Tv toshiba cinema series bbe
I accidentally erased almost all the channels on my television. I am unsure how to get them back.
  • Televison & ... Master
  • 9,587 Answers
Go to the setup menu and select channel search
Posted on Mar 20, 2014
  • 4 Answers
SOURCE: While watching my toshiba cinema series 36
I'm going to speculate. Audio system component shorted (output), changed bias and picture faded, *POP* component failed completely, bias returned to normal, picture returned.
?Shorted resistors and/or chips in audio output circuits?
I wouldnt expect electrolytic caps to be a problem in these newer units, but you might check for open caps too.
Check your level from the power block, if you can scope your B+, check the ripple. If its bad, the PS block may have been damaged.
Take this with a grain of salt. I'm not real framiliar with these units.
Posted on Mar 15, 2009
tvrepairbiz
  • 63 Answers
SOURCE: My 36
You need to have the vertical IC resoderd I think it is ic301
Posted on Feb 15, 2010
  • 144 Answers
SOURCE: tv is showing 480p and we want it at 1080p on our
After searching the owners manual I find that there is nothing mentioned about the screen resolution i.e. 480p to 1080p.
This set is capable of your desired resolution and as far as I can tell it auto selects because it senses the input video and decides which is the best setting for that source.
It's important to understand that you need 1080p video to use it at it's full capabilities. It won't give you a 1080p resolution from a VCR or a standard DVD player. You need a DVD player that is capable of producing a 1080p encoded video. Some satellite receivers are capable of that but you need to make sure you know what resolution that you are sending to the television.
Local TV stations won't usually broadcast HD at 1080p. Your best bet is to use a DVD player that is capable of that high resolution for your best picture.
Please note that what it says in the owners manual about "Resolution" has nothing to do with the 480p, 720p or 1080p signals, your set selects that automatically it will start by selecting the 1080p then goes to 720p then 420p it's dependent on the video you send to the set.
Please note the "resolution" function is actually like a "sharpness" control.
Your video input (tuner, VCR, DVD, games and etc.) is likely your problem.
Posted on Mar 30, 2010
pabloloco
  • 2335 Answers
SOURCE: I need an instruction manual for a Toshiba Cinema
Toshiba Cinema Series TV manuals can be found at Toshiba's website here.
Posted on Mar 14, 2011
SD Tech
  • 14553 Answers
SOURCE: Can't view all my channels on LXI series TV
For anyone with a set with this problem that is older----IT DOES NOT HAVE THAT PART OF THE CABLE BAND BUILT INTO IT--only solution is either to put a cable box to it or buy a new set.
SD TECH
Posted on May 27, 2012
Toshiba tv cinema series problem doing the software upgrade when the upgrade starts to download after a couple of minutes it gives me a error msg saying it couldnt download. I am using the download via...
Check the settings on the wifi portion of the television. If you have a cat5 connection try using that to connnect to internet. If you still have the problem, activate the factory reset process on the television and then use setup again. Then try the update.
Mar 02, 2014 | Toshiba 55WX800U Cinema Series 55 class...
Toshiba 62" DLP Cinema Series
Could be the cooling fan. Is it under warranty?
-Kevin
Jan 04, 2011 | Toshiba 62HMX95 62" HDTV
I have a toshiba cinema series. Tried to put
rabbit ears wont work on any tv anymore,you need a converter box,its all digital now,call your local cable company,they did this a few months back(government).
Oct 25, 2009 | Televison & Video
Our tv is 10 years old toshiba cinema series it has blue and red
It will be 11 years next month that I've had my Toshiba 55H55 Cinema Series and have the same problem every now and then, if you haven't already done so, go to the picture settings and scrolling down to conversion and it will take you through 3 steps of adjustments,there is a white cross in the middle of the screen line up the red first and then the blue, it will then take you to a screen with numbers, ID the clearest number and exit out, you should have a clear picture again. I hope this helps.
Jan 06, 2009 | Toshiba 50H81 50" Rear Projection...
Olevia syntaxbrillian flat screen tv model527-S12
go through the setup and have the TV auto programm again. This should fix the problem.
Dec 06, 2007 | Televison & Video
Toshiba 50" cinema series
Try to unplug and replug back the power cord of the
tv and turn it on again. Sometime this work.
Sep 09, 2007 | Toshiba 55H70 55" Rear Projection...
RE: Toshiba 27" Cinema Series
your problem is in the high voltage circuit.change your flyback it has a short.also check around for open diode in the same circuit.good luck
Aug 04, 2007 | Toshiba 27A34 27" TV
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
