Question about Kodak ESP 5 Printer
Error code 3527 kodak 5320 printer/scanner
Code says to clear obstruction, but there is NO obstruction
SOURCE: Kodak EasyShare 5300 Printer error message
Ten Step Process to Fix the "Print Head" Error Message on the Kodak 5300 Printer.
1. Clear a good spot it your back yard that is free of shrups and flowers.
2. Get the following tools: Flat head screwdriver, shovel, sledgehammer.
3. Dig 24" x 24" hole in your back yard and rope off the excavation area for safety.
4. Whaaaaack the heck out of the Kodak 5300 with the sledgehammmer until such time that it is not a recognizeable piece of electronic equipment.
5. Stab it with the flat head screwdriver, just in case it has the Terminator syndrome (comes back to life).
6. Throw the piece of garbage in the recently excavated hole in your back yard.
7. Cover up that useless piece of garbage and forget you ever owned it.
8. Get in your car and go to the nearest electronic store and ask to speak to the manager.
9. Ask if they sell the Kodak 5300 printer. If so, whack him with the shovel. You don't want to seriously injure him so don't even consider the sledgehammer of the screwdriver. After all, its not his fault that his company carries such garbarge. But the whack is just to burn off some steam from your frustrations.
10. Purchase any other printer but a Kodak and live happily ever after.
Posted on Jul 13, 2008
shockwave727
  • 262 Answers
SOURCE: Scanner motor move failed error code 6202
6202 error code means that the scanner motor failed
to solve this
-Open the printer access door of your printer
-Unplug power cable
-then after 30secs plug the power able back
-If the printer is already power-up the message printer access door will appear
-Close th printer access door
-try to scan or print
If this issue not solve call tech support of kodak Toll free 1 800 421 6699
Posted on Nov 08, 2009
  • 1218 Answers
SOURCE: Kodak Easy Share 5300 Printer error Error
Error code "6203" can be resolved as follows:
First, you need to open the access door of the printer and disconnect the power adapter from it.
You then need to wait for at least 30 seconds for the printer to get reset.
As a next step, you can connect the power adapter back to the printer.
You can turn on the printer, if required. Once the printer gets powered up, a message "Printer access door open" gets displayed.
Once this message gets popped up you can close the access door of the printer. get more help for Printer Error Code 6203
Hope this helps you.
Posted on Sep 20, 2010
SOURCE: my kodak copier model esp3250 shows an error code
Print cartridge jam error 3527
I cleared this error by manually moving the head cleaning pad into its stand by position It must of stuck while changing the ink cartridges.
Posted on Oct 11, 2010
SOURCE: Kodak ESP 3250. Error 3527. I put new ink
Contact Kodak. I think it's the batch of printers that were made around this time. I just contacted them (mine is the same age and I'm getting the same error), and they are sending me a new printer.
Posted on Mar 09, 2011
Error code 3527
Yes; I would find the reciept to the printer and return it to the manufacturer for an exchange for a newer and better one!
Jan 23, 2013 | Kodak Esp 5210 All-in-one Inkjet Printer
Clearing Code 3527 from Kodak Hero 9.1
Hi friends,
I was able to solve this problem (error code 3527 on Kodak hero 9.1) by opening the printer entirely (dis-assembled), Checking the cartridge carriage assembly, i discovered that the belt that drive carriage assembly had a locker that was broken as such, the carriage assembly could not move in the direction as the motor drives the belt on.
I simply inserted the belt in position and drop a little drop of super glue to it, let it dry off.
Assemble my printer, and it was ok and is working.
Aug 01, 2012 | Kodak HERO 9.1 All-in-One Printer with...
Code 3527 Printhead carriage jam on Kodak ESP 5210 All in one
the only thing i can think off is there is a problem with the head sensor, the heads move back and forth on a rigid belt but the head case also runs along a see through plastic strip, this has lines in it and tells the printer were it is, other thing i can think of is the head cleaner, they can get stuck in them sometimes and cause misalignment and damage the reader. also anything they like to use on printers is a inc use chip that can make faults come up so you have to buy a new printer. this has been in a few articles. business printers don't have this feature. hope this helps
Jun 05, 2017 | Office Equipment & Supplies
Printhead cartridge jam code 3527
Contated Kodak about the error code 3527 and was advised I needed to purchase another printer and they would give me a 30% discount. Why would I do that when my Kodak printer is only 14 months old! My Dell is 9 years old and works fine! Dell ink cartrides are expensive and can only be ordered online. That is why I switched to Kodak. Do not buy Kodak!
May 01, 2011 | Kodak ESP 7250 All-in-One InkJet Printer
Kodak ESP 3250. Error 3527. I put new ink cartridges in.It started to pull the paper thru then stopped. I had to remove the paper buy pulling it back out. It says Printhead cartridge jam. Open printer...
Feb 02, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
Kodak esp3250 error code 3527
Hii follow the below link to fix kodak esp3250 error code 3527
http://tinyurl.com/kodakerror
All the Best
Dec 20, 2010 | Office Equipment & Supplies
My kodak copier model esp3250 shows an error code of 3527...what do i do?
Mar 13, 2010 | Kodak Office Equipment & Supplies
Error code 1-2036 on Kodak ESP3 printer
this error code is for printer scanner. run clear utility from www.kodak.com/go/clear
and reinstall kodak software from
www.kodak.com/go/downloads.
Note-  Do not connect your printer while installing the software untill installation wizard say to do so.
MS
Jun 14, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Sharp ar 5320 foud code F 7
Hello sir;E7 that' means this machine laser unit have problem, remove it send it to shop for repair.
May 14, 2009 | Sharp AR-5320 Black and White Copier
Kodak ESP 5 Printer Logo
42 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
