Question about Maxtor One Touch III 500GB FireWire/USB2.0 External w/16M buffer Retail ****... 500 GB USB 2.0 Hard Drive
I plug my drive to the computer and nothing happens like I never plugged it up
Do I need a driver?
    Master:
  • 397 Answers
Most modern Windows systems should not require a driver for this type of device. What version of Windows or what OS are you running?
The problem could indicate the drive has failed and needs replacing.
Posted on Mar 20, 2014
I just purchased a "new never been used" bloggie complete with original packaging. I plugged it into my computer and pressed the "on" switch but nothing is happening.
Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8
it might take some time being a freeware driver solution note: it will find all of your outdated drivers This is a free driver solutions.
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Hope this helps
Dec 21, 2012 | Sony MHS-TS10/B Bloggie Touch HD Video 2GB...
Plug in my hard drive and nothing happens
Make sure that your usb hard drive is inserted properly into the computer but if nothing happens, go to your bios settings of your computer and be sure that usb function is set to on. Save changes and restart the computer. If you dont know how to do this, first turn on the computer and press the delete key in the keyboard, once you enter the bios screen look for the usb settings and make sure it is set to on. Hope this could help. Thanks
Oct 23, 2009 | Computers & Internet
My fantom hard drive was working perfect until i unhooked it to move the computor to another area of the house. now when i pluged it up nothing happened. i may have plugged the usb upside down but not...
First of all you cannot plug the USB upside down. it always will go only in one direction. as for the **** try right click my computer/manage and see if the disk is been recognised? if not you have a driver issue or a disk issue.
Jun 09, 2009 | Fantom Drives 120 GB Hard Drive
SimpleTech hard drive not found by my computer
This may or may not help, but it worked for me! After about 4 hours of trying everything (Device Manager/Uninstall, Disk Management, etc..) nothing at all would work. The USB external hard drive would power up but when you plug it in, the New Found Hardware will pop up and search unsuccessfully for drivers for a PLUG AND PLAY external drive!?!?!
In any event, I simply plugged another USB drive into my laptop (and desktop) and viola! The new hard drive was recognized and installed immediately as 'plug and play' should do. I then unplugged the new drive and tried plugging in the one that was recognized and all of the sudden....IT WORKS AGAIN!!!!
This fix might not help anyone who doesn't have a second USB external drive, but you could try plugging another USB device in and get it to load and then unplug it and try your drive. It worked for me on my laptop and then I did the same thing to my desktop (which also wouldn't recognize it) and it worked on the desktop too! Problem solved for me, thank GOD!
Hopefully, this bypass can save you a few hours of google time and unwanted anguish. Like I said, you may not have another USB drive but try plugging in any other USB device until it loads and then unplug it and then plug in your USB drive that wasn't working. It worked perfectly for me.
Hope it helps!!!!
-BIRDMAN - BIRD ^v^
Oct 02, 2008 | SimpleTech SimpleDrive 250GB, 7200RPM,...
if you are running windows, then check the following:
go to control panel -> administrative tools -> computer management -> storage -> disk management.
you probably have a drive (located on the bottom right) that is listed with no drive letter, just assign it a drive letter and see if it comes back, if not, the drive is probably not initializing and you might have to either format it or replace it.
Jun 12, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Nothing happends when I plug my drive into my PC's
Surely you have to install driver first because windows does not have it in cache. If you don't have go manufacturer site
Apr 17, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computer hookups
Jan , did the computer see new device ? The popup windows appeared when you plug the hard drive in?
Guest #1 : go to your computer maker and download most recent driver for your computer concerning the USB.
Guest #2 : Does Vista see new devicec jsut got plug in ?
Mar 29, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
RE: my external hardrive
Check cmos to see if usb ports are enabled? If Windos 2000 you need a usb driver disk.
Feb 28, 2008 | Maxtor OneTouch II external hard drive...
Computer just won't recognize reader
Was referring to the configuration. P3, P4, etc. Older boards that have a USB 1.1 port sometimes have compatibility issues with some USB 2.0 devices.
I recommend trying it on other XP-based computers. If it still doesn't work then the device has a problem. If it works then it could be a compatibility issue with your PC.
Hope this helps.
Jan 26, 2008 | SanDisk MobileMate SD Plus 5-in-1 Media...
Open Questions:
Maxtor One Touch III 500GB FireWire/USB2.0 External w/16M buffer Retail ****... 500 GB USB 2.0 Hard Drive Logo
125 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
