Question about LG Televison & Video
Westinghouse when i turn my tv on there is a picture but after about 3 min it goes black what do i need to fo
    Problem Solver:
  • 5 Answers
Sounds like the screen has went out for further assistance call 800-243-0000 or go here
LG Helpline Contact and Customer Service Phone Number LG USA
Posted on Apr 14, 2014
  • 155 Answers
SOURCE: Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Posted on Oct 26, 2008
  • 4 Answers
SOURCE: Westinghouse tv ltv46w1hd sound no picture
www.cfusion.com has the spare parts for that tv. it sounds like it is the mainboard. shouldn't be more than 150-200 to replace.
Posted on Apr 03, 2009
skotkolr
  • 558 Answers
SOURCE: Sharp LCD TV, Screen goes black sound stays on
Capacitors on the power pack are going bad they need to be replaced that should fix the problem.
Posted on Apr 07, 2009
SOURCE: I have a Westinghouse TV , when turned on the
I just fixed the same model and with your symptom. What it appears to be is the main module is locking up just after the Logo goes away. All you can do is unplug and try again and all you will get is the logo for 5 seconds and then black screen, no sound and led stays lit. Cannot turn off or on. The power supply is actually working fine, it's the main module that has died. This module is no longer available, the part number was W470PROLX68. What i did to restore operation on this unit was to insert 3 volts into the plug going to the master inverter board and then plugged the tv AC cord in. The set showed the logo and then it started working. I removed the 3 volts and it has worked every time since then.
Here is what you should try to do: First take two AA batteries and solder them in series and attach two short wires so you can use it as a power source. Now you have a 3 volts power supply. Next Remove the stand first before removing the back cover. Looking at the back of the unit you will see the power supply and the main circuit boards in the middle (under metal shields) and two boards on each side. These are partially covered with a metal shield, the one on the left side is the master inverter, the one on the right is the slave inv. They both have a plug and wires going to them from the power supply, but the one to the master will have two extra wires. I believe the colors are purple and blue, and they are separated with an empty hole (unused part of the plug). The wire on the end is where you will hook up the positive lead of your battery pack. The negative lead simply goes to the metal shield. With these hooked up plug the tv into the ac and give it a couple seconds and hopfully you will see the tv come on. If it does then disconnect the battery pack and try it without it. good luck.
Posted on Nov 17, 2009
ladywinn
  • 5138 Answers
SOURCE: I HAVE A WESTINGHOUSE HD TV 23
Look for Bad capacitors on power supply board they will be vented or swollen on top 220uf 10v 330uf 1000uf 16v
Posted on Mar 18, 2010
Tv works with sound but no picture
Sounds like we have the same problem with a similar Television, I'm attempting to fix a Westinghouse LTV-32w4HDC that has a great picture and sound for about 10 min max. then the screen goes almost completely black(you can make out the red colors somewhat) and the sound is just fine. From other posts on the internet I'm trying to replace the T-CON board. I just ordered one from www.tvpartsguy.com for 25.00 +$10 shipping. I'll post back when it comes in and if that solved the problem. My TV only has four boards in it: T-CON, Main, Inverter and Power board. T-CON seems like the most likely canidate from other posterings and it was the cheapest. Next likely canidate will be the Inverter board I guess. If you have a phillips screw driver and ahve ever taken apart a desktop computer this T.V. shouldn't be a problem ( if you feel uncomfortable, take lots of pictures first so you know how it all goes back together).
Jun 26, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Oct 26, 2008 | Vizio Televison & Video
The picture goes blank after about 3 or 4 minutes. I have to shut it off and wait a few seconds and turn it back on. It does this 3 or 4 times and then it seems to stay on.
When the picture go black,tv still have audio?Yes,than those 1 or 2 long boards that call the LCD inverter boards are the problems are dying.If picture goes black and no audio at all?Yes,than the tv Tuner signal board have problems is dying.The tv Tuner signal board it is the board,where the incomming broadcasting signal cable plug into it.Tries websites like Shojimmy.com,Ebay.com to buy those 1 or 2 refurbish long LCD inverter boards or the tv Tuner signal board for the replacement.
Mar 02, 2011 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse SK26H240S - Sound works but no picture?
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 27, 2009 | Westinghouse SK-26H240S Television
40" LCD Westinghouse Pictures comes and goes rapidly
Take it in to a service center for an Estimate. Parts are very difficult for Westinghouse sets.
Jul 15, 2009 | Westinghouse Electric VK-40H580D 40 in....
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Westinghouse 27" lcd hdtv
My Wesinghouse 27" lcd hdtv jumps and vertical hold is out of control after being on 15 mins. The cable company checked the connection and it is clean. We did not damage the tv. It has been doing this since we got it. We did not get a service contract. Sometimes the screen goes black with a small rolling picture on top. Help me please. Can the maufacter still help us?
we lost all the papers when we moved.
Jan 27, 2008 | Westinghouse LTV-27w6 27 in. LCD HDTV
Sumsung HLP 4663W
Might be a bad ballast, has the picture been dark?
Jun 21, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Flickers on cold startup after 5 min then goes away in 2-3 min.
I had same problem. Tech's said the power was noisy. I cleaned up the power but the TV still did exactly as you describe. Problem will progressively get worse with longer bouts of flickering. I was under warrenty and sent the TV back. After 3 months I am still waiting for a repalcement.
Jan 12, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Televison & Video Logo
21 people viewed this question
Computer Repairing
Computer Repairing
