Question about La Molisana Pasta Penne Ziti Rigate P
Time to boil this pasta is NOT listed on package, be it 5 min, 10 min, 15 min 20 min. What is the magic number for pasta from La Molisana?
I have a androide tablet la pan 4.0 android os it has home screen and ask for a pass word i do not remenber it how do i re set it ?
Factory reset! Turn off, then press power on and volume up or down at the same time till android appears then follow instructions.
Oct 04, 2015 | La Pavoni Imperia Pasta Maker-Maunal (for...
How to cook lasagna
The pasta does not need to be boiled prior to assembling the lasagna.
Mar 01, 2013 | Norpro Atlas Pasta Machine Lasagna...
How do you cook pasta? Do you boil the water with the pasta in or wait till it is boiling to add it?
In terms of water to pasta ratio, you should use around 4-6 quarts of water for every pound of dry pasta. Once the water has come to the boil add the pasta and then bring it back to the boil. Add some salt, stir occasionally and follow the instructions on the packet to find out how many minutes to cook it for.
Feb 20, 2013 | Cooking
Whenever I cook pasta the water boils over and causes a terrible mess. How can I stop this happening?
The most common cause of water boiling over when you cook pasta is if you cook it with the lid on the pot. Don't cover pasta fully with a lid. Either cook it uncovered or if you are in a hurry to cook it quicker, just partially cover the pot.
Also make sure you don't overfill the pan with water as this is another cause of overboiling.
Jan 10, 2013 | Cooking
As seen on tv pasta express cooker instructions
Fill the container with boiling water, place pasta in the container, cover and let sit for 10 minutes. This will work on most pastas. Denser pasta, it just does not work.
May 09, 2012 | Tristar Pasta Express "As Seen on TV" -...
Need instructions for pasta and more
by how much water do you mean how much water do you put in the pasta or how much water to boil to cook pasta??
cooking pasta is easy.. if its dry pasta around 8-12 mins or according to package instructions but fresh pasta takes a shorter time at around 2-5 mins :D
hope it helps :D
Mar 04, 2012 | Kitchen Appliances - Others
La pavoni stops boiling water
Run some WHITE vinegar through it, followed by plain water a few times. The heating system gets a buildup in it and requires cleaning from time to time.
Feb 06, 2012 | La Pavoni Coffee Makers & Espresso...
My pasta gone into a solid lump how do i unstick it
Sorting out pasta starts at the beginning. I'll tell you what I do.
1. Get your water on a fast boil 3/4 full in a pot (depending how many you're feeding). A rapid boil is essential.
2. Add some oil (sunflower or olive), about a tablespoon, and the boil will send it through the water.
3. NOW add the pasta, and give it a good stir rather than leaving it in a clump in the pot. Separating it at this point will help ensure there's no gloops at the end. Give it at least two more stirs (at least!) through the cooking. You must separate it to avoid the lumps and clinging together.
4. Cook it for as long as the package suggests, then strain off at the end and serve.
Hope this helps :)
Aug 14, 2010 | Kitchen Appliances - Others
Can i cook spaghetti in the pressure cooker
I have not tried spagehetti but i do cook macironi in there.
i use 2 cups of pasta.. macironi or shells. 1 cup water and 1 cup milk.. then 1 cup shredded cheese. 1 table spoon of butter.and 1 table spoon of olive oil i select rice and add time until it gets ot 10 min.
then i have macironi and cheese.
i also make pasta with tomato sauce in there.
again 2 cups pata shelles.. 1 can of tomato sauce, some choped onions.. 1 cup ground beef. and 1 cup of water. set cooker for 10 min ..
Apr 02, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
La Molisana Pasta Penne Ziti Rigate P Logo
69 people viewed this question
Top La Molisana Cooking Experts
Tom Chichester
ray gallant
Are you a La Molisana Cooking Expert? Answer questions, earn points and help others
