Question about Maytag Dryers
Maytag dryer remove back cover
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 33 Answers
Maytags are usually accessible from a front panel.
Posted on May 19, 2014
Replace belt on a maytag med6400tqo
bCheck out a video on youtube. This is a fairly simple do it yourself, but you will need to remove the cabinet of the dryer just leaving the barrel. Remove back cover, remove lint screws. Slide belt between cabinet and barrel. Lay dryer on back and around tension pulley and motor.
Jan 12, 2014 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
My maytag electric dryer won't start the light flashes off then on again
Remove exhaust. clean out lint. Remove back cover. Clean lint out of entire air system. Likely air block or overheating. If not, check back bottom of dryer for a white and black plastic thermal fuse. Unplug the 2 blue wires and electrical tape them together to bypass. Test dryer. If it works, replace thermal fuse before operating.
Jan 08, 2014 | Maytag Dryers
Maytag-dryer\model number -- Ldg7304aae
This is the heating element. they are easy to replace by removing the back cover. UNPLUG it from the power source first!! The part is cheap to.
Apr 28, 2010 | Maytag HYE3657A Electric Dryer
I Have a maytag Electric Dryer the dryer is
it could be your drum glides in the front of the drum or the rear center bearing or rear rollers, or the belt idler pulley or motor end bearings going bad,you will need to remove the front cover by removing lower kick panel screws near the floor and lifting upward on front cover,then remove top cover screws located under top cover and lift up and secure so as not to break wires to control panel,then rotate drum by hand and listen for noise location
Jan 25, 2010 | Maytag PYE2300AY Electric Dryer
Maytag 3000 series dryer, coins stuck in dryer fin
open the top of the dryer. slide the belt down to the power unit. of course you shoudl always unplug the unit first before removing the cover. carefully lift up ont he drum and they shoudl fall out. carefull y palce the drum back and the belt. replace the cover and plug in to see if that works.
Dec 04, 2009 | Televison & Video
Need help with installing belt in Maytag Electric dryer
if not able to remove rear panel,you will need to start,like most models,take top cover off and hinge back to wall then remove frt cover including door as a whole assy. lift up drum put new belt on drum ( and position in same area as old belt,it will have marks on drum from where original belt was on drum) then put rest of belt over mtr pulley and then idler pulley, turn drum by hand to align belts and put it back together in reverse order
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
How do you take the back off of a Maytag Dryer LDE4914ACE? I want to change the belt?
you cant take back cover off, you remove front cover and then access the top cover then you can replace the belt,there is an access panel on the rear you may need to remove to put belt on motor and idler pulleys
Jul 10, 2009 | Maytag PYE2300AY Electric Dryer
How to silence the bell on my Maytag Atlantis dryer
First listen for the bell and determine where it is. Unplug the unit and remove the cover where it is. Carefully remove the wire to it and insulate the wire with plastic electricians tape. Put the cover back on and make sure the dryer will work ok with the bell undone.
May 01, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Pye300ayw electric dryer dryer starts however it wont heat on an
Hi, unplug the dryer, there is an electric element on the back of the dryer, it should be covered with a removable metal cover, remove this cover and plug it back in turn the dryer on if the element does not heat it is probably bad, also check if there is a broken spot or if the element has shorted out, Hope this helps.
Mar 18, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Dryer Repair
Easy fix.
Open the top cover by insrting a putty knife in the top right and left sides where the top meets the bottom cabinet.
Lay the top to the back.
Remove 2 screws on the right and left front inside corners of the cabinet.
Remove the door.
Replace the belt around the drum and motor pulley.
Re-assemble the dryer.
Mar 10, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
20 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
