Question about Emerson MW8107WA Microwave Oven
Changing bulb Can't figure out how to change the 650 w 120 v bulb in an Astroscope 5000 projector??
    Master:
  • 397 Answers
Hi, you have posted in the wrong section. You have posted in the microwaves section.
Posted on Mar 20, 2014
Changing interior light bulb on GE jes1289sk
I have had this trouble before but with a different model. There may be a plastic screen inside the microwave that will just pop off exposing the bulb. Now all you will need to do is to find out what type of bulb you will need to change the other bulb. I hope this made things easier on you.
Jul 25, 2013 | Microwave Ovens
Can't figure out how to replace light bulb for model #721.66319
Sears Parts Direct lists the microwave, 72166319500 , as using the lamp, 6912W3B002L. This is available for $6.49 here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Microwave-Parts/Model-72166319500/0582/0123245/50026833/00004?blt=06&prst=&shdMod= .
Unplug the microwave and wait a bit before starting to replace the bulb. To change the bulb, you first need to take off the entire cabinet (remove 4 screws on the back of the microwave and lift the part up). Then see the parts diagram on the page given above. There are 2 screws that hold the switch and bulb assembly to the frame of the microwave. I believe you should be able to pull the bulb housing down from the middle of the assembly and then push the unit up after replacing the old bulb with the new bulb. However, the bulb housing may have two screws holding it in place.
I hope this helps.
Nov 25, 2012 | Microwave Ovens
Suddenly stopped working, changed bulb but made no difference
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 02, 2011 | Microwave Ovens
The light is out.
Usually, you have to remove the outer case after pulling the power cord and wait for maybe 10 minutes to make sure the HV power supply has discharged itself. The lamp should be plainly visible at this point. Be sure to use the same wattage lamp as the original. Good luck!
Jul 02, 2010 | GE JVM1540SMSS Microwave Oven
Light Bulb Change
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Feb 01, 2009 | Samsung MD800SC Microwave Oven
How do I change the light bulb in this unit?
it has to be opened up to be able to change the bulb , but there is a dangerous high voltage capacitor that you should not touch as it still will hold a charge
Dec 10, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
I have a Sharp model R-315J, 1200 watt counter top microwave. The bulb has burned out and I can't figure out how to get into the unit to change the bulb. Anybody know?
You need to remove the outer cover. The bulb is located on the upper right part of the oven mounted atop an air duct.
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it already.
Dec 05, 2008 | Sharp R-315JS 1200 Watts Microwave Oven
Light bulb
If you are comfortable with taking the cover off, Unplug the microwave, usually there are 2 philips screws on the top back, 2 on the right back and 2 on the left back edge cover. Sometimes, their might be a screw on the bottom but you will notice this right away if there are or not if the cover doesnt come off.
Then located the light bulb. You should be able to see the opening from inside the microwave where the light bulb is located.
Once you locate the bulb, then there are usually 2 types, type 1 screws in and the other type is a bayonet type, which you push down, and then twist. You should be able to figure this out.
Sometimes there is a plastic cover that is placed around the bulb to kinda help focus the light towards the inside of the microwave.
Once the bulb is out, then take it to your local hardware store and see if they can match it up. You might want to call first to see if they carry them before driving all over the place.
Hope this helps.
Good luck.
If i have helped you with you question, then please remember to post a feedback and a rating.
Thanks.
Mac
Feb 19, 2008 | Westinghouse WST3504 Microwave Oven
Emerson MW8107WA Microwave Oven Logo
16 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
