Question about Dell E153FP 15" LCD Monitor
Dell Monitor 1704FPT1 Blanks out after 5 mins & can be turned on for a second at a time when I press the monitor power button. Thanks
SOURCE: Dell E172FP 17 monitor keeps blinking
That sounds like the backlight inverter board. Check ebay for the board or a repair kit for it.
Posted on Oct 23, 2007
SOURCE: Dell Monitor 152FPC POWER BUT DIMMED SCREEN
At my place of work, we've had several blown capacitors on this monitor. You can see the capacitor bulging once you tear apart the monitor. Radio Shack 1000uF is the replacement, and only costs about $1.50.
Posted on Nov 19, 2007
SOURCE: Dell E172FPb 17" LCD Monitor Problem
C2? 1000uF 50vdc Electrolytic, worked for me, identical problem.
Posted on Jan 05, 2008
  • 1684 Answers
SOURCE: Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 30, 2009
paulbtorrent
  • 34 Answers
SOURCE: lg flatron w2234s monitor is flashing ??
The problem is the VGA part of the moniter is playing up. Two areas, one the MCU on the vga card, the other is a faulty transistor on the vga card. Repairs on a PCB VGA circuit are impossible with out the right tools.
The part number you require are Manufacturer Part Number EBU59489401
Board Numbers 791501300700R
For a replacement card
if no warrenty
Some thimes the 5 sec can be 20 to 30mins.
Posted on Jan 15, 2011
Unlock E178FP monitor menu
I don't know what you're referring to, but here is something i think it might be...
1. Power on the monitor.
2. Press and hold the MENU button for at least 15 seconds.
3. Look to see if an UNLOCK icon appears on the screen.
4. Release the MENU button and wait 5 seconds.
5. Press any button on the monitor to test.
6. Turn off the monitor if it is no longer needed.
Mar 03, 2014 | Dell E178FP 17 inch LCD Monitor
We have rolled out Dell Optiplex 790 machines running Win XP and using E2210 monitors. Recently networking applied power managment options to power of the monitors in 20 mins of inactivity. The monitor...
Turn off power saving mode in your monitor. In monitor beside orange light there will be a menu button press it and find for power management ok it turn of power management. The problem will be fix.
Sep 13, 2017 | Dell E2210 22" Widescreen Flat Panel...
Hi, I have a Dell Latitude D830. The display was off. I can connect extrenal monitor for current work. Please advise if I need replace display or motherboard ? Thanks Alex
Before replacing anything verify that your laptops display type didn't get changed to VGA out only.
look at your function keys (usually top one or two rows ) and look for the key that has a pc/monitor icon. with the machine powered up and connected to the external monitor press the function (FN button lower left of keyboard) and the video/monitor button at the same time. most laptops have 3 settings:
laptop display only, external display only and laptop and external display. Press the FN/Display button at lease 3 times waiting 3-5 seconds between keystrokes. I have seen this many times where the FN/display button keys are hit inadvertently.
Typically if the motherboard or video card fail the external monitor would not work either.
Jan 04, 2011 | Dell Latitude D830 Notebook
Dell P2210 menu is locked, how do I unlock it?
You have to hold down the top and bottom buttons at the same time for around 10-15 seconds and it will eventually display an unlock icon and you are back in business..
Sep 07, 2010 | Dell P2210 Monitor
Dell E152FP monitor after startup or coming back from standby the screen will show up and 5 seconds later it disappears. I turn off the monitor and turn it back on. The image comes back again but it...
Hello
Probably the monitor. LCD monitors use electrolytic capactors which change value with heat. The power board in yours probably has 6 to 8 caps whic need replacement. Take it to a reputable repair person or check out my websit.
Thanks
Jan 07, 2010 | Dell E153FP 15" LCD Monitor
My monitor shuts down after one second.
Dell monitors automatically go into power-save mode after a preset amount of time when the computer is inactive. The Dell monitor will go completely black, instead of showing a screensaver. This doesn't mean that your Dell computermag-glass_10x10.gif has shut down. Instead, this allows your monitor to essentially turn off until it's needed again. You can change how long it is before the Dell monitor goes into power-save mode by changing your display settings.
  1. Step 1 Press any key on your keyboard or move your mouse. Either will turn off power-save mode. Alternately, you can press the power button on your Dell computer tower or laptop.
  2. Step 2 Press any key a second time if the monitor goes from power-save to stand-by mode. Stand-by mode allows the screensaver to appear.
  3. Step 3 Enter your user name and password into the login prompt if your computer requires a login. Press "Enter" to begin using your Dell computer.
  4. Step 4 Change the display settings on your Dell monitor to prevent your monitor from going into power-save mode prematurely. Right-click anywhere on your desktop and choose "Properties." Click the "Screensaver" tab and press "Power." Beside "Turn off Monitor," choose a time amount from the drop-down list and press "Apply."
Nov 13, 2009 | Dell Dimension 3100 PC Desktop
Screen comes on briefly then blanks out.
check inverter, memory, and powersupply.
May 31, 2009 | HP w1907 LCD Monitor
I am using view sonic monitor & i am facing a problem with it .At the centre of the screen there is a message in blue colour filled box that"osd lock"its irritating
OSD and Power Lock Settings
• OSD Lock: Press and hold [1] and the up arrow 􀁓 for 10 seconds. If any buttons are
pressed the message OSD Locked will display for 5 seconds.
• OSD Unlock: Press and hold [1] and the up arrow 􀁓 again for 10 seconds.
• Power Button Lock: Press and hold [1] and the down arrow 􀁔 for 10 seconds. If the
power button is pressed the message Power Button Locked will display for 5 seconds. With
or without this setting, after a power failure, your LCD display’s power will automatically
turn ON when power is restored.
• Power Button Unlock: Press and hold [1] and the down arrow 􀁔 again for 10 seconds.
Well this Should resolve ur issue
May 13, 2009 | ViewSonic E70fb 17" CRT Monitor
Viewsonic VE175b Monitor Powers Up Doesn't Display Windows OS
Hi; I had the same problem. I know that sometimes devices require you to perform some type of '10-30 second' "hold" of one or some of its buttons in order to 'reset' the device, so to speak. So, having said that, try this:
1) Turn your monitor off (no green light) but leave it plugged in.
2) Leave it off for about 10 seconds.
3) Hold the [2] button on your monitor (the one to the immediate LEFT of your monitor's POWER button).
4) While holding the [2] button, now press and HOLD your POWER button.
5) Wait for your image to appear and STAY onscreen for about 5 seconds, then release both buttons.
6) Your monitor should retain its onscreen image.
Hope this helps! Good Day to all!
Kelvin W.
Dec 04, 2008 | ViewSonic VE175b 17" LCD Monitor
Dell E153FP 15" LCD Monitor Logo
376 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
