Question about Ball Joint, Tie Rod, Pitman Arm Seperator Set
Flat rate for replacing ball joints on 2003 f 150
Time to replace
150 is good price
Posted on Mar 21, 2014
Ball joints
Replacement time and the flat rate time are two different things. Flat rate is what the dealership mechanic for the job no matter how long the mechanic takes to do the job. Usually an alignment is necessary after ball joints because the new parts will change the toe specification.
Jan 09, 2014 | Cars & Trucks
How to replace ball joints on a 1998 mercedes benz s420
For ball joints issue.Before replacing it,first inspect and test the ball joints to confirm the problem:----Click the help links below to troubleshoot the problem and replace the ball joints:----Upper Ball Joints inspection and replacement? http://howtobyme.blogspot.in/2012/02/upper-ball-joints-inspection-and.html How to Test Upper and Lower Ball Joint? http://repairhelpcenter.blogspot.com/2011/12/how-to-test-lower-ball-joint.html How to inspect Upper and Lower Ball joint? http://repairhelpcenter.blogspot.com/2011/12/how-to-inspect-lower-ball-joint.html How to Service Ball Joints on Car? http://repairhelpcenter.blogspot.com/2011/12/how-to-service-lower-ball-joints-on-car.html How to Replace Ball joints? http://repairhelpcenter.blogspot.com/2011/12/how-to-replace-lower-ball-joints.html Lower Ball Joints replacing? http://howtobyme.blogspot.in/2012/02/lower-ball-joints-replacing-on.html----------This will help.Thanks.
Jan 31, 2012 | 1991 Mercedes-Benz 420
Have had to replace ball joints 3 times on my 97 lumina, any ideas why
Always use original parts instead of aftermarket products.Original parts cost bit extra,but they are exact fit and last longer.Click this link below to troubleshoot the issue :----Upper Ball Joints inspection and replacement? http://howtobyme.blogspot.in/2012/02/upper-ball-joints-inspection-and.html How to Test Upper and Lower Ball Joint? http://repairhelpcenter.blogspot.com/2011/12/how-to-test-lower-ball-joint.html How to inspect Upper and Lower Ball joint? http://repairhelpcenter.blogspot.com/2011/12/how-to-inspect-lower-ball-joint.html How to Service Ball Joints on Car? http://repairhelpcenter.blogspot.com/2011/12/how-to-service-lower-ball-joints-on-car.html How to Replace Ball joints? http://repairhelpcenter.blogspot.com/2011/12/how-to-replace-lower-ball-joints.html Lower Ball Joints replacing on car? http://howtobyme.blogspot.in/2012/02/lower-ball-joints-replacing-on.html
Jan 17, 2012 | 1997 Chevrolet Lumina
I would like to know the easiest way to remove the ball joint from the lower control arm. The upper portion that is bolted to the unibody is free, but after removing the dust cap from the arm connected to...
Leaving the nut loose so that when it pops parts don't fly use a fork pry bar designed to "pop" ball joints. If this does not work soar overnight with penitration oil and have someone apply pressure while you heat the control arm where the ball joint sits. The expansion of the metal will help with removal but it must be heated faster than the heat soak into the joint or they will expand at the same rate.
Mar 11, 2011 | 1998 Honda Accord
Upper ball joint repair cost with labor
Labor rates are different in other locations. the average labor rate where I am is 68.88 an hour. Your ball joint replacement says it takes 2.3 hours to do. the ball joint itself is around 50 - 60 bucks. you can figure the math when you find out what the shop you are going to use's labor rates are. I hope this helps and good luck.
Feb 06, 2011 | 1998 Chrysler Cirrus
Drivers side upper ball joint replacement
It appears your car only has lower ball joints, the link below will take to detailed instructions on how to replace the lower ball joints.
Lower Ball Joint Replacement Instructions
Please rate my advise.
Jan 14, 2011 | 1988 Toyota Camry
How to replace a lower ball joint on a 1988 pontiac grand prix hit a pothole and it popped out
Hope this helps and please don't forget to rate! Thank you!
Front ball joint with heat shield
Remove and Replace-
  1. Disconnect the negative battery cable.
  2. Raise and safely support the vehicle with jackstands.
  3. Remove the front wheel and tire assembly.
  4. Unfasten the retaining bolts, then remove the ball joint heat shield.
  5. Remove and discard the lower ball joint cotter pin.
  6. Remove the ball joint nut.
  7. Loosen, but do NOT remove, the stabilizer shaft bushing assembly bolts.
  8. Separate the ball joint from the strut/knuckle assembly using ball joint/tie rod puller J-35917 or equivalent.
Do NOT damage the halfshaft boots when drilling out the ball joint rivets.
  1. Drill out the rivets retaining the ball joint to the knuckle strut assembly and remove the ball joint from the knuckle. Use a 1/8 in. drill bit. Refer to the instructions in the ball joint replacement kit.
To install:
  1. Position the lower ball joint in the strut/knuckle assembly.
  2. Install the four ball joint bolts and nuts, as shown in the ball joint kit and tighten to specifications.
  3. Install the ball joint-to-lower control arm. Install a new ball joint-to-lower control arm nut.
  4. Tighten the stabilizer shaft bolts to 35 ft. lbs. (48 Nm).
  5. For 1988-91 vehicles, tighten the ball joint-to-lower control arm nut 15 ft. lbs. (20 Nm) plus at least an additional 90° (11/2flats), plus enough to align the cotter pin hole. Do NOT overtighten.
  6. For 1992-96 vehicles, tighten the lower ball joint nut to 63 ft. lbs. (85 Nm). Tighten to align the next slot in the nut with the cotter pin hole in the stud. Do NOT tighten more than 60° (1 flat) to align with the hole.
  7. Install a new cotter pin.
  8. Position the ball joint heat shield and secure with the retaining bolts. Tighten to 62 inch lbs. (7 Nm).
  9. Install the front wheel and tire assembly, then carefully lower the vehicle.
  10. Connect the negative battery cable and check for proper suspension operation
Apr 26, 2010 | 1988 Pontiac Grand Prix
The driver side suspension squeeks there is a lot of different openios some say ball joints some say struts anyone with similar problem and how to fix?
The squeeks would definately be the ball-joint.
I had the same problem few weeks ago till I changed my ball joint.
Replace ball joint please and rate my solution.
Good luck.
Aug 16, 2009 | 2001 Lincoln LS
REPLACING LOWER BALL JOINTS ON 2000 FORD F250 4X4 7.3L DIESEL
hello,yes you do have to take the hub off to replace the ball joint with the ball joint being on the back side of the hub. hope this helps and please rate this.
Mar 15, 2009 | 2000 Ford F250 Super Duty Crew Cabs
Ball Joint, Tie Rod, Pitman Arm Seperator Set Logo
50 people viewed this question
Top Lisle Vehicle Parts & Accessories Experts
Danny
Rigger
charles
Are you a Lisle Vehicle Part and Accessory Expert? Answer questions, earn points and help others
