Question about BenQ Office Equipment & Supplies
Projector : BENQ mp610 lamp turns on and then when fan starts running , lamp goes out, no light on LED indicators, not powering up anymore
Projector : BENQ mp610 when turn on lamp lights on and then when fan starts running , lamp goes out, no light on all LED indicators, not powering up anymore
  • BenQ Master
  • 9,587 Answers
Check the ballast board. It is the one that has the wires going directly to the bulb socket.
Posted on Mar 20, 2014
  • 11800 Answers
SOURCE: I have a BenQ PB6100
The inverter - the system that generates the high voltage needed by the bulb - has failed due to normal wear. When that happened it has surely done some damage in the power source also.
The projector is fixable, the inverter/ballast board will have to be replaced and the power source tested and repaired if necessary. But on an such old device, age related failures will be common from now on and in the end fixing them will cost you more than a new one - it's time to accept that this one has done its duty and it's time to retire.
Just cut your losses and buy a new one.
Posted on Jan 07, 2011
projdoc
  • 2236 Answers
SOURCE: 3m-X50 Lamp will not light up. Changed lamp.
you have a bad ballast. you'll have to replace it.
Posted on Jan 27, 2010
projdoc
  • 2236 Answers
SOURCE: Projector powers down as soon as LAMP lights up
the ballast/power supply needs replacing.
Posted on Dec 23, 2009
projdoc
  • 2236 Answers
SOURCE: rest benq pe8700 projector
if the lamp comes on, hold the exit button down until the osd comes on. press enter, then the right or left arrow button to reset it, then the exit.
Posted on Nov 12, 2009
SOURCE: BENQ PROJECTOR
Mine needed a "fan module" replaced. The part number is 60.J8613.011.
Cost was $60, plus $100 for labour.
Posted on Apr 10, 2009
Benq w1000 project not turning on
Look at the manual page 34, for the indicator messages. I suspect it's the same problem I have (which I haven't had formally diagnosed yet!), which I believe is a defective fan. My projector had been making a really loud noise on startup, which varied in length and volume. Recently the projector has taken to turning itself off after being on for about a minute, and the power light flashes green, with the temp and lamp lights flashing red.
Jan 27, 2012 | BenQ W10000 Projector
Power on, fan runs, get a red led at the "lamp" indicator then the projector goes to standby and shuts off. Projector is a benq MP515
Hi
Check the lamp physically if looks ok then problem suspect with Lamp ballast or lamp
ANS BY
M.R. Mumbai & Dubai
Sep 01, 2010 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Benq Projector MP721 stops illuminating after about 1 minute on. The lights are as follows: Power: Off, Temp: Red, Lamp: Green. Shortly after the projector shuts off. Thoughts?? My assumption is that the...
it might be dusty enough to hold in the heat. it needs a good cleaning. use canned air. if you still have an issue, the fans might be running too slow or the thermister (temp sensor) may be faulty. sometimes if it gets too hot in there, the thermister needs to be replaced, too.
Sep 11, 2009 | BenQ MP610 Multimedia Projector
Temp and lamp led turn on after 1 Minute
The fan has again got burnt out. Try replacing with the fan of the Benq Brand or a compatible one as depicted in the manual or contact:
Headquarters
16 Jihu Road, Neihu,
Taipei 114, Taiwan
Tel: +886-2-2658-8880
Fax: +886-2-2797-9288 or check up the address from the net regarding your country's support or Authorized representatives close to you and get the details mailed back.................sodeep
Jun 02, 2009 | BenQ MP610 Multimedia Projector
How do you open a BENQ MP610 projector to replace the light? What tool do you use? Thanks Marty
I just replaced my lamp for the same beamer. Took me a while to figure out how, but if you know how, it is easy. Turn the beamer on its back. In the middle, you will see a black rubber (small), it covers a hole and a screw is in the whole. Pull the small bblack rubber out. Unscrew the screw. A small cover will come loose. And there is the lamp, You have to pull out the power cable, and than only one little screw that mounts the lamp to the inside of the beamer.
It's easy!
Hope you will succeed,
Ojnoka
May 23, 2009 | BenQ MP610 Multimedia Projector
BenQ MP612c projector has three orange flashing lights
you can go to the BenQ website and download a manual for your particular projector. It should tell you what the lights indicate.
Feb 01, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
PB6110 Powers down after 30s, splash screen appears, red temp lig
Be sure to check the filters and make sure you have good airflow thru the proj. Cleaning filters solved our temp shutdown problem.
Nov 17, 2008 | BenQ PB6110 Multimedia Projector
BenQ MP610 Multimedia Projector Problem
I don't have the manual on this one, but in general if the lights indicated that the lamp needed to be changed because of hours of use, then until the lamp hours have been reset, the lights will remain. The owner's manual should have the procedure for resetting the lamp hours. Try that and update this if you still have a problem. Also, check to be sure that the lamp access door is closed completely. There are safety switches that get activated when the door is not installed correctly.
Dan
Sep 25, 2008 | BenQ MP610 Multimedia Projector
Projector shuts down after only a few minutes.
I'm having the same problem. My Model is PB8253. Projector started, then afer a couple minutes it goes off with the red lamp led flashing.
Just replaced the lamp, but the problem persists. Tried to remove all connecting cables, except for the power, but still the same problem.
Anyone with similar problem or solution, please contact me at dartveiga@gmail.com
Jan 19, 2008 | BenQ PB6100 Multimedia Projector
320 people viewed this question
Top BenQ Office Equipment & Supplies Experts
Tom Chichester
Electro Med Services...
Tony
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
