Question about Akai Professional Akai Pro MPK61 61-key USB MIDI Controller
Akai mpk 61 firmware
Blue screen and thats it nothing else Deleted manufacturer trying to upgrade firmware nothing comes up on screen tried to put it back on but must be doing something wrong
Akai firmware
Hippo.com has a ton of free downloads
Jul 29, 2014 | Akai Professional Akai Pro MPK61 61-key...
Can I get my akai keyboard port repaired as its damaged?
I see no reason why not...but that will depend what part of the country you are in...where are you located???
Jan 20, 2014 | Akai MPK mini MIDI Controller Keyboard,...
Not working, power is on but nothing is coming up in the screen
The embedded software on board is not booting up. It may have detected a hardware problem. Make sure the power supply is in good condition then disconnect everything else and try again. If fault remains, its toast.
Dec 16, 2013 | M-Audio AXIOM PRO 61 MIDI CONTROLLER
Akai mpk broken conector
Its a lot simplifier than that really.. all you need to do is unsolder the old one and re-solder the new one.. The pins and connectors are standard.
Dec 30, 2012 | Akai MPK mini MIDI Controller Keyboard,...
Akai MPK mini MIDI Controller Keyboard, 25-Key ... my keysare broken from were it clips on
I have the same keyboard, what do you mean from where it clips on. Do you mean the keys itself are broken? I'm not sure how you did that, but you can contact Akai and see if they will send you a new one. Those keys are supposed to be pressure sensitive and unbreakable. Please rate me for assisting you today! :-) PS I love that little thing!
May 09, 2011 | Akai MPK mini MIDI Controller Keyboard,...
My knobs of my AMAY MPK mini just don't work!
This is likely a software you are using with this is either not compatible with those particular controllers OR is not set up to use those controllers. Someplace those need to be mapped into whatever you are trying to control with the knobs.
Mar 07, 2011 | Akai MPK mini MIDI Controller Keyboard,...
Operational book for a akai pro mpk 49
Try this website:http://www.akaipro.com/content1023 I hope this helps.
Apr 07, 2010 | Music
My keys have popped up on my akai mpk 49
use black electrical tape. put tape on the edge of the key and cut it at the bottom of the mpk
Feb 21, 2010 | Music
Akai Professional Akai Pro MPK61 61-key USB MIDI Controller Logo
43 people viewed this question
Top Akai Music Experts
T-Comtech Repairs
T-Comtech Repairs
ray gallant
Are you an Akai Music Expert? Answer questions, earn points and help others
