 590Qs Treadmill...
Instructions for changing the walking belt on my Cadence DX15 treadmill
1. Unplug the treadmill and remove the motor hood.
2. Use a permanent marker like a Sharpie and mark the roller positions on the bolt on the front roller and bolts on the rear roller- not all front rollers have this adjustment bolt.
3. Loosen the walking belt at the rear of the treadmill.
4. Remove the front roller adjustment bolt.
5. Some higher end treadmills use straddle covers that have an undermount or slide mount. If you don't see staples or bolts on the top of the cover, do not pry them up. If you do have one stapled or screwed down, use a flat head screwdriver or similar instrument, pop the plastic deck cover on the right hand side up (if you are standing on the treadmill like you are using it, the deck cover on the right side). If you see screws, simply unscrew and remove the screws. Screws are included to reattach the cover near the end of installation.
6. Remove the deck boltsmost have 3 or 4 bolts.
7. Once the deck is loose on the right side, completely remove the screws from the rear roller. Be careful with the plastic endcaps. The endcaps and the roller need to be removed in this step.
8. One person should hold the deck up and hold the front roller in position near the pulley while a second person removes the old walking belt (some models that do not fold and a very few number that do have a side handrail on the right side that attaches at the base of the treadmill…if yours does, remove this handrail before removing the belt). If you are talented, you can do this with a single person.
9. With one person holding the deck up and holding the front roller in position near the pulley, the second person should reinstall the new walking belt. Once the belt is in place, raise the deck up again and look underneath to make sure the belt is in the center of the belt guides that stick down from the deck underside. When tensioned, the belt guides should make the outside edges of the walking belt turn toward the center of the belt.
10. Replace the rear endcaps and rear roller and start the rear roller bolts. DO NOT TIGHTEN THE REAR ROLLER BOLTS IN THIS STEP.
11. Refasten the deck bolts. Go ahead and tighten the deck bolts fully in this step.
12. Refasten the front roller bolt and return it to the marked position (it was marked in step 2).
13. Replace if you have undermount straddle covers or fasten the plastic side deck cover with the enclosed screws if yours were screwed or stapled down. Removing the staples in the deck with a pair of pliers before reattaching the deck cover is not required but will make it easier to reattach.
14. Retighten the walking belt to the marked positions on the rear roller bolts.
15. Check the walking belt for proper tension by lifting it 2” to 3” in the center of the belt.
16. Test the treadmill for slippage and make adjustments (if needed) for lateral centering or tracking.
17. Once the belt tests good, replace the motor hood.
Feb 17, 2010 | Exercise & Fitness
Proform 400GI Treadmill making a very loud noise, which is worse when using speeds between 2.7 and 3.1, noise is so loud can't hear tv when turned up to full volume. It makes the noise without anyone...
This definitely sounds like the drive motor. One way to check is to remove the drive belt and run the motor without the walk belt connected. Obviously if you still have the noise it will be a motor issue. If not then it will be one of the 2 rollers. Good Luck! Tim
Nov 04, 2009 | Proform 490GS Treadmill Walking Belt
With every step I get squeak / chirp while running on treadmill.
Check the knob used to hold it up in the folded position. While running, have someone pull it to the out position. That was the problem on mine. If it is, a little grease on the end of the rod should do it.
Jul 23, 2009 | Exercise & Fitness
Scraping pulse noise r front merc sable
Check the condition of the wheel bearings, front and back side if the brake rotor, and the back side of the rim. Everything should be clean, rust build-up can throw everything out of true. The hub or wheel-bearing should be tight and smooth when spun.
May 12, 2009 | Mercury Sable Cars & Trucks
Weslo pro tread belt
Hi, Yes it is! the belt is not free floating but travels on a slide. When there is pressure on it ( from someone) it rubs on the slide underneath. When you step off it should stop the rubbing noise. There you go, this should Fixya!
Mar 24, 2009 | Weslo Pro Crosswalk 7.8 Treadmill
Rhythmic thumping noise with increased speed
The problem is the rear roller has a bad bearing and needs to be replaced
Mar 11, 2009 | Bowflex Treadmill Series 7
Cybex International CYBEX LCX425T Treadmill Logo
87 people viewed this question
Top Cybex International Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Cybex International Exercise and Fitnes Expert? Answer questions, earn points and help others
